Which Gear Ratio to use?
Discussion in '4 Cylinder' started by evil_gandhi, Oct 27, 2009.
  1. Oct 27, 2009 at 11:33 PM
    evil_gandhi
    evil_gandhi [OP] Member
    Jake
    Northern California
    1995 4x4
    Bilstein 5100's all the way around, fronts @2.5" (highest) setting. Rear leaf springs from a '91 pickup (1.5" lift). Firestone airbag spring helpers. Doug Thorley ceramic coated Tri-Y header. K&N air filter. Tubular steel front bumper.Much more planned!!!
    So which ratio should I choose for my 95 4x4 2.7L automatic?
    Right now it has 31's, but it will soon have someting in the neighborhood of 33's on it, maybe a little bigger. It currently has 3.73's in it I believe and its 10.4% overdriven as it is. I tow a trailer with this rig through the mountains so I would like to go a little lower than whatever would compensate for 33's. According to my calculations 4.10s would correct for the 31's and 4.56s would a little more than compensate for 33's. I am wondering about going with 4.88s but I am concerned they mauy be too low.
    Any speculation or experiences would be apreciated.
    Does anybody have a body lift they would recommend?
    Do you have any suggestions on how to coax more powere out of the 3rz without going to forced induction?
    Also does anyone know if it is kosher to add a small spacer on top of Bilstein 5100s cranked all the way up, like one that would add just an inch or so of lift?
    Thanks
  2. Oct 28, 2009 at 8:24 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
  3. Oct 28, 2009 at 8:34 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    On the gear ratios I would say a 4.56 would be about right if you are going to running 33 inch tires and towing a trailer. As for your question about the lift. Running a top plate spacer is ok with the 5100s as long as the spacer you are referring to is in the 1/4 thick range. Also, you would want it to be on top of the strut assembly, not inside the coil pack.
  4. Oct 28, 2009 at 8:36 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    you could go the 1/2" thick range giving the 3/4" additional lift for the spacer
  5. Oct 28, 2009 at 10:43 AM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    I also have a 2.7l 1st gen, but my gearing is 4.10 stock with 32's on it.
    It works okay...but I really want 4.56's to get better gas mileage around town and more grunt offroad.
    Everybody says to get headers, so that's what i'm going to do to get more power out of my little 3rz.
  6. Nov 5, 2009 at 7:33 AM
    evil_gandhi
    Jake
    Northern California
    1995 4x4
    Thanks to all of you for your input, especially afd23a. That gear calculator was really helpful. I have decided to go with 4.88s. This is not going to be my daily driver so gearing it a little lower is not that big of an issue.
    I ordered a set of polyurethane spacers that are supposed to provide an inch of lift.
    I am building a winch bumper and I will post some pics if I can.
    To Sachou: I put a doug thourley header on my 3rz and I found that it did not really add top end power but rather brought a good deal of power down to the 2000-4000 rpm range which is exactly what I was looking for. Northwest Offroad makes a header that they clai to be superior to all others and it does not require a gasket. I would check them out, I was unable to put one on my truck because the NWOR header does not carry a CARB number.
  7. Nov 5, 2009 at 8:19 AM
    afd23a
    The Dynamo of Dixie
    I'm glad it was helpful :thumbsup:
  8. Nov 7, 2009 at 3:48 PM
    Reaper22
    Reaper22 Well-Known Member
    Palmyra Missouri
    SR5 Tacoma
    Radient Red, Red Grille, Debadge'd, Blacken'd Headlights, DTRL's, Cruise Control, Fog Lights, 2 1\2" suspension lift, 285\75\16 Nitto Dune Grapplers, Pioneer Premier DEH-P510UB stereo, Pioneer 3 way fronts with factory tweeters & Kenwood tweeters, Kenwood truck boxes behide seats with 8" subs in each, Wet suit like tacoma seat covers
    Here is another table you could use also..
    http://www.4lo.com/calc/geartable.htm
  9. Nov 7, 2009 at 4:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Without knowing what gear you have, its hard to guess what you need. You have a gear code on the door jamb. It will look like "B04A", or the like. It should be near the VIN number....Post it up, so we can see what you currently have.
