Which came first, the lift or the skids?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ZIB, May 14, 2015.
  1. May 14, 2015 at 10:25 AM
    ZIB
    ZIB [OP] Well-Known Member
    Zach
    Rhode Island
    2014 TRD DCLB Sport
    Pelfreybilt front bumper steel full hoops Warn Zeon 10s winch Caliraised 20" slim light bar and amber 18w pods TRD exhaust Century High-C topper Stubs Welding SKO sliders Pelfreybilt Skids King 2.5 RR extended travel coil over with 650 springs and King 2.5 RR rear shocks Dakar leaf pack Total Chaos UCA BFG KO2 265/70/17 Cobra 75 wx st CB w/ 4' Firestik FS Rotopax 4 gallon gas can
    Looking for some insight on what would be a good/recommended next step for mods on my 2014 DCLB . I'm not sure the best way to go, skid plates or a lift. I'm thinking if I go skids most likely going with Pelfreybilt and OME 885/Dakar for a lift. Sadly will only be able to do it one step at a time. So far my offroading has resulted in a dented factory skid and ding on the 3rd crossmember, thankfully didn't take out the exhaust! Mild Moab and mountains, but hopefully lots more soon! Thanks for the help
  2. May 14, 2015 at 10:26 AM
    ZIB
    Zach
    Rhode Island
    2014 TRD DCLB Sport
    This is also my first post, so if there is another thread that covers this, send it my way. Thanks!
  3. May 14, 2015 at 10:35 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Lift first. The stock setup can't handle the extra weight you would be adding. This is assuming you are going full skids.
  4. May 14, 2015 at 10:38 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    I went
    Tires (265s, so no rubbing even on stock) > Lift > Skids & Sliders
  5. May 14, 2015 at 10:42 AM
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    Get the lift first ground clearance is your best friend
  6. May 14, 2015 at 10:51 AM
    ZIB
    Zach
    Rhode Island
    2014 TRD DCLB Sport
    would be going full skids, already have sliders, they were an easy sell to the wife so she had a solid step!
  7. May 14, 2015 at 10:51 AM
    frizbal
    frizbal Well-Known Member
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    I would say sliders/skids first! You've already witnessed some dents and damage. Some of that can be pretty severe. Besides, you are still going to need the skids after your lift. People ride stock all the time, but they have protection. Suspension component wears out a year or two later due to weight of armor... big deal. You've had time to save by then anyway.
    Don't count on stock skids. You can take em off, put them between two crates and bend them by stepping on them. Your truck is going to exert MUCH more force than that. And since it seems like you obviously offroad, you are going to want to protect your goods.
    Longboard1110 likes this.
  8. May 14, 2015 at 11:00 AM
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    If you already have sliders then I would defiantly say lift I'm in the same boat and I got my long travel kit on order and sliders I'm going to custom make to my liking as soon as I put the lift on I have a fat dent under the door from resting my truck on a rock
  9. May 14, 2015 at 11:02 AM
    Lostsheep
    Lostsheep Well-Known Member
    NorCal
    2015 6spd 4x4 OR
    6112s and 5160 , Dakars , Superbumps x4 , u-bolt flip , All Pro Skids (hacked and raised) , 265/70R17 KO2s, SEMA wheels, couple of machined things here and there
    If you are asking this question, I assume you do not already wheel a whole lot. Therefore I vote skids and learn to wheel your truck in its stock configuration. This way you will protect your investment and learn what you need and why. Just my $.02
    ZIB[OP] likes this.
  10. May 14, 2015 at 11:47 AM
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    I did a lift first, and I still don't have skids only sliders.
  11. May 14, 2015 at 11:48 AM
    Iggy
    Northern CA
    Check out the build
    You can also go with aluminum skids to save weight on the stock suspension.
  12. May 14, 2015 at 12:31 PM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    I did sliders first. In the NM mountains, a couple inches lift won't make a difference in the rock gardens. You're gonna scrape something. So far the stock TRD skid plate has held up (the steel one, not the tinfoil bling add-on). I could probably use more protection underneath but haven't decided what/which/how.
    Around Moab the ledges seem to be what bites stock trucks first. Approach angle and short wheelbase is more helpful than ground clearance. A Taco is just too long for some of the gnarlier trails in the area, built or not.
    For me the next step is a winch and Al bumper. Then I'll lift the truck.
    ZIB[OP] likes this.
  13. May 14, 2015 at 6:16 PM
    ZIB
    Zach
    Rhode Island
    2014 TRD DCLB Sport
    Why do you say the stock setup can't handle the extra weight? Looking at a full set of skids is adding no more then 140-150lbs. Due to drop in clearance or wear out the stock suspension quickly. Thanks
  14. May 14, 2015 at 6:28 PM
    TacoChica
    TacoChica Member
    Since you already have sliders, I'd say lift first/larger tires for most of the trails in Utah that I've been on, including Moab. Added ground clearance is key, and knowing your limitations/weak points. I'd also check out the All-Pro skids. They seem to contour the truck well for the most amount of clearance.
  15. May 14, 2015 at 7:58 PM
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    Lift and tires, then skids. At least at 46, I don't want to have to scrunch around under the truck more than I have to. The extra clearance makes installation a whole lot easier.
  16. May 14, 2015 at 8:00 PM
    ZIB
    Zach
    Rhode Island
    2014 TRD DCLB Sport
    DCLB defiantly puts limitations to some of the trails approaches I'll be able to make. A trip to NM is in the works, I may have to pick you brain on some areas to check out!
  17. May 14, 2015 at 8:10 PM
    frizbal
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    I still say skids. Stock suspension will handle enough. I'd rather squash my springs then smash my dif or tcase. Sure, some may sat gear angles suffer with extra weight. A lift Is going to do the same, just opposite . It really comes down to how you wheel and what protection you want. You are already denting oem skids. So either pick a better line or get armor that will take the abuse. I have a taco leveled out where I am more careful on my lines, and a 4" lifted wrangler w/35" tires where I Hellen Keller it. Depends what your intentions and style are/is off-road
  18. May 15, 2015 at 2:34 AM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    Lift first, then skids.
  19. May 15, 2015 at 3:00 AM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Lift for the clearance.
  20. May 15, 2015 at 8:00 AM
    Pigpen
    Dan
    Northwest Montana
    Get some daylight unda that mutha
