which is a better spark plugs?
Discussion in 'Technical Chat' started by linkfeeney, Jul 20, 2009.
  1. Jul 20, 2009 at 11:52 AM
    linkfeeney
    linkfeeney [OP] Well-Known Member
    link the stink!
    aberdeen, nj
    09 Doublecab TRD Off-Road! Magnetic Grey!
    NGK or Denso?
    I like the laser irdium and denso too...
    u guys think i should just get the NGK. Easy to get at parts store anyway! :)
  2. Jul 20, 2009 at 12:09 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    I run NGK, Anything But bosch
  3. Jul 20, 2009 at 12:14 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    I can get those ngk iridiums for like 6.49 here at work. Plus my 20% discount plus tax, they come out to like 6 bucks each. I might be able to get them cheaper too
  4. Jul 20, 2009 at 12:31 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    You can't go wrong with either. I would only buy NGK or Denso.
  5. Jul 20, 2009 at 1:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Use the OEM Nickle plugs for best results. There is NO benafit to running the Iridiums, or whatever. In some cases, they run worse.
  6. Jul 21, 2009 at 5:51 AM
    flatlander
    flatlander Well-Known Member
    09 DC-LB 2WD Prerunner V6 Auto
    Did I read somewhere that from the factory on V6's they put one type on one side of the engine and another on the other side? But then I read on a plug changing howto to go back with the better type for all six cylinders, which I can not remember whether that was ngk or denso?
    Any ideas?
    TIA
  7. Jul 21, 2009 at 5:53 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    NGK is on the driver side, and Denso is on the passenger side. No idea why this is, but my friends and I have ideas. Anyway, I recomend useing all Denso when changing the plugs, as they seem to hold their gap better.
  8. Jul 26, 2009 at 5:36 PM
    linkfeeney
    link the stink!
    aberdeen, nj
    does the dealer sell Denso Irdium or Platinum?
  9. Jul 26, 2009 at 5:45 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    My buddy is a maechanic and he said that NGK is by far the best option for Tacos! :D
    So i'm running the NGK Irodium Plated...got em at Autozone.
  10. Jul 26, 2009 at 5:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Interesting....I have actually TESTED these different plugs, and found quite a few times, the Iridium or Platinum plugs cause issues. Best performance has been achieved with the OEM Nickle Denso plugs.
  11. Jul 26, 2009 at 5:54 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Hmmm...Mine runs like a champ, mine had NGKs in it when I changed em and that's straight from the dealer although mine was a certified preowned so maybe the person before me was runnin NGKs too :rolleyes:
  12. Jul 26, 2009 at 5:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    NGK's work fine, they just dont hold a gap well.
  13. Jul 26, 2009 at 5:55 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven
    '17 Inferno DCSB O/R
    STOCK 4 NOW
    i gotta go with the NGK's! made in wv, what more can you ask for out of a product? lol :)
  14. Jul 26, 2009 at 6:49 PM
    linkfeeney
    link the stink!
    aberdeen, nj
    so I guess the dealers sell the denso? how much are they a pop?
  15. Jul 26, 2009 at 6:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    About $3.50 per plug for the 1GR-FE in my Area.
  16. Jul 26, 2009 at 6:52 PM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    Sold my truck Jan '13... Still hang around.
    I guess that's OK... I mean, spark plugs don't really need teeth.
  17. Jul 26, 2009 at 6:54 PM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    I thought Toyota advised against using an Iridium plug in the 4.0
  18. Jul 26, 2009 at 6:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They do.
  19. Jul 27, 2009 at 3:16 AM
    linkfeeney
    link the stink!
    aberdeen, nj
    how much are the plugs from the dealer? I saw the the plugs advance auto parts and they are like $8.99 here..not cheap
  20. Jul 27, 2009 at 9:30 AM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    When I went to purchase the plugs from Toyota parts, the Tech pulled up the standard OEM Denso's (Nickle). I ask whats the Diff between them and the Iridium, and only answer I got was life of the plug: ie.. 30,000 or 100,000 mile plug change. Not sure how true this is. But of course I chose the cheaper of the two:D
    Only time plugs should become an issue of whats best, would be when running a SC... I believe this requires a colder plug, which comes w/the SC Fit Kit...
    Other than that, OEM copper will get the job done, and yes nevermind the NGK/Denso R/L mix match. If you are gunna do it, do it right. Let the dealership worry about pleasing Manufacturer's:cool:
