Which headunit?
Discussion in 'Audio & Video' started by Chris(NJ), Apr 12, 2017.
Which radio for my 08 w/ jbl
  1. Alpine CDE-W265BT
    1 vote(s)
    7.1%
  2. JVC KW-R925BTS
    1 vote(s)
    7.1%
  3. Pioneer AVH-4200NEX
    12 vote(s)
    85.7%
  1. Apr 14, 2017 at 10:31 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I should have kept my single din pioneer 3900BT stereo :facepalm:
  2. May 10, 2017 at 9:24 AM
    EngineerMatty
    EngineerMatty Active Member
    2009 Silver Tacoma Access Cab 4x4 TRD
  3. May 10, 2017 at 9:35 AM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    Of the 3 you are deciding between, only consider the Pioneer. Alpine is a great brand, but should look for a more comparible unit as the Pioneer.
    If you plan on spending good dough on a h/u, and already have sound deadening, upgrade wires and speakers too, as well as add a 4 ch amp.
  4. May 11, 2017 at 11:56 AM
    firestorm
    firestorm Active Member
    Calgary, Alberta
    2011 Tacoma DBL Cab
    Just get the AppRadio 4 for cheaper. You get Carplay and a pretty decent HU with none of the BS 'features' that you'll never use. Highly recommended.
  5. Jun 3, 2017 at 6:39 AM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    I have that Alpine unit which I bought back in July 2015. They may have another new one right around the corner...wouldn't pay retail for it now.
    It's a very clean sounding, feature packed unit ( 9 band EQ with adjustable bands and Q, built in crossovers are great). The only disappointment is the overstated 4 volt preamp spec. I have the gain my PDX sub amp turned up 2/3's.... which is way too high. And the sub preamp only outputs sub frequencies instead of full range...which makes the sub preamp and control useless when you want to setup an Epicenter properly ( need to split one of the full range outputs).
    The Bluetooth sounds ok, but it DOES compress the source signal a bit...so I use an iPhone cable 99% of the time.
