Which is a stronger, 3.4 or 4.0?
Discussion in 'Performance and Tuning' started by LukeBo4x4, Jun 13, 2013.
3.4 or 4.0
Poll closed Jun 13, 2014.
  1. 3.4
    21.8%
  2. 4.0
    78.2%
  1. Jun 13, 2013 at 10:28 PM
    #41
    NW4RUNNER
    NW4RUNNER Well-Known Member
    4 runner trail
    3.4 can squat more but the 4.0 has higher bench press hands down.
  2. Jun 13, 2013 at 11:45 PM
    #42
    AWilson013
    AWilson013 Almighty Dirt King
    Alex
    Seattle, WA
    2006 GX 470 Sport
    Matte Grey SCS F5s - 255/80R17 ST Maxx - Front Runner Slimline II - CVT Tent/Awning - 35w Morimoto HID Low Beams - LED High Beams - LED Fogs - AFE Dry Filter - BP-51s - Dirt King UCAs
    By that logic the 3.4 is more powerful and durable. ;)
    I heard the 4.0 can do 100 pull ups though (kipping). By today's logic, that's the strongest. :rolleyes:
  3. Jun 13, 2013 at 11:57 PM
    #43
    dph473
    dph473 Active Member
    Man, you brung it back old school, I remember the 22RE, loved that motor, ran forever...I'll still see one today rolling around and brings me back to high school days.
    That's very promising and good to know. I'm hoping to make mine last till the wheels fall off.
  4. Jun 14, 2013 at 4:42 AM
    #44
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    ah that makes more sense, thanks for clarifying i was dislexically reading it i guess.
  5. Jun 14, 2013 at 7:14 AM
    #45
    taco206
    taco206 Well-Known Member
    2JZ-GE and GTE are belt driven. So I guess a 4.0 is "stronger and more durable" than the GE and GTE too. But the 4.0 is a good unit, my brother in law has 215k on his 03 4runner V6 and it runs great and pulls hard.
  6. Jun 14, 2013 at 8:45 AM
    #46
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2UZ-FE 4.7 V8 FTW.
    :cool:
  7. Jun 14, 2013 at 8:46 AM
    #47
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    If the belt snapped, some of the valves would remain in the open position while the pistons would continue to go up and down, smashing into the valves that weren't closed, bending them.
    The same damage would occur whether it was a chain or a belt failure.
  8. Jun 14, 2013 at 8:49 AM
    #48
    JDMcQ
    The 3.4 is a non-interference design. There will be no collision of valves/pistons.
  9. Jun 14, 2013 at 10:05 AM
    #49
    BamaToy1997
    Bill
    Navarre, FL
    As mentioned above, the 3.4 is not an interference engine, so even if the valves were stuck fully open, the piston would never come into contact with it. Thus no damage.
  10. Jun 14, 2013 at 11:02 AM
    #50
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    yeah I mean timing
    Its easier to break a belt then chain, overall both are good motors I would be happy with
  11. Jun 14, 2013 at 12:03 PM
    #51
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
  12. Jun 14, 2013 at 12:12 PM
    #52
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Toyota engine's are like the Duracell bunny......
  13. Jun 14, 2013 at 1:32 PM
    #53
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Driven both. More impressed with the 4.0.
  14. Jun 14, 2013 at 2:32 PM
    #54
    tooter
    Greg
    Los Angeles
    Ah, that's good designing. :)
    They planned in advance for the contingency of snapped belts.
  15. Jun 14, 2013 at 3:34 PM
    #55
    LukeBo4x4
    LukeBo4x4 [OP] The more people I meet, the more I like my dogs.
    luke
    Big Island,Virginia
    03 TRD ext cab
    OME 882s, wheelers 5 leaf pack w/aal, ARB front bumper, 305/70/16 nitto mud grapplers,pro comp 7069s, Grey wire mod.
    very tough moter for sure.
  16. Jun 15, 2013 at 1:58 PM
    #56
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    3.4 is stronger all the way around. Might not be as efficient as the 4.0, thus the lower power output, but it is definitely an engine that was build with strength and durability in mind.
    Iron block, closed deck is a good starting point.
    4.0, is all aluminum, open decked with sleeve liners. Powder cast steel rods, and weak ring-lands.
    2rz,3rz,5vz > 1GR
  17. Jun 15, 2013 at 2:18 PM
    #57
    max2
    max2 Well-Known Member
    Gary
    Ruidoso, NM
    There's no replacement for cubic inch displacement.
  18. Jun 15, 2013 at 5:59 PM
    #58
    LukeBo4x4
    luke
    Big Island,Virginia
    03 TRD ext cab
  19. Jun 15, 2013 at 6:15 PM
    #59
    taco terror
    taco terror 1st gen = best gen
    North Carolina
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    I have always wondered what non-interference meant exactly, or how it works. Does it mean that when a piston is at TDC and a valve is stuck open it wont touch it?
  20. Jun 15, 2013 at 6:34 PM
    #60
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Always heard of the 3.4 having head gasket issues.. Driven both and own a 4.0 and their both dang good engines period. Just the 4.0 is much more efficient and less maintenance imo..regardless its still a TOYOTA :D
