Which cell phone holder are you using?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by captainsloose, Sep 27, 2016.
  1. Mar 17, 2023 at 10:48 AM
    #381
    CaptSourPatch
    CaptSourPatch Well-Known Member
    PNW
    2023 Lunar Rock TRD OR
    Stock. For now.
  2. Mar 18, 2023 at 7:41 AM
    #382
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    Cup holder works great for me. Apple CarPlay takes car of the map, Spotify and podcasts as well as answer phone calls and hear text msg so no phone access need there. Actually the Nav screen (I don't have Nav just the screen) is a much better screen (bigger) and in a perfect location than a mounted phone. Siri makes calls (I don't do phone calls while driving but could if I wanted to) and sends txt msg . . . . so what does the the phone mount get you other than being a safety distraction and some of them really make the dash look like crap.
  3. Mar 27, 2023 at 1:55 PM
    #383
    6H05tP3p3
    6H05tP3p3 Well-Known Member
    Kalifornistan
    23 MGM TRD Pro MT
    OTT
    VicNic3 and skidooboy[QUOTED] like this.
  4. Mar 27, 2023 at 5:16 PM
    #384
    RTedder2
    RTedder2 Well-Known Member
    Roger
    Inferno '17 TRD Offroad
  5. Mar 27, 2023 at 5:22 PM
    #385
    Vjustinc
    Vjustinc Talk Nerdy to Me
    City of Angels CA
    2021 Toyota Tacoma (it's white)
    Put in the Taco Garage single mount about a month ago and I have the Arkon phone holder/ball mount combo. Still impressed by it and how its been holding up. At least I see my phone a whole lot better if im using GPS
  6. Jun 28, 2023 at 6:10 AM
    #386
    Big2ny
    Big2ny Member
    Purchased the Tackform Vent Phone Mount (SKU: TFEN-VMA11-UG) for my '23 Tacoma SR5, and it works as advertised. I can position the phone where it won't interfere with the air vent. It doesn't obstruct my view of the of the left side of the control/display screen. And easy to install. The only drawback, no fault of Tackform, is that you can't turn and direct the air from the vent and the vent cannot be fully closed. Mostly closed, not fully.
    Acwood likes this.
  7. Aug 24, 2023 at 12:37 PM
    #387
    tjv504
    tjv504 Taco n00b
    Tom
    NOLA
    2023 Tacoma TRD Sport Lunar Rock
    Pro Grille, TRD skid, Spidertrax 1.25" spacers, Cali Raised cat shields, Seat Jackers, 67Designs Taco Rail, WeatherTech floor mats + bug deflector + side window vent shields, demon (nipple) rings, Hitchhiker's Guide to the Galaxy reference on the tailgate, Tyger tri-fold tonneau cover
    RE; The 67 Designs Taco Rail. How does their proprietary mount clamp on the phone, and how does it release? It is just a spring? Or is there a proper release button? One-hand operation? Thank you!
  8. Aug 24, 2023 at 7:24 PM
    #388
    Phenom3030
    Phenom3030 Well-Known Member
    Jon
    Colorado Springs, CO
    2021 Lunar Rock TRD Pro
    OEM+
    Offroam mount. Love it, it’s sturdy and holds the phone well. IMG_0014.jpgIMG_0013.jpg
    Fitz235 and Dark_Taco like this.
  9. Aug 24, 2023 at 7:29 PM
    #389
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    I like Offroam too. Have one in the Tacoma and one in the 4Runner.
    Phenom3030[QUOTED] likes this.
  10. Aug 25, 2023 at 5:26 PM
    #390
    Big2ny
    Big2ny Member
    #tjv504
    Adding to my previous post of the Tackform TFEN-VMA11-UG. Checkout their web site.
    https://www.tackform.com/products/vent-phone-mount-16-22-toyota-tacoma-14-21-toyota-tundra
    Pic 1 - Once installed, it needs to stay. It came with an install kit, had to use a set screw. Make sure you place the vent the way you want before installing the mount base.
    Pic 2 - I have a Samsung S21, with an Otterbox cover. It sits high enough where it doesn't block the vent, and you can see the display console and controls. Phone is easy to take out and put in. It's really hard to knock or bump the phone out, good grip and easy to adjust.
    Pic 3 - Because of the mount, I can't turn the vent to blow left or right, and it won't close all the way shut. I had to improvise by using a plastic badge cover and clip to direct the flow downward. No problem going wide open.
