Which Front Spacer to Level Out Perfectly?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splizaat, Aug 26, 2016.
  1. Aug 27, 2016 at 9:51 AM
    splizaat
    splizaat [OP] Well-Known Member
    Beaverton, Oregon
    2020 TACOMA, CEMENT, TRD OFF-ROAD, Auto, 4dr Shortbed, Advanced Tech + Premium + LED Heads/Fogs
    I read it. I also wasn't asking how to determine which thickness of spacer. I asked WHICH SPACER will get me level. brand and model. that's all I needed. I don't understand why everyone on this forum is such a bunch of asshole know it alls?
  2. Aug 27, 2016 at 9:52 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Toytec 3/4" spacer. Any more will give you bro lean
  3. Aug 27, 2016 at 9:53 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Where @ in Kentucky? I can install 5100's at a fairly reasonable price. (Or spacers if that's what you want)
  4. Aug 27, 2016 at 9:55 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    That's what everyone says who doesn't think for themselves and just want someone to fill out a shopping cart with what they need.
    Aussiek2000 likes this.
  5. Aug 27, 2016 at 9:58 AM
    Jgchfd
    Jgchfd Well-Known Member
    James
    Kentucky
    2016 Tacoma SR5 DCSB
    I'll message you!
  6. Aug 27, 2016 at 10:00 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    "Which spacer" is yet to be determined. Sorry, but I don't know which Tacoma is yours out of the millions on the road. Try not being so sensitive and assuming everyone is being a smart ass.....You don't know by your own admission, but you want to get pissy with anyone that might know. Do you want just any answer? Or would you rather have a CORRECT answer?
    Just because you don't understand someone, that doesn't mean they're wrong. It just means you don't understand.
  7. Aug 27, 2016 at 6:45 PM
    Clearwater Bill
    Billy
    Largo Florida
    Its a spacer. For one year. Who cares what brand, you're using it as a disposable item.
    Use the formula @DCSBFTMFW gave you to calculate the thickness you need for your goal and move ahead with your project.
    Or 'suffer' with an unleveled truck till your Icon ship sails in, then do it once, do it right.
    Jgchfd likes this.
  8. Aug 27, 2016 at 6:47 PM
    splizaat
    Beaverton, Oregon
    Not concerned with brand....just concerned with which one leaves it level. Brand is not a concern.
  9. Aug 27, 2016 at 6:52 PM
    Clearwater Bill
    Billy
    Largo Florida
    Fine. Even you are confused about what you want apparently.
    So for at least the 4th time in this thread, use the method in post 2 to calculate what your truck needs.
    The point is, not all trucks are the same. It's why you need to measure yours.
  10. Aug 27, 2016 at 7:01 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Hey OP, look at post #2 for your answer. Then Google "Tacoma xyz" spacer. Then buy said spacer. Then be so damn happy with your perfectly leveled truck you come back to this thread and give everyone high fives.
  11. Aug 27, 2016 at 7:13 PM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Not all trucks will have the same amount of rake.
    Since it needs to be spelled out.
  12. Aug 27, 2016 at 7:16 PM
    T4RFTMFW
    More help, more willful ignorance.
    Shocking.
  13. Aug 27, 2016 at 7:17 PM
    T4RFTMFW
    Last verse, same as the first. :rockband:
    EatSleepTacos likes this.
  14. Aug 28, 2016 at 5:25 AM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Really not a lot of options. Just the spacer one but theres not a lot of sense with it. You will need an alignment after so it's not much cheaper. Also any place can install a new shock or they should give their job up. So really you have the option of a spacer lift or spring I think
  15. Aug 28, 2016 at 5:42 AM
    #35
    Aussiek2000
    2016 Offroad AC
    Even a spacer is going to require longer studs which requires taking the strut apart.
  16. Aug 28, 2016 at 5:46 AM
    #36
    Bluegrass Taco
    Bill
    Mt Washington Ky
    OK.....Humor me....I'm old and don't know much. I've lifted a total of 9 IFS Tacoma's, including 3 of my own. No two were the same. I literally swapped the same exact lift kit on two different trucks and got two different results.
    So....Once again. Just park the truck on flat ground, measure from middle of hub to bottom edge of fender opening on ALL FOUR CORNERS, then post here. You won't even need to do any math if THAT'S what is making you so irritable. We'll help you. Honest. There is no magic spacer that will make EVERY truck sit level, no matter the differences. At that point, you will have a spacer thickness suggested to you that will do what you want. You will be free to buy any brand you so desire. What have you got to lose?
    One more time....do you want just any answer, or would you prefer a CORRECT answer?
    T4RFTMFW and Aussiek2000 like this.
  17. Aug 29, 2016 at 7:09 PM
    #37
    Sudsman44
    Sudsman44 Well-Known Member
    Abington PA
    2012 Tacoma Access 4x4
    Ranch cap w/ rhinorack bars, 5100s, Deaver AAL, 2” front receiver, Matt Gecko bedlights, yadda yadda…
    You could buy a half ton of bar sand and set it in the back behind the axle. That'll level that baby out. $40 bucks, done.
  18. Sep 6, 2016 at 11:03 AM
    #38
    splizaat
    Beaverton, Oregon
    Does the 2" Rough Country front spacer require a 1" block in the rear to be level?
  19. Sep 6, 2016 at 11:06 AM
    #39
    maxpower29
    Jordan
    Nova Scotia, Canada
    probably no
  20. Sep 6, 2016 at 11:07 AM
    #40
    maxpower29
    Jordan
    Nova Scotia, Canada
    2 inch in front will likely level it out. I was not level with 1.75 in the front once
