Which Brakes would you Choose?
Discussion in 'Performance and Tuning' started by EFalco50, Sep 17, 2013.
  1. Sep 17, 2013 at 8:49 AM
    EFalco50
    EFalco50 [OP] Woah! How did that get here?
    Ethan
    Corpus Christi
    2012 Single Cab 4x4
    Weather Tech Floor liners, AFE drop in air filter, BFG All Terrain's, Fog lights, Reese Hitch, Undercoating/Rustproofing,
    I'm thinking, stick to all factory.
    What would you choose?
  2. Sep 17, 2013 at 8:50 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I hated the factory brakes and refused to buy them again. I went with Autozone Duralast pads and rotors and was happy with the results.
  3. Sep 17, 2013 at 8:52 AM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC MidTravel TRD Supercharger URD 2.2 and 7th
    I like my brembo oe replacement rotors and hawk lts pads.
  4. Sep 17, 2013 at 11:50 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    ran that combo before......... decent
    Now Im running
    EBC stage 5 kit with braided lines..... much better stopping, minimal wind noise
  5. Sep 17, 2013 at 1:07 PM
    EFalco50
    Ethan
    Corpus Christi
    2012 Single Cab 4x4
    Mines just a Standard cab and the brakes are kinda wack, since I but the big tires it brakes terrible, I was thinking when I need to change them I would go with something better than factory.
  6. Sep 17, 2013 at 1:17 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    thats the nature of these trucks.
    Look into disabling the ABS (killswitch) if ur comfortable braking on ur own depending on road conditions. It will make stops much shorter without ABS usually. I never had ABS before this truck, and have grown to hate the over active ABS system on these tacomas.
    Truck now has the stage 5 I posted about, the braided lines, and an ABS killswitch. Stopping is much better, theres no ABS activation when coming down a curving freeway exit (it seriously happens when ABS is enabled, and makes stopping unpredictable and dangerous even in dry weather).
    OEM iirc is ceramic which provides less dusting, less noise, and I think longer lasting pad life. (statistically)
    BUUUUUUUUT, initial bite usually sucks.... I dont know about you, but I dont drag my brakes, and dont see a way to pre warm them before an accident.
    Ive had zero issues with the two aftermarket setups so far (brembo/hawk, or EBC). dusting hasnt appeared to be any different, and I have no noise upon braking, great pad life, no pulsing, and minimal wind noise from the slots.
  7. Sep 17, 2013 at 1:53 PM
    EFalco50
    Ethan
    Corpus Christi
    2012 Single Cab 4x4
    Could you recommend a good link to the brakes your mentioning? Ive always heard of EBC and Brembo but ive never seen them at any stores.
  8. Sep 17, 2013 at 2:44 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I got mine through 4wp, but before that I was gunna order through here
    http://ebcrotors.com/c-82-ebc-brake-kits.aspx
    braided lines came from tirerack
  9. Sep 17, 2013 at 3:04 PM
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    2011 DC 4X4 TRD Sport
    RCD Lift, Custon Alcan Leafs, Ballistic Jesters, Duratracs 285/70/17,Fold-a-Cover Elite G4 Tonneau, Black Grill Emblem, Sock Monkey Yeti Decals, Tundra 4x4 emblem sprayed black, Debadged, LED interior, Xenon Depot 6000K HID Headlights, Xenon Depot 3000k Fogs with Lamin-X Coating, Borla Exhaust - Chopped, Weathertecs, Custom Katzkin Leather TRD Interior.
    Centric Rotors and EBC Yellow Pads. Great Improvement over stock.
  10. Sep 17, 2013 at 4:01 PM
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    My favorite setup has been from Hawk LTS pads and Hawk Rotors. I had great results with PowerSlot Slotted rotors and Hawk LTS & Hawk SD pads as well as cheaper PowerSTOP rotors.
    EBC makes high quality equipment as well. I would use their YellowStuff or 7000series GreenStuff pads and USR rotors.
    Stay away from drilled or dimpled rotors, but slotted rotors are great for trucks as they will prevent pad material buildup on the rotor face which leads to that nasty vibration a lot of us have had.
    Give TAP Auto a call and they will get you setup. 702.979.1577
  11. Sep 17, 2013 at 4:03 PM
    bubba353z
    bubba353z Titles? We don't need no stinkin' titles.
    Columbus, Oh
    12 TRD Sport AC 4x4
    +1
  12. Sep 19, 2013 at 10:15 AM
    EFalco50
    Ethan
    Corpus Christi
    2012 Single Cab 4x4
    Sweet suggestions yall!
  13. Sep 19, 2013 at 12:18 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I know drilled crack, what's wrong with dimple tho?
    Just curious
  14. Sep 19, 2013 at 12:39 PM
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    Nothing wrong with them. The issue is you are removing surface area of where the pads could b making contact with the rotor. We are not driving these trucks on a race track where heat and degassing of pads are an issue
  15. Sep 20, 2013 at 12:32 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    we dont all drive the same, but Ill take your suggestion.
    I do have some canyons nearby, and I do drive the truck fairly hard.... hence the mods.
    Ill see if any issues come up from these rotors over the long haul and re-evaluate my decision.
