Which Diff is Best for Soft Sand?
Discussion in '1st Gen. Tacomas (1995-2004)' started by MitchMan, May 1, 2010.
  1. May 1, 2010 at 6:01 PM
    MitchMan
    MitchMan [OP] Member
    Which rear differential is best for off roading on soft sand? LSD or Lockers?
    I just bought a used 1998 2.7L 4x4, reg cab, dark red, 129,000 miles, for $5,900. I am thinking of putting either an LSD or Locker on the rear, maybe on the front, too, depends on what I learn from this thread. Also, I have 265/75/R15 on there right now. Seems a bit too big for the truck.
  2. May 1, 2010 at 6:05 PM
    Drewboto
    Drewboto Well-Known Member
    Drew
    Missouri
    Base model ಠ_ಠ
    17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
    My guess would be lockers.
  3. May 1, 2010 at 6:06 PM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    locker ftw....
  4. May 1, 2010 at 8:33 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Keeping your speed up FTW!
    No but really, I would also think a locker would be best combined with low air pressure in the tires.
  5. May 1, 2010 at 10:19 PM
    kumaWRX
    kumaWRX Well-Known Member
    Jase
    Oahu, Hawaii
    04 Prerunner TRD Offroad
    SAW 2.0 Coilovers, Wheeler's 3-leaf AAL, Toytec 1" lift shackles, Bilstein 5100 rear shocks, aFE Stg. 2 intake, Doug Thorley headers, Magnaflow muffler, 16x8 ProComp 7089 wheels, Toyo Open Country A/T tires, Pamalu bedliner, Bakflip G2 bedcover
    Correct me if I'm wrong but isn't a locker better for most all offroad conditions and LSD is better for street? My locker works wonders offroad, can't see an LSD being nearly as useful and vice versa for on road a locker is stupid.
  6. May 1, 2010 at 10:29 PM
    Drewboto
    Drew
    Missouri
    Base model ಠ_ಠ
    Yep, pretty much
  7. May 2, 2010 at 4:57 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    An LSD is better than an open diff.
    I've never wheeled in sand, but I would tend to think.....a locker will get you into trouble (while in sand) - like, digging yourself deeper and deeper into the sand if you come to a stop or slow down.
  8. May 2, 2010 at 5:52 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    Neh. I'm not saying that's impossible because once you're stuck, you're stuck. Either way your going to bury yourself down to your axle and stop. However, more traction will never get you more stuck. The locker will help you not start digging in the first place.
    Yes, a LSD is definitely better than an open diff in all situations where one needs traction to get started though. The only place LSD is better than a locker is on wet/snowy/icy roads. However, if you're the owner of a selectable locker, which most of us are, unless you're a fool, you'd never have your locker engaged on these roads. You'd have it set to open which works just as good a LSD on icy roads (Once you're moving anyway).
  9. May 2, 2010 at 8:42 AM
    Janster
    Jandy
    Lancaster, PA
    Maybe its because I'm used to using lockers on the rocks & hard packed dirt in situations where you can't get the job done with the 4WD and open diff.
    But its hard for me to imagine having 'traction' on a movable surface (such as sand).
    LSD is a 'best of both worlds' for those who daily drive their vehicles in snow/ice AND want to offroad moderately. But for sand? Is a locker truely that beneficial?
  10. May 2, 2010 at 8:51 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    I was thinking the same thing. For hard packed surface the locker will be the best. But for thick soft sand, it seems like it might dig a little. But I have never used a locker so I cant say. Just seems like it would. But keeping your speed up I would say will get you through the most (in sand). :cool:
  11. May 2, 2010 at 8:58 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    If there was no 'traction' on this movable surface, nobody would be able to drive on it at all, yet many, including myself, drive successfully in sand on a regular basis. More tires pushing is always better when accelerating from a stopped position.
  12. May 2, 2010 at 5:39 PM
    Sparky4.0
    Aaron
    WestTexas
    01 trd beat to hell
    i have run lsd front and rear in sand.. open diffs frt. rear. in sand. and full locker frt. rear in sand. and most of the varivbles. the only combination that i have run and never been stuck in sand was locked front and rear. my personal choice in sand is lsd front and rear though. but that just dont suit me for the rest of my offroad use. besides once you go locker you dont go back. but being locked up from a standstill tends to dig more than open or lsd in sugar sand imho.
  13. May 3, 2010 at 9:31 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    On new Tacomas, soft sand is best crossed in H4 with TRAC (LSD front and rear) or on pre-'09 Tacomas (with normal open differentials or LSD) by deflating the tries to 15 psi or less.
    The rear locker only works in L4, and low range will bury you in soft sand unless you deflate your tires... just too much torque, and the trick is to float on the sand without digging in.
