Which cell phone holder are you using?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by captainsloose, Sep 27, 2016.
  1. Mar 5, 2022 at 4:45 AM
    #241
    19OR
    19OR Well-Known Member
    Jay
    2019 TRD Off Road Magnetic Gray
    I had a iottie for a while worked great.
  2. Mar 5, 2022 at 4:56 AM
    #242
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    quad lock on a RAM arm setup
  3. Mar 5, 2022 at 5:01 AM
    #243
    EagleUSMCRet
    EagleUSMCRet Well-Known Member
    Gettysburg, PA
    2017 MGM 4x4 Tacoma DC Limited
    ESR Magnetic Mount MAGSafe charger for iPhone; AVS Vent Visors; Replaced Entune system with Kenwood Excelon Head unit, The Taco Garage DMM for Qi charger, Owl Dash Cam and Motorola GMRS; LED interior light upgrades, ARE Z Cap w/ Yakima Rack, Front Bed Rail, Bed Rug, Tuffy Bed Lock Box, Add a leaf, Pop and Lock, Blendmount and mirror tap for radar detector, AVS Hoodflector, Redline Hood Gas Spring mod. A/C drain mod, X2 Power Premium 27M battery, Debadged the tailgate, Compustar remote start, USB charger for the rear seats, Husky Mats, Lexus Credit Card Transponder Fob, MAG Light mount, twin Hella Sharptone horns, Bedslide, Gasshole, Meso Fuze cover, TRD Gas cap cover, Passenger side locking door handle, Mr. Produxn license place mount, Total Chaos Bed Stiffeners, Valley Runner Tune....help me I can't stop!!!
    This is what I use in my Tacoma and wife’s car… with the Spigen Magsafe case, also on Amazon… it is solid… strong enough magnet.. unless you are wheeling…. https://www.amazon.com/ESR-HaloLock-Magnetic-Attachment-Alignment/dp/B08HNBHSQV?crid=21IRAR5AM908M&keywords=esr+magsafe+car+mount&qid=1646485008&sprefix=ESR+%2Caps%2C91&sr=8-1-spons&smid=A3BBGHDKUKWCAL
    Additionally, I got a 25mm to 17mm dual ball adapter from Ram and mounted it on my DMM… a more simple way would be to use the vent mount. works for me, but for world peace, the wife likes it. Hope this helps.
    Seventh likes this.
  4. Mar 5, 2022 at 5:15 AM
    #244
    hfjeff
    hfjeff Well-Known Member
    Frozen Tundra
    2021 Army Green Off Road
    A bit pricey combo, but I ordered a DMM from TacoGarge and a Ram mount from Amazon. https://www.amazon.com/RAM-MOUNTS-R...=1646485741&sprefix=ram+mount,aps,158&sr=8-19
    I received the Ram mount and am impressed with the quality and how solid and sturdy it is. The DMM has been shipped and I can't wait to get this installed. I presently have a cheapo vent mount clip on from Amazon and hate it.
  5. Mar 5, 2022 at 6:32 AM
    #245
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    The great folks @CourseMotorsports Course MotorSports sent me an Autogrip Charging Head to try out. About a year and a half ago they sent me one of their early design Magnetic Direct Fit Phone Mounts (shown in the later pictures). It worked great but using the steel plate in the phone case eliminated Qi charging and I found that because of the size of my iPhone and wanting to orient it horizontally, the phone would droop to one side from road vibration. Course has since created mounts for numerous vehicle types and manufacturers and have mounts for Tundras and Sequoias, too. They’ve added Magnetic Charging Heads to the line-up, as well. I’m going to hard-wire this one in the coming days and replace the magnetic head. More to come!
    275206219_10223697076509689_5224273683323892983_n.jpg 275227454_10223697076469688_5922491461010238975_n.jpg
    These are pics of the original magnetic mount.
  6. Mar 6, 2022 at 8:05 AM
    #246
    scottdogster
    scottdogster Well-Known Member
    Folsom, CA
    2019 Tacoma TRD Pro
    PNWTacoma and su.b.rat like this.
  7. Mar 6, 2022 at 11:48 AM
    #247
    scottdogster
    Folsom, CA
    2019 Tacoma TRD Pro
    Here’s a picture
    PNWTacoma and EagleUSMCRet like this.
  8. Mar 10, 2022 at 4:16 PM
    #248
    Devious6
    Mark
    I put the new Course Motorsports Autogrip Charging Head onto the original mount I've been using. The original set-up was a non-charging magnetic head. I loved the fit but using the steel plate in the phone case eliminated Qi charging. And, I prefer to place my phone - an iPhone Xs Max - horizontally on the mount and it would always droop to one side or the other. This was the original mount kit.
    Since making the original Course Motorsports has greatly expanded their line, added charging magnetic heads and also this powered Autogrip mount.
