Which colors have clear coat? How important is it?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tekneek, Jan 13, 2021.
  1. Jan 13, 2021 at 7:54 PM
    #61
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
  2. Jan 14, 2021 at 4:13 AM
    #62
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    i painted cars for years, single stage polyurethane is clear and was put on older cars for years, 2 stage has clear coat, alot of solid colors are single stage, most metallics are 2 stage...base coat then clear coat for 2 stage.
  3. Jan 14, 2021 at 7:38 AM
    #63
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I'm thinking so to, my tundra was a metallic silver that had a very thick paint coat. You could definitely tell it was cleared. This quicksand tacoma when looked at is very thin, plus the service manger for the dealers paint dept. really pushed me into a ceramic coating. So far after 10 months the paint is still looks the same...very shiny, and flawless... no chips. I've never even washed the truck yet let alone did anything else, but let the rain/snow clean it.
    shakerhood[QUOTED] likes this.
  4. Jan 14, 2021 at 8:21 AM
    #64
    mjanmohammad
    mjanmohammad Well-Known Member
    Moe
    Single stage paint is pretty common in older cars. I believe all modern tacomas have a clear coat.
    My 91 Miata was single stage paint and was shiny as hell.
    kgilly likes this.
  5. Jan 14, 2021 at 8:27 AM
    #65
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    That would make sense with everyone having trouble with white
  6. Jan 14, 2021 at 9:13 AM
    #66
    Kairide
    Kairide Well-Known Member
    2020 White SR5
    Ultimately, if no one knew their paint were single stage vs multi-stage;
    • Would you notice? No
    • Would you care? No, because you didn't know
    • Does it make a difference in the quality of the paint job? No
    All vehicle manufacturers will have a subset of failed paint jobs, you can't just say it's due to being a single stage paint job. Look at Tesla, they're the paint failing kings and they are using a multi-stage paint. If having a single stage paint job really bothers anyone, they can always get a clear coat sprayed on.
  7. Jan 14, 2021 at 10:29 AM
    #67
    4BYTOY
    4BYTOY Well-Known Member
    Colorado Front Range
    2018 TRD Off Road
    True True my cement has metallic in it and has a clear coat.
  8. Jan 14, 2021 at 11:02 AM
    #68
    zoo truck
    None
    I've seen enough black or white tacoma over the years. Nether to me look clear coated.
  9. Jan 14, 2021 at 1:58 PM
    #69
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    I will only speak of the 6 times I've painted anything myself. And let the flames begin... BUT...
    Paint ... Nowdays ... Isn't anything close to what it was, or could have been .. 20 years ago. (Lacquer? Good luck on even finding that anymore..)
    The last two rigs I painted, I used Eastwood paint. These are/where basically like an 'epoxy' type paint. Two parts. You had your 'color' (Primer, or actual 'color') and you mixed in the catalyst. You had to shoot the paint in about 20 minutes and then get yer gun cleaned, or you were screwed big time.
    Anyway, you could do it one of two ways.. Just shoot the color (And if you were skillful) turned out awesome. Bright and shiny.
    If you wanted to go the extra step and give it that deep-DEEP 'glass' look, you color-sanded and put on one, maybe two layers of clear coat. I would never ever vote against any kind of clear-coats if you want to go that extra mile. It's just a LOT more work and added cost.
    So, what were 'clear-coats' ... 20 years ago that ended up peeling off and looking like shit ... ain't the same thing as what is offered up these days. (And who knows how much effort/quality is put into factory paint-jobs ... I have no idea. Everything is painted by robots now, and I would assume that ANY mfg is just trying to get by with the least amount of $$ being spent as possible)
  10. Jan 14, 2021 at 2:06 PM
    #70
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    tvr probably has the nicest paint jobs, sure a few painters have died but damn those paint jobs look good
  11. Jan 15, 2021 at 2:28 PM
    #71
    2006whitetacoma
    2006whitetacoma Well-Known Member
    2006 White SR5
    I thought cement was a non metallic, is that lunar rock color they have now metallic at all?
