Which Are The Switch Dimmer Wires? (pic included)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tunngavik, Sep 24, 2011.
  1. Sep 24, 2011 at 10:01 AM
    Tunngavik
    Tunngavik [OP] Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    I just installed the heated mirrors mod and have the factory heated switch from a 2003 Highlander which can be used for the mod.
    I want to tie in the dimmer control/lighting into the new switch from the wires on the adjacent switch but not sure which wires on the adjacent switch are responsible for the dimmer. I know which posts to tie into for the Highlander switch.
    I have a 2010 Tacoma.
    Can anyone let me know from the picture below which wires are responsible for the dimmer? (ignore the yellow ones tied together with tape - these are connected to the 2 dimmer control posts on the Highlander switch)
  2. Sep 24, 2011 at 4:37 PM
    cverneau
    cverneau Well-Known Member
    Craig
    Cheshire, CT.
    11 Access Cab 4cyl 4x4 Auto
    AVS In-Channel Window Deflectors, AVS Rear Window Sun/Rain Deflector, EGR Front Hood Deflector, Weathertech Digital Fit Floor Liners With TRD Off Road Decals, TonnoPro Tri-Fold Cover, Coverking Black Neoprene Front Seat Covers & Front & Rear Center Console Covers, Black With Red Stitched TRD Head Rest Covers, Rear Grey Neoprene Wet Okole Seat Covers, Black Front Door Handle Pull Covers, Husky Custom Molded Mud Flaps, Devil Horns Of Fire On Satoshi, 7" Off Road Lights Mounted Behind Grill, Pop N Lock 5300, Seatbelt Chime Off, Interior & Exterior Led's, Cubby & Drink Holder Amber LED's, Infinity Reference #9633 6X9 Front Speakers, Solar-Gard HP Smoke 35% Tint, De-badged & Pinstripe Removal, Sun Visor Stickers Removed, Illuminated 4x4 Switch, ImMrYo Rear-View Mirror Lift Bracket, Ultragauge, TRD Aluminum Skid Plate, Bed Storage Cubby Locks Mod, Additional D-Rings In Bed, Rubber Bed Mat, Intermittent Wiper Stalk, Black Vinyl Arm Rest Mod, Secondary Air Filter Removal Mod, Spare Tire Rod Alignment Tube Mod, 14" Antenna Mod, Tailgate Theft Mod, DTRL Wire Jumper Mod, Parking Lights As Turn Signals Mod, Under Hood LED Strip Lighting Mod, 30 Watt Reverse Bulbs, PIAA 510's With LED's In Fog Locations, Cree LED Flood lights In Rear Bumper, Burner Bedlights In Bed Cubby's, Avid Light Bar, Horn Relocation Mod, Rear TSB Springs, Bilstein 5100's on all four corners - front set at 0.85", Cooper Discoverer ATP - 265-75R/16, Pioneer AVH-X3700BHS Head Unit With Microbypass, Added USB Charging Ports Under Dash.
    For the illumination and dimmer, it should be the solid green and the green/white stripe. Those two wires are the same as when installing the illuminated 4x4 switch and tapping into the AC wiring harness. Maybe someone else can verify this as I'm not an electrical genius, but i'm pretty sure that's it....
  3. Sep 26, 2011 at 12:17 PM
    Tunngavik
    Alberta, Canada
    Thanks man :) - does anyone else have any info they could provide?
  4. Sep 27, 2011 at 6:21 AM
    Tunngavik
    Alberta, Canada
    Thanks CVERNEAU and caribe - I'll try it tonight!
