Which is better off road?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoseller, Apr 5, 2010.
  1. Apr 5, 2010 at 6:31 AM
    tacoseller
    tacoseller [OP] Member
    Alex
    Houston
    4x4 2.7ltr
    4x4 v6 or or 4cyl, which is better?
  2. Apr 5, 2010 at 7:08 AM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    Well, the v6 simply for the power. But if you're just putzing around on dirt roads you won't notice much difference unless you have different suspension setups...
  3. Apr 5, 2010 at 7:11 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    Redz (and others) might disagree with you.
  4. Apr 5, 2010 at 7:12 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Neither is better... I mean, you would obviously get more power with the V6, but I really doubt a V6 could get somewhere a 4 cyl couldn't.
  5. Apr 5, 2010 at 7:20 AM
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    i would need to know the gearing (which i don't)
    it has nothing to do with power... it has everything to do with gearing.
  6. Apr 5, 2010 at 7:25 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    They both good although V6 gets you more of low end torques.
    My major beef with V6's is that they use timing belts instead of chains. Not the case with our v6 it is using timing chain instead of belt.. :D Thank you Toyota... :taco:
  7. Apr 5, 2010 at 7:29 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    4cyl, because you can get it in a Regular cab = shorter wheel base and better maneuverability.
  8. Apr 5, 2010 at 7:34 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    The 4 bangers have 4.10 gears and the v6 has 3.73.
    I would say a single cab 6 would be optimal. You have the bit of extra power if you need it. Now do you need it thats up to you there are tons of 4 bangers that can go anywhere and have never needed the extra. Alot of times the limiting factor offroad is the driver (not always.)
  9. Apr 5, 2010 at 8:57 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What kind of offroading are you talking about?
    If you're crawling over obstacles/rocks and using 4lo range primarily for most of your offroading - then you don't need power. You need torque/gearing.
    If you're doing a lot of mud holes (and maybe even SAND) and you're using primarily 4hi range - then you'll probably want more power.
    For basic dirt roads - I'd think either one is fine.
  10. Apr 5, 2010 at 10:11 AM
    skunk
    skunk what did I miss?
    Rudi
    SoCal
    2010 TRD 4x4 (STOLEN)
    YOU WILL BE MISSED Satoshi Grill, FX-R retros, husky liners, bed bolt d-rings, TRD short throw shifter, 2.5 Fox Coil overs, AP UCA's, AP Expo rear leaf with Fox 2.0 shocks, Extended SS brake lines, AP kick-out sliders, 265/75/16 on Konig Countersteers, AllPro Apex front bumper and Zip Ties.
    there is no replacement for displacement
  11. Apr 5, 2010 at 10:34 AM
    woodygg
    So Cal
    04 DC Tacoma 4x4
    not for off roading. it's all about gears.
    our old willy's jeep will outclimb just about everything, and it's got the smallest little engine you've ever seen. that thing is geared so low it can crawl up the side of a building (okay... exaggeration.. :) We've gotten that jeep into a place and subsequently stuck somewhere else - that we had to get our CJ with a Ford V8 that couldn't begin to climb up to where it was at. We had to winch the CJ up the side of the hill...
    it's all about gears when it comes to offroad capability.
  12. Apr 5, 2010 at 10:43 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    My vote is for the v6 TRD Off Road model. It has A-TRAC and a locking rear differential. The A-TRAC feature is most impressive.
    The TRD Off Road costs a lot more, but if you intend to Off Road, its worth it IMO.
    Also, for you guys with 4x4 standard cab 09-10. There is a "Yellow Wire Mod" to enable TRAC while in 4 Lo.
    Yellow wire mod for 09-10 non ATRAC tacomas.
    Make your Tacoma unstoppable with Front and Rear LSD in 4Lo
    http://www.tacomaworld.com/forum/tec...4low-trac.html
  13. Apr 5, 2010 at 10:50 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    V6.
    Even the custom buggies that only weigh 2000 lbs and are fully loaded with every custom part one could possibly imagine use bigger engines. So no, it is not simply just about gearing.
  14. Apr 5, 2010 at 10:52 AM
    Pope953
    Pope953 That's a fact Jack!
    Wesley
    Asheville, NC
    SR5 Pickup
    35% up front, 20% in the back window tint, 15" Mickey Thompson bullet hole wheels, with 31x10.5 Firestone Destination A/T tires. Glass Pack, High Flow Cat, S&B CAI, Custom Light Bar with 4 fog lights. 2 10" Rockford Fosgate P2 subs with 1000 watt Rockford Fosgate Amp, CB.
    x2
  15. Apr 5, 2010 at 10:56 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Like other's have said... it depends what your doing.
    However I do disagree that having less power doesn't matter. Having power is never a BAD thing. You might get away without it... but having "excessive" power on tap is always a good thing. You can do stuff with gearing to "gain extra power"... but if you already have the power the gearing becomes less prevalent. It's a balance and each setup would be unique.
    That said, straight out the door from Toyota, the TRD Off-Road (double or access cab) is probably the most capable, if nothing more than because it has the e-locker. You can build any of the trucks to be extremely capable, but the v6 has more power enhancement kits out (note, kits). URD's kit will put down 420hp... if you're out in the dunes that'd be damn fun, damn fun indeed.
  16. Apr 5, 2010 at 10:57 AM
    Blue76
    Blue76 Well-Known Member
    Georgia
    08 Prerunner Double Cab
    Dealer installed Leather, Truck Cover USA roll up cover, Pop n Lock, Bilstein 5100's on 4 corners set at 1.75, Rear Spring TSB. USA Spec iPhone adapter, 265/75/16 Mickey Thompson ATZs.
    Wouldnt an automatic transmission almost negate the gear argument? If a driver of an auto knows what he is doing he has infinate gears to work with doesnt he?
    I have a 76 Bronco with 4:56 gears, 35s, and an auto transmission. It can crawl or it can sling mud pretty well. It has a fuel injected 5.0 H.O. I took out of a 93 Stang with a E303 cam and locked in both ends. I have yet to see the guys with the manuals out crawl my rig when comparable equipt otherwise.
    Greg
  17. Apr 5, 2010 at 11:01 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    X2
    The Off Road TRD only comes with a V-6, so that should tell you
    something right there.
    Active Traction Control (A-TRAC) is amazing!
  18. Apr 5, 2010 at 11:06 AM
    btkicker
    btkicker Well-Known Member
    Denver
    '10 4x4 Reg Cab Manual
    I call BS on the whole V6 being better. You can only get a V6 in a Access Cab or Double Cab. Add the extra engine weight to the AC or DC, and that "extra" power is a huge :yawn:
  19. Apr 5, 2010 at 11:37 AM
    woodygg
    So Cal
    04 DC Tacoma 4x4
    gearing is gearing - regardless of the transmission. you're gears only go so low.
  20. Apr 5, 2010 at 12:20 PM
    akwagon
    akwagon Alaska Dude
    chris
    alaska
    08 Access 5spd 4x4
    5100, kazktin leather, truxedo
    Either would do ok if they were both SR5 trucks (Non-trd).
    What it comes down to is color, the white ones just do better off road :D
