Which Fumoto?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SkyDivinTaco, Jul 27, 2021.
  1. Jul 27, 2021 at 9:04 AM
    SkyDivinTaco
    SkyDivinTaco [OP] Well-Known Member
    T.
    Oahu
    Silver 2004 OR Taco & Voodoo Blue 2021 OR Taco
    As the title says, which Fumoto for 3rd Gen Taco? I see members using either of these and see one has a longer nipple than the other. Which one works best with TRD skid plate? Does longer nipple peak below TRD skid plate?
    https://www.amazon.com/dp/B0887M5LNG
    https://www.amazon.com/gp/product/B07D9FCRWM?smid=ATVPDKIKX0DER
    Yeti Taco and TacoEspecial like this.
  2. Jul 27, 2021 at 9:05 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I like long nipples
    LukeLifts, BillW, radclerk1 and 9 others like this.
  3. Jul 27, 2021 at 9:08 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
  4. Jul 27, 2021 at 9:08 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Are you talking about the Pro skid plate or the stock Sport/OR skid? If the latter, then the valve is further back than the skid. I prefer the long nipple as it allows me to put a length of hose on it to make the job a little neater.
    Yeti Taco and Big tall dave like this.
  5. Jul 27, 2021 at 9:39 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
  6. Jul 27, 2021 at 9:51 AM
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    I have the F133N long nipple with a TRD Skid Plate. The nipple doesn't peak pass the hole...:)
    Just curious, is there an advantage over the Fumoto? From the looks of it, it is almost double in price.
  7. Jul 27, 2021 at 9:56 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
  8. Jul 27, 2021 at 4:27 PM
    FLJB
    FLJB Well-Known Member
    J
    FL
    2020 4X4 Sport MT
    I have the F103N on mine with the TRD skid plate - no issues with clearance and I was able to put it on with the skid plate already in place.
    The one in your post is a F133N but the other is F103S...
    Just and FYI so you don't order the wrong one. I think the F103 is what you want, N is long and S is short.
    Edit: I looked it up and both the F133 and F103 have 12X1.25MM threads so i guess either is ok, but I know an F103N works.
    Irons and TacoEspecial like this.
  9. Jul 27, 2021 at 4:31 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I've seen several people get screwed over by the Fumoto valves. Everything from being knocked off to being jarred open by a stick or other object causing the engine to run out of oil without the driver realizing it until it was too late. That's not an issue with the Stahlbus and it maintains the quick drain ability for those who don't want to bother with a standard drain plug.
    Skydvrr likes this.
  10. Jul 27, 2021 at 4:32 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Have you reaaaaallly?
    rimfire7 and usmc2msu like this.
  11. Jul 27, 2021 at 4:48 PM
    RedWings44
    Michigan
    Yes. There are actually a couple of threads on here as well.
  12. Jul 27, 2021 at 4:48 PM
    JKO1998
    Utah
    I guess I missed those
  13. Jul 27, 2021 at 5:47 PM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    I bought the long nipple version and it easily fits under my aluminum TRD skid plate. I hook-up a hose to it and drain my oil directly into a container. No mess.
    The one I bought came with a plastic safety clip that snaps on over the little lever on the valve when it’s closed. If I didn’t have a skid and the plastic clip I ‘might’ be worried about it accidentally getting knocked off or opened.......but the chances are so slim that I don’t miss any sleep over it....
    Yeti Taco likes this.
  14. Jul 27, 2021 at 6:16 PM
    PhilipMarlowe
    PhilipMarlowe Active Member
    2019 Tacoma TRD Sport
    I have a question concerning these oil change systems..maybe someone can answer? When the Fumoto for example is screwed into the oil pan, I assume that it is not flush with the bottom of the internal oil pan. If so, doesn’t that mean you’re not getting a full drain-out? Over time, wouldn’t this built up sludge in the pan? Thanks
    DAS Taco and Skydvrr like this.
  15. Jul 27, 2021 at 6:19 PM
    Pro-Taco
    Pro-Taco Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
    It all depends on which hole :D
    Rainoffire[QUOTED] likes this.
  16. Jul 27, 2021 at 6:21 PM
    FritoBandito
    FritoBandito Well-Known Member
    Texas
    2016 Limited 4X4 DCSB
  17. Jul 27, 2021 at 6:24 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Depends, does this sludge stay at the bottom of the pan when the engine is running? If not, just run the engine for and minute then drain the oil.
    usmc2msu likes this.
  18. Jul 27, 2021 at 6:27 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    yoopersteeze likes this.
  19. Jul 27, 2021 at 6:31 PM
    PhilipMarlowe
    I don't know...I personally would stay away from these things because I don't know. Thanks
    DAS Taco likes this.
  20. Jul 27, 2021 at 6:33 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Well if it stirs everything up, then most of it most likely to leave through the drain plug. If not, then does it matter?
    Idk the answer, but idk if sludge at the bottom of the oil pan is a real issue. I've been wrong before though.
