Which is a stronger, 3.4 or 4.0?
Discussion in 'Performance and Tuning' started by LukeBo4x4, Jun 13, 2013.
3.4 or 4.0
Poll closed Jun 13, 2014.
  1. 3.4
    21.8%
  2. 4.0
    78.2%
  1. Sep 21, 2013 at 11:24 PM
    #101
    ONALL4
    ONALL4 Well-Known Member
    Frank
    Toronto Canada
    2004 V6 4X4
    the lesser number mean less weight (lb) for each 1 hp. its weight per hp so the less the number the faster the truck is.
    the 4L is faster I test drove one. as far as durability I don't know I haven't own one but my 3.4 works great all original except all belts & water pump kit, battery, tires and muffler at 240K KM. No alignment, electrical, suspension or engine leaks noise or any other issues.
  2. Sep 22, 2013 at 12:17 AM
    #102
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    The 4.0 could use a major power upgrade from the factory
  3. Sep 22, 2013 at 7:37 PM
    #103
    42boxer
    42boxer Well-Known Member
    Brannon
    Mcguire AFB, New Jersey
    2000 Toyota Tacoma TRD
    Plenty to come
    Vid or it didn't happen? my 3.4 hangs with my dads 4.0. Both N/A
  4. Sep 23, 2013 at 12:23 PM
    #104
    Darthyota
    Darthyota Well-Known Member
    Alberta
    Blown BSP X-Runner
    TRD s/c @ 9lbs, Unobtanium Welding 321SS Full Race Exhaust, B&M s/s, TRD 1st Gen CAI, sittin sic track ready drop, TSW Tanka's with 275/40/18's all the way around, 4300k hid's in headlights and fogs, with more to come
    x2 and the 3.4 has a forged bottom end stock
  5. Nov 22, 2013 at 7:50 AM
    #105
    taco206
    taco206 Well-Known Member
    It's already had a power upgrade for years, just not in the Tacoma. 4Runner owners have had the 270 HP 4.0L since 2010 model year and Tundra owners since 2011. SMH at Toyota. I really don't get it, but the Tacoma sells regardless.
  6. Nov 22, 2013 at 10:13 AM
    #106
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That dual vvti 1GR is much weaker than the ones in the Tacoma. The new 1GR should be better though.
  7. Nov 22, 2013 at 10:46 AM
    #107
    ONALL4
    Frank
    Toronto Canada
    2004 V6 4X4
    Ya there is no way 4.0 can beat 3.4 SC you gotta be a real bad driver to lose to that.
    Its only on Paper, in actual it depends on driver's reflect and skill but weight to power ratio is not that much different half a sec 0-60. the 2nd gen has a little advantage stock to stock half a sec.
    http://www.060calculator.com/cars/2008/toyota/tacoma/22665
    2008 Toyota Tacoma Base V6 4x4 Access Cab 127.8 in. WB
    Horsepower
    236 hp
    Curb Weight
    3950 lbs
    Drive Type
    part-time four-wheel
    Transmission
    6-spd man w/OD
    0-60 mph
    6.63 seconds
    (estimated time)
    http://www.060calculator.com/cars/2004/toyota/tacoma/15089
    2004 Toyota Tacoma Base V6 4x4 Xtracab 121.9 in. WB
    Horsepower
    190 hp
    Curb Weight
    3515 lbs
    Drive Type
    Transmission
    5-spd man w/OD
    0-60 mph
    7.14 seconds
    (estimated time)
  8. Nov 25, 2013 at 5:51 AM
    #108
    Jakers83
    Jakers83 Well-Known Member
    Jake
    Denver
    2.7 base.
    OME lift. Tires and wanting more
    2.7!!!!!!!!!!!!!!!!
  9. Nov 28, 2013 at 2:13 PM
    #109
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Everyone knows that. this poll is just for second place.
