Which clutch for 2003 Tacoma 3.4?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Joamkaalatsosa, Mar 30, 2016.
Which clutch would you get?
Poll closed May 22, 2016.
  1. ACT
    0 vote(s)
    0.0%
  2. Marlin
    33.3%
  3. Centerforce
    33.3%
  4. OEM
    33.3%
  5. Luk
    0 vote(s)
    0.0%
  6. Exedy
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Mar 30, 2016 at 5:50 PM
    Joamkaalatsosa
    Joamkaalatsosa [OP] Active Member
    2003 TRD 4x4
    YES, I searched but the threads I found on the subject are all 4-8years old, figured something newer or better might be out since then. I also read Toyota OEM clutch kit's changed something(true or not?). From what I read it seems the Marlin 1600lb clutch or an ACT brand clutch is recommended. I don't do any off-roading just drive the truck to and from work everyday most highway/ 45+mph cruising. If not a Marlin or ACT what do you recommend?
    My clutch isn't bad but my throwing bearing is ridiculously annoying with the squeaking. Are there certain Throwout bearing's I could buy separately that are better than the ones that come with either mentioned clutch kits? TIA
  2. Mar 30, 2016 at 7:49 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    i doubt anything has changed in these years. some people say go oem. others say aisin and luk. just don't go cheap. that should be enough advice
  3. Mar 31, 2016 at 7:05 AM
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    And don't go with Centerforce either....garbage. I can't wait until mine dies and get it out of there.
  4. Mar 31, 2016 at 11:30 AM
    CodeSeven
    Serge.
    Coachella Valley
    whats wrong with yours?
  5. Mar 31, 2016 at 11:31 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I got exedy stage one and it's amazing!!! Feels perfect and handles my sc great
  6. Mar 31, 2016 at 11:38 AM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I've used Centerforce clutch and they were great so I'm curious to know what problems you have as it'd be my first choice now.
  7. Mar 31, 2016 at 1:44 PM
    elnip
    LC,NM
    I had one in my 86 and loved it so when Toyota warrantied my tranny on my 98 I had them change out the clutch to the Centerforce and on the street and with the S/C I have no problems.
    However, the first time I took it into the rocks in 4Lo I slipped into a hole in the rocks to where I had to turn to get out. The clutch slipped repeatedly trying to get the power to the ground. I never had that problem with the 86 clutch and after researching I found out (this was a # of years ago so it may be different now) that the diaphragm pressure plate spring pressure was reduced compared to the 86 to ease pedal effort, hence the slip. I remember reading on TTORA back then that others were having the same issue on their 1st gens. as well.
    Like I said, it may be different now but I still get slippage in that 4Lo situation if I'm not careful and the smell of burnt clutch is not fun.
  8. Mar 31, 2016 at 5:40 PM
    cosmicfires
    David
    Everett, WA
    The Center Force clutch I put in my '78 Toyota had 2 diaphragm springs, it never slipped but the pedal effort was high and I had to re-attach the pedal bracket to the firewall with pop rivets after it started to come off. The one I had in my '82 F250 had one spring and didn't slip. They both had the centrifugal weights. Looks like the problem might be with one designed for reduced pedal effort.
  9. Apr 2, 2016 at 10:32 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Love my marlin clutch!
  10. Apr 2, 2016 at 10:54 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I have a Luk Clutch which will no doubt last as long as no Students to a clutch ever drive the Truck
    75,000 miles now
    My next Toyota that needs a clutch is going to be a Marlin
  11. Apr 3, 2016 at 6:11 AM
    Joamkaalatsosa
    2003 TRD 4x4
    I added a poll, figure there's those out there that don't want to bother with a response but might vote. Anyone know why the 1600lb Marlin clutch isn't available for my 2003? Just the earlier generations
  12. Apr 3, 2016 at 7:01 AM
    Joamkaalatsosa
    2003 TRD 4x4
  13. Apr 3, 2016 at 8:01 AM
    Madjik_Man
    Colorado Front Range
    My OEM clutch is still going strong at 205,000 miles.
    I figure when the time comes to replace it, I'll go with OEM again.
