Which Geolandar's are these?
Discussion in 'Wheels & Tires' started by Iggy, Nov 4, 2014.
  1. Nov 4, 2014 at 11:16 AM
    Iggy
    Iggy [OP] Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    I've been searching which model these are to get more info and I can't find them.
    Does anyone know?
  2. Nov 4, 2014 at 12:27 PM
    nextfriday
    nextfriday Well-Known Member
    Indianapolis, IN
    13 SR5 Double Cab
    5100s@2.5", 2" aal Leer 100 XR w/ Yakima rails and towers 18x9 Pro Comp Rockwells Cooper Discoverer AT3 275 65 18
    Similar to the ats, but not exactly.
  3. Nov 4, 2014 at 1:53 PM
    IronBagel
    IronBagel Well-Known Member
    Jake
    North Carolina
    2009 DCSB
    Retreads?
  4. Nov 4, 2014 at 1:54 PM
    Iggy
    Northern CA
    Check out the build
    I have no idea? The sidewalls are different than anything I can find on their website.
  5. Nov 5, 2014 at 6:18 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    They are an older model ATS I believe. I knew an old timer that had an old set like these that he hand drilled and studded for winter. The tread pattern is identical to the ATS if you look at it broadly. The shape of all the lugs and channels is identical. I think if you were to zoom in you would see siping and smaller channels and recognize it as an ATS.
  6. Nov 6, 2014 at 5:04 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Yep, older style Geolandars. I had them, they were so so tires.
    Edit: now that I look at them side by side they aren't the same. I'm not sure OP.
  7. Nov 6, 2014 at 5:19 AM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Maybe a different tread pattern for larger sizes?
  8. Nov 6, 2014 at 9:53 AM
    Iggy
    Northern CA
    Check out the build
    Thanks for all the suggestions!
    I've seen all the tires on their site and while the ATS is the closest, the sidewall is off a bit and it seems like a more blocky tread pattern.
    But after searching I can't even find another picture of the same tire.
  9. Nov 6, 2014 at 10:22 AM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
