which is the correct 24F battery CCA for 3.4 v6
Discussion in '1st Gen. Tacomas (1995-2004)' started by keakar, Jan 26, 2017.
  1. Jan 26, 2017 at 7:15 PM
    keakar
    keakar [OP] Well-Known Member
    karl
    louisiana
    I see all different batteries CCA listed for my truck
    890/725
    700/600
    650/535
    so which is the correct replacement?
    I don't want a weaker battery then it should have but the charts say any of these batteries will work and I don't like to see such a wide range.
    batteries aint cheap no more so I want to buy what it needs not what fits
    currently right now it has a 890/725 Duracell battery in it but that doesn't mean that's what is supposed to be in it
    asuchemist likes this.
  2. Jan 26, 2017 at 8:18 PM
    TooMuchToDo
    TooMuchToDo Well-Known Member
    2002 Gold Tacoma XtraCab with 192k
    ...we'll get there.
    Are you a cold weather guy?
  3. Jan 26, 2017 at 8:21 PM
    keakar
    karl
    louisiana
    not at all, might get to 30 degrees one or two weeks out of the year
  4. Jan 26, 2017 at 8:55 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Personally I always buy the highest cca battery I can physically fit in my vehicles. I'd rather be over juiced than left stranded. It came in handy this year when we hit -30°F
  5. Jan 26, 2017 at 9:27 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    I go big too reguardless of temp. You'll be fine with any of them though especially with you being down south where you are. I know this doesn't help with your question of what exactly the truck came with but something like CCA specifics are really not necessary... i figure temp and budget are the real factors here.
  6. Jan 26, 2017 at 9:28 PM
    TooMuchToDo
    ...we'll get there.
    I think at positive 30 you don't have much to work about with CCA. 1, it's a measure of cold weather performance ("tested" at 0F) and you're safely away from Arctic temps. 2, in the tests that I've seen battery companies are terrible at report these things. So...It's a bit of a crap shoot no matter what.
    If i were you, i wouldn't cheap out on a battery, but dont let CCA on their own dictate your purchase either. That ability in a battery won't affect you much.
  7. Jan 26, 2017 at 9:58 PM
    keakar
    karl
    louisiana
    I pretty much agree with you guys so I decided to go with the closest to the 890/725 that was in it but I wanted to "know" if that was bigger then stock or the same
    im thinking its bigger, but by how much I wonder?
  8. Jan 27, 2017 at 12:17 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    For what it is worth I always go with the highest output battery I can.
  9. Jan 27, 2017 at 5:58 AM
    keakar
    karl
    louisiana
    ok so nobody really knows the oem battery CCA's?
    not like its that big a deal but I like to know the details on things like that
  10. Jan 27, 2017 at 9:01 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    If the tacoma comes with a Toyota truestart battery originally, the specs should be found here.
  11. Jan 27, 2017 at 9:04 AM
    cruiserguy
    Elijah
    SEKS
    It's a little lower on the CCA than I expected. No harm in going above the original spec'ed CCA rating though. Prolly more important than the CCAs is the quality of the battery. I can't remember who makes the truestart for Toyota. Is it Johnson Controls? Or is it Interstate? I can't memba.
  12. Jan 27, 2017 at 9:43 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I'd be very supprised if your truck came with a 24F from the factory. Most 1st gens came with a group 35.
  13. Jan 27, 2017 at 2:06 PM
    keakar
    karl
    louisiana
    thanks, so if your info is correct, then the oem batteries were originally the 650/535 based on the group 35 battery specs
    that's what I wanted to know, its good to know how much over the oem specs things are when you change parts :cheers:
    now I just got to start reprogramming all my radio stations and I forgot to write them down before I pulled the battery lol :frusty:
