Which Catalytic Converter?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Johnny G, Jun 26, 2025 at 4:15 PM.
  1. Jun 26, 2025 at 4:15 PM
    Johnny G
    Johnny G [OP] Member
    2003 Tacoma PreRunner 2.7 Automatic
    2003 Pre-Runner, 2.7L, Auto, 295,000 miles
    Got a CEL, scan showed P0420, catalytic converter. I tried CataClean in the gas, but it worked as well as I expected. As in, didn't work (you can't blame me for trying). Not wanting to play diagnoses-by-part-replacement, I'm wondering if any of you, particularly techs, have had this issue, and which converter was it? Looking for consensus :)
    Thanks!
  2. Jun 26, 2025 at 4:19 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Did you verify it isn't a sensor failure? Pre CAT exhaust leaks can also cause that code.
  3. Jun 26, 2025 at 4:31 PM
    Johnny G
    Well, the upstream O2 sensor isn't too old. I have no indication of an exhaust leak. I did have a bad misfire for a few days (only on hot starts - weird) before I got the injectors rebuilt, and that makes me think that might have been the final nail in the coffin for the cat...
  4. Jun 26, 2025 at 4:43 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Just saying, no use in throwing a new cat at it if there are other, cheaper causes. And not sure what your reference to the upstream sensor has to do with this.
  5. Jun 26, 2025 at 4:46 PM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    yup, but what do I know...
  6. Jun 26, 2025 at 5:15 PM
    02hilux
    Planet: EARTH
    Take it off and checked the comb? Majority of the issue is exhaust leak as stated
    I tagged you
  7. Jun 26, 2025 at 6:17 PM
    Johnny G
    What sensor were you referring to earlier?
  8. Jun 26, 2025 at 7:34 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The p0420 code is coming from the downstream O2 sensor. The one after the CAT. Either that sensor has failed or is failing to report good info to the truck's ECU.
  9. Jun 26, 2025 at 7:36 PM
    Johnny G
    Yeah, okay, makes sense. Wonder when I replaced that last...
  10. Jun 26, 2025 at 8:11 PM
    slater
    San Diego
    bad info....
    either 02 sensor can fail, the front 02 or the rear cat monitor sensor....
    the front 02 sensors switches rapidly....
    If the rear cat monitor sensor switches rapidly too, that indicates the front or both cats are bad.
    The cat monitor sensor is suppose to be a more steady voltage signal than the front sensor when everything is operating as it should.
    Ive never seen an exhaust leak cause a p0420, regardless what "the book" might say.....
    Atleast not on any ford, & the trucks are notorious for exhaust leaks....
  11. Jun 26, 2025 at 8:24 PM
    Johnny G
    So, summing up what you said here, I have a bad cat, if not both.
  12. Jun 26, 2025 at 8:38 PM
    slater
    San Diego
    im not a toyota tech.....
    Never touched one....
    But been an engine, exhaust, drivability, performance, tech for ford for 32 years...
    The system operates the same...
    I diagnose bad cats, its what I do....
    If Toyotas are one off & the very slightest exhaust leak will cause a p0420 or p0430, I wouldnt know...
    Open your hood & have someone cold start it & power brake it while its cold while you have your ears under the hood & in the fender well......
    If you dont here a tick tick tick that sounds like an exhaust leak....
    You truly eliminated the possible exh leak.
    You want to parts cannon 2 new sensors at it to kick the can down the road, so be it...
    Guys on these forums feel a slight misfire wont cause a cat to go bad, as they continue to drive their trucks while it runs like shit...
    Where I come from, we diagnose bad cats looking at all the appropriate data, you dont have that luxury...
    02 & cat monitor sensor voltage switching
    cat converter 02% saturation
    fuel trims
    etc, etc...
    Dm93 likes this.
  13. Jun 26, 2025 at 9:17 PM
    Glamisman
    Glamisman Well-Known Member
    Eliminate all exhaust leaks first. The cheapest way is to take a shop vacuum and put the hose on the exhaust port of the vacuum and tape/seal it to the exhaust pipe on the truck then crawl under the truck with some bubble making mixture in a spray bottle... any leak, even a little one will make lots of bubbles.
    There is also a work around if it is the cat... you modify the wiring going from the rear O2 sensor with a few dollars of electrical bits. This is a emmission defeat modification and if caught, big time fines. Somewhere in this forum is the post.
    ControlCar and Dalandser like this.
  14. Jun 26, 2025 at 9:23 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If you have more than one cat only the upstream one is monitored.
    95% of the time P0420/430 is a cat that is no longer functioning as it should.
    IMO it's a 22 year old truck with nearly 300k on it, if your not in an emissions testing area and the converter isn't plugged stick a spacer under the downstream O2 sensor and run it or live with the light.
    Dalandser likes this.
  15. Jun 27, 2025 at 1:20 PM
    Johnny G
    That's the issue - I'm in CA, the king of emissions testing. I'm going to have to do the work, just trying to get the best idea for what needs to be done.
  16. Jun 27, 2025 at 1:32 PM
    slater
    San Diego
    Im in San Diego...
    Seen many vehicles with an anti fouler installed at the sensor to get light to stay off pass the sniff test regardless that the cat is no longer "efficient"
    The truck will still burn clean as long as its not doing something stupid like burning a bunch of oil....
    ControlCar likes this.
  17. Jun 27, 2025 at 2:39 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
  18. Jun 27, 2025 at 2:59 PM
    slater
    San Diego
    :frusty:
    Scotty Kilmer is an idiot....
  19. Jun 27, 2025 at 3:01 PM
    slater
    San Diego
    Scotty is an idiot....
    The OP already tried some snake-oil already which im sure has lacquer thinner in it which is suggested in the video you posted.
    The OP stated, that didnt work....
    ControlCar[QUOTED] likes this.
  20. Jun 27, 2025 at 3:48 PM
    Moonrman
    Moonrman Fix it and it will run
    Hill Country, TX
    2001 Dbl_Cab Prerunner TRD
    I'll vouch for the exhaust leaks at first sensor or in between first and 2nd sensor will cause a P0420 code. Lived it and fixed it with a weld.