  11. Aug 25, 2023 at 7:50 PM
    #391
    econwatch
    econwatch Well-Known Member
    Utardia/Kanook Eh
    Naranja 7545
    Hondo Garage.
    Indestructible, very beefy and very easy to use.
    I pull my phone constantly while driving, pics here, grocery getting there, UFO sightings, side mirror shots while getting passed by a GT3 on I-80.
    Close the door, slam the phone in, crank it tight, light the turbines and launch.
    Awesome-sauce.
  12. Sep 18, 2023 at 3:42 AM
    #392
    jdw-
    jdw- New Member
  13. Sep 18, 2023 at 10:53 AM
    #393
    3GTCMLMTD
    3GTCMLMTD Well-Known Member
    2022 Limited
    I got this one for the work truck. It was cheap, so I figured I'd give it a try. You do have to put a magnetic sticker on the case of the phone, but it's not a thick one and doesn't get in the way. Surprisingly, it holds my 14 Pro Max and it's never fallen off. Even on the roughest roads under construction with a lot of huge potholes.
    https://www.amazon.com/dp/B00I608BJ8?ref=ppx_yo2ov_dt_b_product_details
    embedded rock and Wwjvd like this.
  14. Sep 18, 2023 at 10:39 PM
    #394
    axxkicker
    axxkicker Well-Known Member
    brett
    Unbelievably, Alabama
    2018 Tacoma TRD Off Road
    I had a 67 Designs mount in my Wrangler and liked it enough to not bother looking at anything else when I got my Tacoma in '19.
    I have the TacoRail with two mounts- one for the phone, and another for the SPoD controls.
    The Rail is just that- it mounts to the top of the radio bezel (using some very tiny bolts) and has been anvil-reliable for 4 years now.
    The arms and balls that make up the adjustable portion of the rail are as tight as you want to turn the knobs. Mine haven't moved in 4 years.
    I use the proprietary phone mount clamp from 67 Designs. It is just a spring-loaded clamp, and one handed loading and unloading are all I do. I am careful with it, because I'm wary of the small bolts, but it hasn't moved and works perfectly on my Iphone Pro with a modest protective case.
    Hope this helps!
    tjv504[QUOTED] likes this.
  15. Sep 19, 2023 at 8:07 AM
    #395
    Wwjvd
    Wwjvd Well-Known Member
    Jimmy
    2022 TRD Off-road 4wd
    Cheap, effective, universal. I use these in all my trucks, even one in the boat.
    3GTCMLMTD[QUOTED] likes this.
  16. Sep 19, 2023 at 8:24 AM
    #396
    Raptr117
    Raptr117 TacoRaptr
    Hickory
    2023 Tacoma TRD Off-Road
    Because I got a 23, I have CarPlay, so I actually re-routed the cable underneath the cupholders and into the center console, that way I can put my phone in my tray organizer and keep it out of sight and out of mind, which is also a little bit of a PITA if I need to pull my phone out for whatever reason, but that's what I'm trying to avoid.
    9pm likes this.
  17. Oct 8, 2023 at 9:10 PM
    #397
    axxkicker
    brett
    Thought I'd share some photos of the 67designs tacorail for you. Again, it's been absolutely rock-solid and I can't recommend them enough.
  18. Nov 4, 2024 at 2:52 PM
    #398
    sde_az
    sde_az Member
    Steven
    2019 Tacoma Sport 4X4 Extended Cab
  19. Nov 4, 2024 at 2:55 PM
    #399
    sde_az
    sde_az Member
    Steven
    I'd caution against the taco rail. It's a solid mount, but scratches the heck out of the phone case...for some reason they put VERY sharp edges on it. Called their support, all they offered was I was out of warranty (admittedly, I took too long installing it. Just wanted to find out if I got a bad one, but they didn't let the conversation get to that).
    Someday, I'll be in a hurry and ruin the camera lens.
  20. Nov 6, 2024 at 10:12 PM
    #400
    axxkicker
    brett
    I did find the edge to be somewhat sharp, so i applied an adhesive foam strip to the gripping jaws of mine. I couldn't tell you where I got it, but it was just on hand. I don't mind that the case gets scratched, as long as it does what the case is supposed to do, which is protect the phone. I just enjoy the rock-solid grippiness of the mount. And if grippiness isn't a word, then it is now.
    Perhaps I'm just deliberate when inserting my phone and don't have any issues. As you have an android, I could see scratching the camera if you aren't careful. The spigen case on my iphone does a better job covering the multiple lenses, I think.
    In any case, good point, and I hope you find a cradle that better suits you.
