Which Detroit Trutrac did you get?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marc70, Dec 6, 2019.
  1. Dec 6, 2019 at 9:15 AM
    Marc70
    Marc70 [OP] Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    I contacted Eaton, and here's what they said:
    Eaton Performance (Eaton Performance Support)
    Aug 9, 19:54 ADT
    Hello Marc,
    Thank you for the follow up. We do not currently make a Detroit Truetrac that will fit a 2008 Toyota Tacoma.
    You may want to check with harrop.com.au as they have alternate fitments which are Eaton differentials that are modified to different fitments. They are fully supported and warranted by Harrop.
    Thanks,
    -Eaton Performance Support
    And yet there's some of you fellow TW users who say they've installed and enjoy this product.
    Which did you get?
  2. Dec 6, 2019 at 9:19 AM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
  3. Dec 6, 2019 at 9:20 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
  4. Dec 6, 2019 at 1:29 PM
    Marc70
    Marc70
    Northern Ontario
    Hey @ajohnson, @MattCowsmasher, did you guys have to change your ring gear to add this? Did you end up buying the whole rear install kit, ring and pinion, spacer?
    According to my axle code (A04A), I seem to have an 8" 3.727:1 gear ratio.
    Thanks for the help.
    llamasmurf and MattCowsmasher like this.
  5. Dec 6, 2019 at 2:13 PM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    No I didn’t just the spider gears are replaced not the pinion gears. I did buy outer axle seals and the 3rd member gasket.
    llamasmurf, DG92071 and BassAckwards like this.
  6. Dec 6, 2019 at 2:16 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  7. Dec 6, 2019 at 8:44 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    I have the one that ECGS installed when they did my gears
  8. Dec 7, 2019 at 5:44 AM
    ajohnson
    Andy
    Charlotte, NC
    I bought the trutrac, 4.56 gears, master install kit and solid spacer from ECGS, pulled my diff and had a local guy set it up. You don’t need new gears if you want to keep the stock ratio. If you have higher miles, I recommend the master install kit and replace everything while the diff is out. Solid spacer is only necessary for off-roading.
  9. Jul 22, 2021 at 9:54 PM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    How's that true trac holding up? Thinking about getting one for my prerunner
  10. Jul 23, 2021 at 9:31 AM
    ajohnson
    Andy
    Charlotte, NC
    It is holding up fine, no issues.
