Which AIR Filter Do You Use?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mceagle555, May 16, 2008.
What AIR Filter are You Using?
  1. AFE Pro Dry S
    816 vote(s)
    18.1%
  2. AFE Oil
    52 vote(s)
    1.2%
  3. K&N Oil
    1,321 vote(s)
    29.4%
  4. Green Oil
    6 vote(s)
    0.1%
  5. TRD Oil
    204 vote(s)
    4.5%
  6. FRAM
    224 vote(s)
    5.0%
  7. Stock
    1,606 vote(s)
    35.7%
  8. Other
    270 vote(s)
    6.0%
  1. Feb 4, 2014 at 7:15 AM
    #601
    DonziGT230
    DonziGT230 Gearhead
    Oscar
    Hacienda Hts, Ca.
    '07 base taco. Sold. Now Taco-less
    Factory cruise added, wood storage box in bed, wood center console/armrest, charcoal air filter delete.
    Exactly what I find with every vehicle I service that has any aftermarket filter in it. Even a no name cheapo chinese paper replacement works better. I also don't change filters 'till they really need changing, a used filter filters better.
  2. Feb 5, 2014 at 8:22 AM
    #602
    lloyd
    lloyd Active Member
    Texas
    15 Tacoma Access 2.7
    HID headlights, LED interior lights, Hella and stock HID foglights, Hella HID driving lights, backup camera, Wiper mod, cruise control mod, higher rate springs , X- runner Rear rollbar and x-brace, K&N air filter, Amsoil in trans and diff, EBC yellow stuff pads pads, stainless brake lines, 18x8 40mm wheels with 235 55r 18 tires, oil cooler with remote big oil filter
    I ran a K&N filter in my 1986 4-Runner since it was new. At 483,000 miles I blew a head gasket. It was using no oil at that time. The cylinders still had the hone marks too. That was the only engine work I did on it.
    I put synthetic oil in it after 2,000 miles of break-in and only used it from then on. I had a remote big oil filter and oil cooler on it. I don't know if that helped or not, but I am happy with that wear with the K&N.
  3. Feb 6, 2014 at 6:21 AM
    #603
    DonziGT230
    DonziGT230 Gearhead
    Oscar
    Hacienda Hts, Ca.
    That does say a lot for the K&N, but any time I see dirt in an intake I know where it's headed. I'm guessing that since you cared enough to take the extra steps with the oiling system you probably kept the K&N well oiled which does help them a lot. Adding the extra oil filtration also helps mitigate some potential damage that contaminants could do.
  4. Feb 6, 2014 at 6:28 AM
    #604
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
  5. Feb 6, 2014 at 7:20 PM
    #605
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Oh, you gain a fair amount of flow, but the issue is that you don't need it.
    The stock system on the 2.7 can flow more than any normally aspirated 4.0 can pull, and the stock 4.0 system could feed the Tundra 5.7.
  6. Feb 27, 2014 at 4:17 PM
    #606
    Yakoma
    Yakoma Well-Known Member
    Randy
    ATL-ish
    '14 DCSB TRD Sport 4x4 - White
    Black APS Bull Bar Black Westin Step Bars Black ARE camper top with Yakima J-cradles (replaced Roll-X Tonneau) Black AMP HD Bed Extender
    Does anybody have the AEM Brute Force on a 2014 Tacoma?
    Is it this model number?
    21-8409DP
    Should there be any concern that adding this equipment might void a warranty?
    Thanks.
  7. Feb 28, 2014 at 7:35 AM
    #607
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Just use the stock one.
    It is the best air filter for the truck and is 100% guaranteed to be covered under any warranty problems.
    It is proven for a non supercharged engine our stock air intake setup is the best for it.
  8. Feb 28, 2014 at 8:25 AM
    #608
    Yakoma
    Randy
    ATL-ish
    Not really the answer I'd hoped for, but I appreciate your input.:cool:
  9. Feb 28, 2014 at 1:35 PM
    #609
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I find this very hard to believe unless all those miles are on road.
    I have a 08' Tacoma with a snorkel and after 20k of dusty offroad and on road use my entire intake would be filled with dust. I don't give a crap what oil you use of how many filters its goiung through silica passes right through K&N filters.
  10. Mar 1, 2014 at 7:37 AM
    #610
    Utard
    Mark
    Tidewater, OR
    2019 Tacoma SR5
  11. Oct 4, 2014 at 10:03 PM
    #611
    LadTacoma
    LadTacoma Well-Known Member
    Ray
    NJ
    Prime Mover
    I'm currently using afe-dry. It's been over two years. I'm happy with it but today I came up with an idea to rotate it out with TRD air filter. I'm expecting to receive it in two days. Can't wait to learn! :D
  12. Feb 21, 2015 at 10:35 AM
    #612
    tacomike0
    tacomike0 New Member
    mike
    brantford on
    2012 trd
    how do you remove the charcoal filter and where to find it on 2012 4.0l access cab
  13. May 3, 2015 at 8:09 AM
    #613
    Calgaryguy
    Calgaryguy Member
    Calgary
    2014 Double cab premium package
    Tail gat key lock,tray cover & subwoofer. Put carbon fibre on entry step, install chrome side bar install K&N intake air filter at 33144km
    I think you need to include K & N air filter also. you have the oil filter listed.
  14. Jun 13, 2015 at 11:58 AM
    #614
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Just took out my k&n I'm tired of dealing with it clogging up after one off roading adventure. Put an afe pro dry in, cleaned the tb, maf, and intake housing. We will see how long this lasts. The maf and Tb were so damn disgusting prior to the cleaning. But here's a question. Is our maf supposed to have a little tear drop piece on the end of it? I've cleaned maf's before and never noticed it.
  15. Jun 13, 2015 at 2:19 PM
    #615
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    yessir
  16. Nov 4, 2015 at 7:49 AM
    #616
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
  17. Nov 4, 2015 at 9:16 AM
    #617
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    They are all a waste of $$ imo
  18. Nov 4, 2015 at 10:11 AM
    #618
    moe2o4
    Corey
    Pittsburgh PA
    So your saying just get a drop it for the stock box and that would be sufficient?
  19. Nov 4, 2015 at 10:31 AM
    #619
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    What kind of driving do you do? Dirt roads, city, highway? If you're exposed to dusty environments, the good ole paper filter works best in my honest opinion. I ran the K&N for three months and I realized my MAF sensor was covered in a layer of debris. After making the switch back to paper, the amount of debris has lessened. It's honestly what you feel most comfortable with. You could probably run that K&N forever without any noticeable problems.
    moe2o4[QUOTED] likes this.
  20. Nov 4, 2015 at 10:33 AM
    #620
    moe2o4
    Corey
    Pittsburgh PA
    Not to many dirt roads until the summer when i go camping but other than that. Mostly city, highway, around town driving. I ran the K&N on my 13 and haven't gotten around to putting it on my 16 yet. Just wondering if its better to have a dry filter instead of the oiled one?
