which is a better leaf set?
Discussion in 'Suspension' started by 08pretaco, Dec 3, 2009.
  1. Dec 3, 2009 at 9:04 AM
    08pretaco
    08pretaco [OP] Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    wheelers:
    OME 2.75" Lift Leaf Spring Set: 375.00/pr [​IMG] THESE OME DAKAR SPRINGS PART #'s CS047 REQUIRE BUSHING KIT SHOWN BELOW. OTHER PARTS THAT ARE RECOMMENDED WITH THESE IS OUR LONGER U-BOLT SET, FK29 DRIVELINE CARRIER BEARING DROP KIT AND OME REAR SHOCKS SHOWN BELOW:
    OR
    Toyteclifts.com:
    OME leaf spring 2005-2010 Tacoma
    Price per Unit (EACH): $199.99
    Number EACHs in packaging:1
    Number EACHs in box:1
    CS047R
    ****PRICED PER SPRING****ORDER QUANTITY OF 2 PER VEHICLE
    2 1/2" lift complete rear springs priced each with bushings. Also requires new U bolts not included
    OME Dakar leaf springs feature:
    • Draw Tapered & Diamond Cut Leaves: Ensure the load is progressively distributed over a larger surface area, reducing the high stresses that develop at leaf ends. This provides increased ride quality and protection against leaf breakage, significantly increasing the spring life.
    • Bolt Clamps & Liners: The leaf clamps are bolted to allow installation of anti squeak nylon liners.
    • Fully Scragged & Load Tested: Scragging ensures the spring takes a permanent 'set' which reduces the risk of sagging. Load testing ensures the spring meets the required specification.
    • Graphite Coating: To further reduce the friction between the spring leaves & friction pads.
    • Military Wrap: Designed to provide added safety.
    • Anti Friction Pads: Regreasable nylon interleaf liners reduce friction at the leaf tips where the load is the greatest.
    • Flat Axle Seat Area: Allows a positive, safe axle mount reducing spring stress & increasing spring life.
    • Shot Peening: The tension side of all leaves is shot peened to reduce spring stress. This process can double the life of a spring.
    • Two-stage Leaf Pack: Featured on most rear springs for optimum comfort. When unladen the vehicle is largely riding on the primary stage, with the secondary stage providing additional support when a heavy load is added.
    Please note: Most Emu Dakar leaf springs have all the listed features, but where design or a physical limitation exists one or more of these features may not be incorporated. Please check with your OME licensed fitter for further information.
  2. Dec 3, 2009 at 9:10 AM
    AZCOMA
    AZCOMA where can't I go?
    Kacey
    Laveen
    05 Preunner sr5
    2.5 saw co's, n-fab bed cage rear tire mount,new head unit and 10"sub,285/75/16 nittos on M/T wheels,H.I.D.'s...The next mod is T.C. long travle kit,Deavers and glass all the way around.
    suspension travle or lift? if u want travle and lift go to a local shop and have them make u a set. Its not that spendy and no shipping.
  3. Dec 3, 2009 at 9:11 AM
    8th sin
    8th sin Swollen Member
    Tampa, FL
    2015 DCLB 4x4 Sport
    Llumar CTX Tint, Grillcraft MX Upper, Pro Comp Rockwell 5034 17x8.5, Nitto Terra Grappler G2 LT285/70/17, Icon Stage III
    they are the same spring...OME CS047
  4. Dec 3, 2009 at 9:47 AM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    what about allpro.
  5. Dec 3, 2009 at 10:07 AM
    08pretaco
    az
    I didn't notice them being the same, I thought the wheelers were progressive and the toytec ones looks different then what I imagined the wheelers set to look like. Sorry if you guys wanna delete that's fine haha
    I heard the sll pros are hit or miss: some people like them some don't. I can't justify spending 600 for dakars or alcans, don't have the 200 bucks. I might look into local shops. I'm looking for both lift and flex.
  6. Dec 3, 2009 at 10:12 AM
    08pretaco
    az
    One says its r and then they advertise different lift numbers. The leafs that are progressive where the icons and I mixed up haha sorry guys :(