  10. Nov 7, 2009 at 4:14 PM
    Reaper22
    Palmyra Missouri
    SR5 Tacoma
    Chris this is what I found on my door, How do I translate that to a gear ratio..
    A02A\R155F
    Thanks man..
  11. Nov 7, 2009 at 4:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The axle code for your rig can be found on the manufacture's sticker located on the driver's side door jamb as follows:
    First digit:
    • A = 7.5" ring gear
    • B = 8" ring gear
    Next two digits:
    • 01 = 3:42
    • 02 = 3:58
    • 03 = 4:10
    • 04 = 4:56
    • 05 = 3:15
    • 06 = 3:91
    • 07 = 4.30
    Last digit:
    • A = 2 Pinion, Open
    • B = 4 Pinion, Open
    • C = 2 Pinion OEM Limited Slip
    some '98-00 models have shown a BO code of "???" on the door plate; so far this turns out to be a 3.91 gear ratio, at least for the 5sp. RZN171L-CRPDKAB with factory 31s/265s should be 4.56 with the AT.
  12. Nov 7, 2009 at 5:40 PM
    Reaper22
    Palmyra Missouri
    SR5 Tacoma
    Hmmm, Here I thought all 6 lugs were 8", Looks like I need to step up to at least 4:11's by the chart I posted. I do have manual trans with 33's..
    Thanks man..
  13. Nov 7, 2009 at 5:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    DOH! I didnt notice you had a second gen. You have an 8", and 4:10 gears. That chart only aplies for the first gens. :eek:
  14. Nov 7, 2009 at 5:54 PM
    Reaper22
    Palmyra Missouri
    SR5 Tacoma
    Whoo Hoo! that makes me fell better, Thanks for the update..
  15. Nov 8, 2009 at 3:54 AM
    Reaper22
    Palmyra Missouri
    SR5 Tacoma
    You are correct Chris, this is some info I dug up..
    This is what toyota has for specs on a 4X4 2010
    Final axle ratio - MT4.1
    Or you can go here http://www.toyota.com/tacoma/specs.html
    I googled my 06 and all the sites I found with specs say
    4.1:1 axle ratio
  16. Nov 8, 2009 at 2:24 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    A big ol write up on the gear swap is a must now.:)
    I expect to see R.P.M.s on the freeway before and after , a locker installed , Faux accident with a yugo under a wheel , oh yea 0-60 before and after :D
    I like my stock 4.10 with the 245 series (30" or so), I do sorta wish it came with something like 4.33 though, that wouldn't be too high for the freeway.For What little off-trail riding i do, I go to 4lo for idling in 1st gear. why regear for that 8-12 mi. a year in my case.
  17. Nov 8, 2009 at 2:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I had 4.30's in my first gen with 32" tires....It worked really well....Kinda diapointed Toyota didnt keep that gear ratio.
  18. Nov 8, 2009 at 2:30 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    All this talk about gear ratios....
  19. Nov 8, 2009 at 2:37 PM
    Tacoyota
    08 4wd
    Toyota did a good job on these reg cabs overall in my opinion, but for trucks a lot comes down to first gear/gear ratios, they should have a fairly low gear for towing/idling offroad. I'd love the manual 5 spd to add a gear at the low end for that.
  20. Nov 22, 2009 at 5:18 PM
    evil_gandhi
    Jake
    Northern California
    1995 4x4
    Okay, so my axle code is B03A, 8" 4.10 ratio, open carrier.
    I have purchased 4.88 ratio Precision Gear rings and pinions, and the Eaton Kazuma TRD limited slip unit. I am also building a pretty beefy bumper so I guess I should document the swap process and the crushing of a small import car.
