Which ARB Air Compressor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bjmoose, Dec 13, 2010.
  1. Apr 28, 2011 at 1:23 PM
    bjmoose
    bjmoose [OP] Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I took some pics as I installed it, but somehow either my iPhone or my computer ended up eating up half of 'em, so I didn't have enough snaps to do a really satisfying install thread.
    I've got the 4 banger, so I mounted the compressor on the driver side fender, right behind the fuse box, using some thick rubber washers and grommets to provide some vibration isolation between the compressor and the body.
    I had to have ARB USA send me two separate parts - the air solenoid for the locker didn't hold pressure, and the Y valve for the add-on tire inflation kit was improperly threaded. :mad:
    As a result, my locker works, but I still haven't gotten around to installing the Y valve and tire inflation kit. So I can't really report on how well it works for airing up tires.
    My expectation is it'll be just roughly about as fast as my VIAIR 400 - around 3 minutes a tire or a little less (285/70R17.)
    It wasn't easy to find a good switched power line behind the dash - I used the most current wiring diagram off of toyotaowners.com ($15 fee for two days of access.)
    My most convenient power source was a tiny 22ga wire, so I brought in an unswitched power line from the battery and added a little solenoid there, behind the dash, and hooked the output of the solenoid as my "switched" power into the ARB air harness. That's probably total overkill, but I've had aftermarket stereo electronics fry a car computer before, and so I'm super paranoid about the whole thing.
    The dash lighting wiring doesn't work exactly the same as ARB's harness expects (they expect variable input voltage to ground) so if you want to wire up the lights with variable lighting levels, you have to do a tiny bit more work (wire into both a positive source and negative return, not just a positive source and then to ground.)
    Now, I *HATE* cutting factory wires, so after waffling for a while and I eventually decided I'd rather have unlit buttons than make necessary two additional cuts and crimps.
    On the tacoma "basic" model, there are three empty switch blanks right where things like factory Locker and atrac switches would go, so those made a great place to put the ARB compressor and locker switches.
    Anyhow, since then, ARB has now introduced an even newer continuous duty air compressor, so you'll want to check that one out as well.
  2. Apr 28, 2011 at 1:26 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    I also want to install right behind the fuse box. Did your computer eat that pic? Would like to see it.
  3. Apr 28, 2011 at 1:32 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I can take a new pic "as installed." Obviously that won't show the mounting holes.
  4. Apr 28, 2011 at 1:32 PM
    pAP
    pAP ==========
    NJ
    24 Tacoma TH
    Just tint and ppl for now.
  5. Apr 28, 2011 at 1:36 PM
    Dark Knight
    Jeff
    NC/SC
    Perfect, I'm just curious how well it fits there.
    the new constant duty is 2x as big as the heavy duty. Also pulls lots of power. I have had a Large OBA system, now downsizing to make things more sensible.
  6. Apr 28, 2011 at 1:36 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
  7. Apr 28, 2011 at 1:48 PM
    pAP
    pAP ==========
    NJ
    24 Tacoma TH
  8. Apr 28, 2011 at 8:14 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Here you go.
    Dash switches.
    Taken from the driver side - Front of truck is left side of pic:
    Taken from above the engine bay - Front of truck is right side of pic:
  9. Apr 28, 2011 at 8:25 PM
    sandman427
    sandman427 KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    here is mine...
  10. Apr 28, 2011 at 8:37 PM
    Dark Knight
    Jeff
    NC/SC
    hmmm lot tighter fit than I thought!
    Thats what she said.
  11. May 13, 2011 at 4:12 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    subbed for summer spending... :cool:
  12. May 13, 2011 at 4:17 PM
    Dark Knight
    Jeff
    NC/SC
  13. Oct 11, 2011 at 12:03 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    And now I've installed the front as well.
    When I initially installed the switches, I wanted to splice into as few factory wires as possible. So I didn't wire up the switch lights to the instrument light dimmer circuit.
    I figured - I don't wheel at night - why do I need the switches lit?
    Well, over time, I've figured out that I *do* DRIVE at night, and sometimes want to adjust the air vent on the driver side. And I don't want to accidentally engage the compressor or locker! So it's helpful to have those switches lit so that I can *AVOID* accidentally engaging them in the dark.
    So I spliced into GREEN (not "light green") and GREEN/WHITE wires off of the instrument panel rheostat to get my positive and negative leads for the three ARB switches' background lights. Naturally these are wired in PARALLEL not in SERIES. (And if you don't know what that means, I respectfully suggest you that you FIND OUT before you start cutting and tapping in to your factory wires)
  14. Oct 11, 2011 at 12:07 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Another note - when I first installed - I had a problem with the locker air solenoid releasing pressure when it wasn't supposed to. So I had ARB send me a new one.
    The same damn thing happened this time! So I figured it had to be me; nobody is that unlucky. So I pulled the little stainless dust cap filters from the ends of the air solenoids and cycled the switches again and again to blow them out. Eventually, the system held air reliably.
    I figure one of two things was going on:
    1. I'm obsessive about leaks. So I use a lot of teflon tape. As I installed and reinstalled the threaded connectors, it's possible a couple shreds of teflon tape got into the air tank and then got drawn into/stuck into the air solenoid, causing it not to close all the way and be unable to hold pressure.
    2. I'm obsessive about leaks. So I check for leaks with lots of soapy water. It's likely that some soapy water got into the air solenoid - and it's possible that the soapy mixture somehow prevented the valve from sealing shut relaibly so again, it blew at high pressure.
    At any rate, after I cycled the valves twenty times or so, they were holding reliably.
  15. Jan 13, 2012 at 9:19 AM
    #35
    Brunes
    Brunes abides.
    Rotorhead
    Around
    So yeah...Another blast form the past (not too far back tho)
    How tight are those switches to get into the dash in the blanks to the left of the steering wheel??
    Did you have to take out dash material to get them to fit?? Any photos of the wiring??
  16. Jan 13, 2012 at 9:42 AM
    #36
    n0rth
    n0rth Well-Known Member
    J.W.
    New Mexico
    2019 Tundra Platinum
    2009 Tacoma Access Cab SR5, 4wd, 2.7L URD S/C, 4:88's ARB lockers, 36x9.8r16 Radial TSL
    You will need to work the blanks with a dremel to get them to fit on the switch panel.
  17. Jan 13, 2012 at 9:44 AM
    #37
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah...I peeked and thought that was gunna be the case...A little, a lot??
  18. Jan 13, 2012 at 9:55 AM
    #38
    n0rth
    J.W.
    New Mexico
    It wasn't too much, maybe 10 min. to open all 3 of blanks up when I first took it apart I was like they'll fit no problem until I actually did a test fit. I did the same thing a few weeks ago when wiring up the ADD switch in the blanks below the stereo so it isn't much material to remove to get a good fit.
  19. Jan 13, 2012 at 9:55 AM
    #39
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Just sent one photo to TW live.
    Hot glue to hold the switches in place.
    Custom wires for the switch lighting since factory panel dim is on the ground side not the positive side.
    Pull dash lights from two wires in the dash dimmer that is RIGHT THERE as that's far and away easiest access.
    I also spliced into that for switched power.
    Use wiring diagram from NorCal ttora to see which three wires to cut into.
    Extra care cause they're like 22 gauge skinny.
  20. Jan 13, 2012 at 9:57 AM
    #40
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Okay-I gotta find some time to play with the truck now. And get in the mood to do some wiring....
    Saw your photo- That was a great start. I'll check out TTORA for that wiring too. I'm just running two switches for Fogs and Offroad Lights (For now- Compressor/Locker will be later)
