Which CAI?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Jul 23, 2017.
  1. Jul 23, 2017 at 8:05 AM
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Had to remove my passenger inner fender liner, which leaves the stock intake hole very exposed to the elements, thus I would like to swap to a CAI maybe even just a high flow and block the old hole off.
    I don't care about power gains really, this is more to prevent water/dirt/mud from getting in.
    What are you guys running for a CAI?
  2. Jul 23, 2017 at 8:16 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    I run the aFe Power CAI, but it uses the same hole in the fender. I also added their front intake scoop but if you blocked off the fender hole I'm not sure the scoop would be enough on its own. Plan B would be to use a snorkel or reconfigure the air intake port someway.
  3. Jul 23, 2017 at 8:25 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Your stock intake is a cold air intake.
    Aftermarket Cai will also use the same hole.
    Mully and harrycary like this.
  4. Jul 23, 2017 at 8:28 AM
    Gettin Lost
    Gettin Lost Backwoods Rated
    Florida
    2021 TRDOR
    KDMax tune, eibach stage 2, ceramic tint, DD SS3 PRO fogs. Toyo AT3 285s
    Love my S&B cai. I chose it because i didn't want any dirt, sand, mud getting in my filter... Works and sounds great...
    I use the scoop attachment that goes towards the passenger side headlight and grille. It comes with the cai... But it also comes with a plug in case you don't want to use the scoop.
    Any pics from when you removed the fender liner? Curious how exposed the intake hole is. But the S&B also has an intake hole on the fender side as well so I'm not sure....
  5. Jul 23, 2017 at 8:45 AM
    su.b.rat
    su.b.rat broken truck
    the TRD one uses that fender inlet exclusively so it keeps warm bay air totally out. the air on the outside of the fender is preferred, but since you don't care about any performance stuff just decide where you want your air to come from. i want mine from outside the bay, so I'm using the TRD CAI. i actually got it just for extra sound to help guide my shifting.
    poopshute and Mully like this.
  6. Jul 23, 2017 at 9:08 AM
    rewted
    rewted Well-Known Member
    2017 Black TRD Off-Road Double Cab Short Bed
    Warn Zeon 10-S, BFG KO2 265/75/16, Bakflip MX4, Split Dual Battery System, TRD Pro Grille, Tokonsha P3 Brake Controller, ScanGauge II
    There is no reason to get a CAI for a truck like this. Intake Air temp is only slightly above ambient usually. This is measured with ScanGauge.
    And I feel that you reduce water resistance by changing away from stock or increase water resistance by putting a snorkel on it.
  7. Jul 23, 2017 at 9:19 AM
    su.b.rat
    like i mentioned above, i got it for an extra bit of intake sound to help guide my shifts in a MT. that's a reason right there.
  8. Jul 23, 2017 at 10:20 AM
    Gettin Lost
    Florida
    2021 TRDOR
    I like the extra sound as well but also like the improved throttle response. It's only really noticeable when I'm at WOT, flooring it to pass or from a dead stop. But then it shines.
    poopshute likes this.
  9. Jul 23, 2017 at 10:23 AM
    MESO
    State of Jefferson
    Ok, CAI is not what I'm looking for then. I want to block off the OEM fender hole. Maybe a K&N short ram style would be best..
    This is what I am trying to eliminate:
  10. Jul 23, 2017 at 10:27 AM
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    K&N is your best bet.
    MESO[OP] likes this.
