Which fuses to pull for compression test?
Discussion in '1st Gen. Tacomas (1995-2004)' started by digcolnagos, Jul 28, 2022.
  1. Jul 29, 2022 at 2:11 PM
    #41
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    Yea I thought so then you could Use voltage meter on the wire plug that go into coils if it starts misfiring again. then if it’s good then look at the valves if it’s not the valves. it’s probably the injector.
  2. Aug 26, 2022 at 7:51 PM
    #42
    digcolnagos
    digcolnagos [OP] Member
    It was a bad injector. Thanks, all, for playing.
    Smokestacks likes this.
