Which E85 kit?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Benny238, Apr 14, 2022.
  1. Apr 14, 2022 at 8:01 AM
    Benny238
    Benny238 [OP] New Member
    2016 tacoma
    Any suggestions on what Injectors to use and what kit should I put on, to make it E85
  2. Apr 14, 2022 at 8:13 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  3. Apr 14, 2022 at 8:35 AM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    Share some of that popcorn please. :drunk:
  4. Apr 14, 2022 at 8:38 AM
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    Don't.
    Don't entertain E85.
    Don't even think about E85.
    This will void even your Car Shield warranty, and Ice T won't save you.
    pltommyo, b_r_o, Aqualoon and 4 others like this.
  5. Apr 14, 2022 at 8:38 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    There, have at it y'all.
  6. Apr 14, 2022 at 8:39 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    @VE7OSR got us covered.
    Now, sit back and hold on for Friday, baby!
    :mudding:
  7. Apr 14, 2022 at 8:40 AM
    1546 Well-Known Member
    I think you have to do Doc Brown's garbage conversion.
    SR-71A, Skydvrr, piratepegleg and 2 others like this.
  8. Apr 14, 2022 at 8:41 AM
    TheCochese
    TheCochese The Bronze T4R OG
    Attempting to flee the south
    Cavalry Blue soccer machine
    Fine corinthian leather
    b_r_o, SR-71A, Skydvrr and 6 others like this.
  9. Apr 14, 2022 at 8:46 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Is Mr Fusion better or worse than Mr E85?
    CaptAmerica likes this.
  10. Apr 14, 2022 at 8:47 AM
    Bout the same but it causes gear hunting.
    pltommyo and tonered like this.
  11. Apr 14, 2022 at 8:47 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    I run E85...but I have a vehicle with an engine actually built to use it. Results may vary.
  12. Apr 14, 2022 at 8:48 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Roughly, this big:
    pltommyo and Skydvrr like this.
  13. Apr 14, 2022 at 8:48 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Don't ask me, i got banned from the last fuel post here, and not even a clue why.
    Skydvrr likes this.
  14. Apr 14, 2022 at 8:49 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
  15. Apr 14, 2022 at 8:49 AM
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    I heard that you can improve gas mileage by replacing your radiator fluid with ketchup.
    Speedfreak, zoo truck, b_r_o and 4 others like this.
  16. Apr 14, 2022 at 8:49 AM
    1546
    Were you masked up when you posted it?
    cryptolime and SR-71A like this.
  17. Apr 14, 2022 at 8:55 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :rofl::rofl:
    Dammit!
  18. Apr 14, 2022 at 8:57 AM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    How bout e80no
    tonered likes this.
  19. Apr 14, 2022 at 9:00 AM
    LongBedOrNoBed
    LongBedOrNoBed M̴̯͖̖̐̀ȩ̶̝̼̓̋͘m̶̗͗ḅ̸̬̈̈́ḛ̶̘͆̿̈͜r̷͇͔͆̾̅
    '21 2.7 SR SX Access Cab 4X4
    265/75R16 Wildpeak AT3W
    Even if you did want to run E85 and it was a good idea to do so (it isn't), doesn't E85 get worse average fuel economy than normal gas anyways?
  20. Apr 14, 2022 at 9:05 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Filling up every 150mi is NBD. When out on an expedition, the OP can just dump the leftover drinkies in the tank!