  10. Dec 8, 2013 at 7:08 AM
    #110
    muddybamaboy
    muddybamaboy Member
    Brantley
    Bham,AL
    98 SR5 4x4
    OME 881s on OME struts, Deaver AALs, K&N air filter w deckplate mod, 305/75/16 Dick Cepeks, Clutch Masters Stage 2 clutch assembly, Pro Comp es 9000 rear shocks, Real Tree seat covers and floor mats on 2003 4Runner buckets, custom sewn transmission and transfer boot(leather), 5% tint rear sliding and Xcab, Double layered 20% on front side glass, 50% on entire windshield, aftermarket pedal kit, self improved cats, AVS bug shield and ventvisors, black BetterBuilt low pro toolbox, 200+ ft of logging chains, shackles, bed cargo net, NGK performance plugs and wire set, few more I'm probably forgetting!
    Bring that 2nd gen to Shelby County, we'll hit some APCO lines I'll show you how a 1st generation will "out do" a 2nd!!;);)
  11. Dec 8, 2013 at 7:19 AM
    #111
    LukeBo4x4
    LukeBo4x4 [OP] The more people I meet, the more I like my dogs.
    luke
    Big Island,Virginia
    03 TRD ext cab
    OME 882s, wheelers 5 leaf pack w/aal, ARB front bumper, 305/70/16 nitto mud grapplers,pro comp 7069s, Grey wire mod.
    My brother might be right but I'll stick with my 3.4!!!
  12. Dec 8, 2013 at 7:19 AM
    #112
    mac424205
    mac424205 Well-Known Member
    Mathew
    Chelsea
    2005 4Runner Limited V8 4X4
    Billies on all four corners with daystar spacer lift. Bought it like this. Replacing done with toytec ultimate 3" lift
    Yota has a 2wd 2nd gen so yea, he won't get too far... on APCO trails
  13. Dec 8, 2013 at 7:37 AM
    #113
    muddybamaboy
    muddybamaboy Member
    Brantley
    Bham,AL
    98 SR5 4x4
    Yea just saw. My partner's 4.0 has got more power than my 3.4. My unit has 288k on clock and 305s and that 2nd gen w 265s and 80k won't and can't hang. He plays it off well, but it's gotta suck when a '98 cuts cookies around your '11 in a hole while you're stuck in 4LO. 2WDs lifted are the funniest, and my ol lady says "cute."
  14. Dec 8, 2013 at 8:06 AM
    #114
    yota243
    E.J.
    north Alabama
    Id make it farther than u. 2wd > 0wd haha.
  15. Jan 13, 2014 at 2:27 PM
    #115
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Wut? :cookiemonster:
  16. Jan 16, 2014 at 2:22 PM
    #116
    creech
    creech PUFF-N-STUFF420
    BRADLEY
    SGV
    1st Gen Taco 2000 Prerunner
    TRD SUPERCHARGER URD 7th INJECTOR KIT
    Got the answer to that one.... TRD Supercharged 3.4 definitely gets over on the bigger 4.0 motor.
  17. Jan 16, 2014 at 3:01 PM
    #117
    yota243
    E.J.
    north Alabama
    Got the answer, but not the question
  18. Jan 16, 2014 at 3:11 PM
    #118
    foxhead
    foxhead Well-Known Member
    Andrew
    Colorado Springs, CO
    2016 DC Tundra
    I've had two 4.0s and love them both. The 4.0 gets my vote!
  19. Feb 2, 2014 at 10:38 AM
    #119
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    no contest, 3.4. ask any toyota mechanic they will tell u which one can take more abuse and last longer
  20. Feb 22, 2014 at 4:14 PM
    #120
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    This is a funny topic. The motor with more power is stronger? DUH who woulda thought? :rolleyes: Stronger is a relative term. Stronger rods? Stronger pistons? Stronger crank? Stronger all together? Stronger because it'll haul your under geared truck up hills faster? Who knows/cares? This is just a dick swinging competition with bias from both sides since not everyone has owned both and legitimately tested them side by side to see which is "stronger".
    I threw a rod in my 3.4 from over-reving it. I can say I won't be 4.0 swapping it, rather a GM 5.3 swap :p
