Which Bili's fit my truck
Discussion in 'Suspension' started by david7268, Dec 3, 2009.
  1. Dec 3, 2009 at 4:47 PM
    david7268
    david7268 [OP] Well-Known Member
    Tucson, AZ
    2012 DCLB 4x4 TRDSport
    NONE.....yet!
    I was going to install Bilstein 5100s on all four corners of my truck. I have seen several sellers list them as good for 1.5" to 2" inches of lift in the rear. My truck is lifted 3" in the rear. Anyone know the model number of any that would fit?:confused:
  2. Dec 3, 2009 at 4:55 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    they wont give lift in the rear only aal do that. oh i see you have a 3" lift in the rear, contact downsouthmotor sports and they will work with you on the 5125's and which length to get you! 5100 for the front will work though
    just read your sig and its an 04 idk if those work with that
  3. Dec 3, 2009 at 5:16 PM
    david7268
    Tucson, AZ
    NONE.....yet!
    Thanks........I will call Downsouth. I just didn't know if they made 5100s that would fit my truck specs.