    Once powered the wings close down on the phone automatically when you set it into the mount. To remove the phone, you just touch one of the lighted buttons on either side of the mount (or top/bottom, depending on orientation).
    I need to give it a better road test - will do that on Friday when I have to run some errands. I am also in the process of hard-wiring the mount instead of using the included adapter in the power outlet on the dash. All in all, though, I am really happy with the unit - always loved the low-profile mount that attaches to the upper left screw of the infotainment system. It holds my phone securely and doesn't droop. Looks like a winner especially if you have a larger profile phone. As you can see, the phone is charging through my Otterbox case
    When I originally inquired about the mount at Course Motorsports, they did tell me that some users have indicated an issue where they have to angle the mount up to keep the motor housing from hitting the dash surround. They will be making an offset but they sent me the details and I secured a 7/16" hex offset that works perfectly. You can see it attached to the mount in the second picture.
    1Crusader likes this.
  9. Mar 10, 2022 at 5:48 PM
    #249
    Tw85
    Tw85 Active Member
    2017 MGM DCSB TRD OR 4x4 6spd w/P&T
    I have something like that too, works well and leaves no residue.
  10. Mar 10, 2022 at 7:08 PM
    #250
    BTH1
    BTH1 Active Member
    Bill
    Ocala Fl.
    2022 SR5 4x4
    TRD dealer installed lift
    Pro clip use it in all my vehicles
  11. Mar 16, 2022 at 7:32 PM
    #251
    rdgm71
    rdgm71 Well-Known Member
    Richard
    Florida
    2018 Black Toyota Tacoma OR Double Cab Short Bed 2WD
  12. Mar 16, 2022 at 10:39 PM
    #252
    Absolut_Boost
    Absolut_Boost Well-Known Member
    Cincinnati, OH
    2021 Tacoma TRD OR DCSB Cement
    venezian likes this.
  13. Mar 17, 2022 at 9:03 AM
    #253
    scottdogster
    Folsom, CA
    2019 Tacoma TRD Pro
    That Taco Garage DMM is pretty cool, just watched the install video, I like that it is practically invisible. Thanks!
  14. Mar 17, 2022 at 10:23 AM
    #254
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    My phone stays in my pocket while i'm driving.
  15. Mar 17, 2022 at 10:30 AM
    #255
    vanrynd
    vanrynd Well-Known Member
    dan
    West Chester, Pa
    2017 Off Road DCLB
    WIP
  16. Mar 24, 2022 at 7:26 AM
    #256
    bilplat
    bilplat Simply Driving Into Mordor
    Bill
    Denver, CO
    '17 White A/T 4x4 TRD OR DCSB
    ARE Hard Top
    I went with the Hondo Un-Holey mount, combined with a ram mount, ram arm, and wireless charging head from Quad Lock. The Quad Lock case is on my phone all the time, and I have mounts for it on all my bikes. A little pricey for the whole setup, but I love it.IMG_5198.jpg
    NinGee87 likes this.
  17. Mar 24, 2022 at 8:29 AM
    #257
    JHP
    JHP Well-Known Member
    Heart of the South
    2022 Whilte Tacoma SR 2.7 DCSB
    Towing Package, Bed Mat, Roll-up Tonneau Cover
    Topgo. It sits in a cupholder. I have it in a metal Yeti coozie to lift it up higher. Makes it very easy to take out of the truck when I need to.
  18. Mar 26, 2022 at 8:43 AM
    #258
    TacoCarl303
    TacoCarl303 Well-Known Member
    Following, I've yet to find one that doesn't send my phone flying when offroading :)
  19. Mar 26, 2022 at 8:59 AM
    #259
    cammerv8
    cammerv8 Well-Known Member
    2019 Silver Tacoma Trd Sport DCSB
    Bed inlays stickers
    was using the Scosche magic mount in my old phone ( still have it but not installed), but since i switched to an iPhone 13, so now i use a magsafe mount from amazon.
    that scosche mount is great if you don't use Wireless charging.
    i still cannot understand why is so difficult to find an option that is not Vent or CD mounted. i'm like is either gonna be flimsy or is gonna break my vents. give me suction cups or 3M tape
  20. May 14, 2022 at 9:21 PM
    #260
    Tony382
    Tony382 Well-Known Member
    2022 Tacoma TRD Sport
    I went with a mount from a company called Quarble. I've had it for about a month now. I use an iPhone 13 pro and it's a heavier phone. This magnet is pretty strong and it pivots on a ball, but its pretty solid. I drive a TRD Sport that has pretty stiff suspension and the phone does not fall. I have it placed at a slight angle and the phone does not lose its position. I also found a right angle 12 inch cable for Apple Car play and it stays totally out of the way and doesn't obstruct from reaching whatever beverage I have in the cupholder below it. The only thing it does obstruct is pushing the ECT PWR button when you need to, but even then you just reach your finger behind the phone.
    Dexa likes this.
