Which Factory Service Manual to use for a 98 Tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Draper98Tacoma, May 2, 2016.
  1. May 2, 2016 at 9:44 PM
    Draper98Tacoma
    Draper98Tacoma [OP] Member
    Draper
    1998 Tacoma 4x4
    I bought a 98 Tacoma recently and am interested in delving into the mechanical upkeep. I have access to both a '96 Tacoma and 2000 Tacoma factory service manual. Which manual do you recommend that I use for my adventures?
    Both manuals are in PDF form, however, the '96 FSM is one large document while the 2000 FSM is separated into sections and further subsections.
  2. May 2, 2016 at 9:45 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    The 2000 will be the better of the 2.
  3. May 2, 2016 at 9:49 PM
    Draper98Tacoma
    Draper
    1998 Tacoma 4x4
    Thanks a ton! also, what bull bar do you have on your pickup in that picture?
  4. May 2, 2016 at 9:53 PM
    koditten
    Kirk
    Central Michigan
    I built my own ARB clone for the Tacoma. The Tundra bumper is just what I came up with. Its not copied directly from any other bumpers.
    I'm a fabricator, so it was a fun project to see how close to the real thing I could get for the Tacoma Also, way cheaper to build my own. You are looking at $90 in steel and a 12 pack of beer to get my muffler shop to bend the hoops.
    Draper98Tacoma[OP] likes this.
  5. May 3, 2016 at 7:37 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    If you are going to keep your truck for a LONG time, and do most maintenance/repairs/mods yourself, like most guys in this crazy hobby, its well worth it to get a paper copy of the FSM. The PDF is much better than nothing, though. At least get the Haynes manual.
    Not sure about previous years, but my '99 FSM has 3 distinct volumes, one being the electrical diagrams. Took me a few months, but I eventually found them online (Amazon and Ebay). Even used, they cost me around $200, but I've saved thousands by being able to do 95% of the work that needed to be done.
    Just my 2 cents.
  6. May 4, 2016 at 1:38 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Get the one for the 98 if I recall there is some differences between 98 and 2000 to cause some interesting problems
    If I had a limited budget I would want the Electrical Wiring Diagrams first
    With a good code reader /Scanner most codes you can find the diagnostics searching online
    Until you learn the most common ones.
  7. May 4, 2016 at 8:00 AM
    tan4x4
    Rick
    Folsom, CA
