Which cell phone holder are you using?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by captainsloose, Sep 27, 2016.
  1. Jun 4, 2018 at 7:40 PM
    #221
    SpaceTrim
    SpaceTrim Well-Known Member
    SD
    1998, 2011, 2015, 2018 Tacoma DCSB OR MT
  2. Jul 13, 2018 at 11:57 AM
    #222
    rkjunior
    rkjunior Active Member
    Which Magic Mount mounts to the ball? All the ones I find are opposite with the ball on the mount itself.
  3. Jul 20, 2018 at 10:54 PM
    #223
    devildoggunner
    devildoggunner Member
    Mark
    Maricopa, AZ
    2014 and 2017 Double Cab 4x4
    Did you ever get this installed the way you wanted? How'd it work out?
  4. Jul 22, 2018 at 7:28 PM
    #224
    mtnhnt
    mtnhnt Member
    Anyone ever drill a small hole in the dash and use a simple Ram mount like this? You could drill into the trim, which is ~$60 to replace if you felt you needed to replace it if you decided you didnt like it. Or I was thinking in the small gap to the upper right of the vent. But that specific part doesnt seem to come alone if you removed the mount and didnt want a hole. I probably wouldnt hang a tablet off it, but for a phone I dont think there would be an issue. Thoughts?
    WCTRDTaco likes this.
  5. Sep 14, 2018 at 5:29 PM
    #225
    VersaTrax
    VersaTrax Well-Known Member Vendor
    Nicholas
    2019 Toyota Tacoma
    When will your mounts be available?
  6. Sep 15, 2018 at 7:40 AM
    #226
    GoGoGadget
    GoGoGadget Well-Known Member
    2017 DCLB OR
    Unless you use some good size washer to distribute the force, I imagine the weight of the phone and wibrations would crack the plastic or start ovaling the hole out causing it to wobble.
  7. Sep 22, 2018 at 7:32 PM
    #227
    Zeezrom
    Zeezrom New Member
    2018 Magnetic Gray Metallic Tacoma TRD Off-Road
  8. Sep 24, 2018 at 7:41 AM
    #228
    peppinoss
    peppinoss Well-Known Member
    Los Angeles
    2016 TRD OR 4x4
    ToyTec Boss 2.0 lift TRD Pro Wheels 265/70/R17 KO2s Mobtown Offroad Sliders
    How did you mount the magnetic thing to the hondo plate?
  9. Feb 25, 2022 at 8:27 AM
    #229
    saajanpatel1
    saajanpatel1 Well-Known Member
    Saaj
    MA
    2022 Tacoma Limited
    None
    Is there any option for phone holder besides magnetic ones or ones that need that track mounted on top? I wish someone figured out a way to do a vent mount with these circular vents. I see cup holder ones but it takes up too much space.
  10. Feb 25, 2022 at 8:30 AM
    #230
    su.b.rat
    su.b.rat broken truck
    that's what the Hondo mount is all about, unless i'm not understanding..
    https://hondogarage.com/products/toyota-tacoma-phone-mounting-system
    jobo2718 likes this.
  11. Feb 25, 2022 at 8:52 AM
    #231
    NinGee87
    NinGee87 Well-Known Member
    AZ
    19 Cement DCSB TRD Sport 4x4
    I have the hondo mount as well that goes into the vent ring area. Works with the meso chrome delete for the vents as well.
    I tried the magic mount ones, and they would allow the phone to shake or sometimes fall off when I was off road or going over a pothole. This hondo mount has been amazing.
  12. Feb 25, 2022 at 8:55 AM
    #232
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    The Hondo garage mount combined with the RAM x-grip. Still working great after 3 years and multiple phones.
    EagleUSMCRet likes this.
  13. Feb 25, 2022 at 8:57 AM
    #233
    DrSouthpaw
    DrSouthpaw Dog limo
    Spur
    AZ
    2017 MGM TRD OR 4x4 DCSB
    RAM has MagSafe compatible mounts for iPhones but I’d like to have a non-charger insert for it. Does anyone have any ideas for a magnet that would fit? I think my only option is to purchase another MagSafe charging cable and cut the cord.
  14. Feb 25, 2022 at 11:58 AM
    #234
    saajanpatel1
    Saaj
    MA
    2022 Tacoma Limited
    None
    *sigh*.. someone hide the credit card bill when it comes in my wife is going to flip when she finds out i spent $150 on a phone mount lol
  15. Feb 25, 2022 at 12:37 PM
    #235
    Rick4657
    Rick4657 Well-Known Member
    Rick
    Iowa
    2019 Red TRD OR
  16. Feb 25, 2022 at 2:25 PM
    #236
    DrSouthpaw
    DrSouthpaw Dog limo
    Spur
    AZ
  17. Mar 4, 2022 at 4:05 PM
    #237
    saajanpatel1
    Saaj
    MA
    2022 Tacoma Limited
    None
    So i got the Hondo Mount, i installed it and i dont get the hype and i don’t like it much. It is bulky and i had to install it 3 times to make it sturdy. The holder has this wheel to use to tighten after you use the button to get approx size of phone in but it takes 2 hands. I use 2 mounta, this and a windshield mounted iottie on left side of the windshield and that is just place and lock and just takes 2 hands to take off. There werent instructions for the Hondo mount but i youtubed it which isnt bad atleast it has presence in the community. Other thing is tho i am looking for a female ball adapter to replace the arm and mount to something else
  18. Mar 4, 2022 at 4:13 PM
    #238
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
    Ram mount then Hondo Garage now 67D
  19. Mar 5, 2022 at 3:51 AM
    #239
    TRD_Seeds
    TRD_Seeds Well-Known Member
    York, PA
    2019 Cement Tacoma TRD OR
    Went with the Offroam a few months back and couldn't be happier. High quality.
    1Crusader and Seventh like this.
  20. Mar 5, 2022 at 4:42 AM
    #240
    19OR
    19OR Well-Known Member
    Jay
    2019 TRD Off Road Magnetic Gray
    Nitzie has one that’s just a magnet and you just stick a thing round plate to the back of the phone. Most compact Unnoticeable one I’ve ever seen. Works with probably any case out there. Wireless charging won’t work though unless maybe you offset the plate but it still would make a gap. I have a heavy duty case and it holds it solid.
