which jack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RDtres, Oct 25, 2012.
whick jack
Poll closed Nov 24, 2012.
  1. rapid jack
    2 vote(s)
    15.4%
  2. high lift jack
    11 vote(s)
    84.6%
  1. Oct 25, 2012 at 9:23 PM
    RDtres
    RDtres [OP] Well-Known Member
    Albuquerque
    2012 Tacoma DC LB
    rapid jack or high lift?
  2. Oct 25, 2012 at 9:50 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    floor jack
  3. Oct 25, 2012 at 9:52 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Outer Space
    x2 on the floor jack
  4. Nov 1, 2012 at 9:38 AM
    RDtres
    Albuquerque
    2012 Tacoma DC LB
    Does anyone have any experience with Harbor Feight's Rapid Jack? 1.5 ton, 3 ton any ton. I'm looking to use it in the garage mostly but I noticed a few rally trucks have aluminum racing floor jacks mounted in the bed. I've always thought Hi Lifts were more versatile but I'm looking for opinions
  5. Nov 1, 2012 at 9:42 AM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    Wyoming
    2012 TRD Off Road Double Cab V6 6Speed
    Stay away from acdelco floor jacks. Garbage internals...
    ~M
  6. Nov 1, 2012 at 10:14 AM
    amadougrand
    amadougrand Well-Known Member
    Southwestern Idaho
    Tacoma TRD Off-Road
    I would say it depends upon the application. I tend to use my hi-lift jack more due to being stuck or in a recovery situation than to change a tire. In that application a floor jack does not get the job done.
    Both jacks have their purpose.
    I would expect a floor jack is more useful to race teams for the speed in which it can be used to change a tire with little risk. It is also more useful for situations that call for the need to wrench.
  7. Nov 1, 2012 at 10:18 AM
    amadougrand
    Southwestern Idaho
    Tacoma TRD Off-Road
    One more thing, the floor jacks my security carries in their B6 Landcrusiers drive me crazy from the rattling even on the smoothest of roads. I am one rattling trip away from loosing it and spraying an entire can of Great Stuff into the gears.
  8. Nov 1, 2012 at 10:21 AM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SP... CaL
    11 TRD sPort
    5100's@1.75 Horns (Andres) Satoshi TRD cat back BHLM
    Harbor freight jack and jack stands
  9. Nov 1, 2012 at 10:25 AM
    TeamLombardo
    TeamLombardo WE'VE LANDED ON THE MOON!
    Tony
    El Paso
    '12 DCSB TRD Off-Road 4x4
    OME 886x, OME Trim Packer, OME Shocks, Dakars, Toytec Shims, LR UCAs, CB Drop, Demello Sliders, Pelfreybilt Plate Bumper, Warn VR8000-s, RI 20" LED, RI Duallys, TRD Exhaust, Weathertech Liners, SS Brake Lines Front/Back, BHLM, Anytime Fogs, CV Boot Mod, 20% Tint, Stubby Antenna, Salex Console Organizer, Derped Grill/Badges
    Hi-lift if you have points where you can place it. Very versatile IMO
  10. Nov 1, 2012 at 10:37 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    depends on the region and what you use the truck for.
    I would never be without a hi lift. for my uses a floor jack is useless.
  11. Nov 1, 2012 at 10:38 AM
    Sandman614
    Sandman614 LRGRNR
    Boone, NC\Garner, NC
    '06 SR5 Off Road
    Harbor Freight for garage/home use
  12. Nov 1, 2012 at 12:44 PM
    BMOC
    Paden
    Phoenix, AZ
    get the arcan jack 99 bucks at cosco. imo
  13. Dec 17, 2012 at 11:27 AM
    RDtres
    Albuquerque
    2012 Tacoma DC LB
    So I finally broke down over the weekend and bought a Harbor Freight Steel 3 ton floor jack with rapid pump for $79.99. This thing is a beast and has a high lift ability. The only con is its weight. Anyhow, I have my hi-lift mounted and have found it to be more useful for off-road etc. while the floor jack is better at home on level ground. I've also added a few pieces of 2x4 to aid in sticky situations, sand, mud, etc. Happy recovering!
  14. Dec 17, 2012 at 2:17 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    Good choice. I also have the HF 3 ton rapid pump floor jack for home use. Yes it's heavy but it's affordable, works fast and has been reliable for me.
  15. Dec 17, 2012 at 2:20 PM
    DHwreckage
    DHwreckage Well-Known Member
    Boulder, CO
    Moby Dick (FZJ-80)
    I actually just picked up a HF 2.5ton rapid jack. So far i like it alot but then again ive only had it for 2 weeks. But realistically you cant beat 79.99 for that Jack!
  16. Dec 18, 2012 at 12:10 PM
    RDtres
    Albuquerque
    2012 Tacoma DC LB
    Agreed!!! you can't beat the affordability of HF.
  17. Apr 10, 2013 at 1:09 PM
    gt40
    gt40 Well-Known Member
    Georgia
    11 SR5 4X4 SB TOW PKG.
    I have an Avid light bar with an extra bar in the middle and was wondering if it is strong enough for lifting with a high lift jack? Or should I get an attachment that bolts to the light bar and then hook the jack to it? :confused:
  18. Apr 10, 2013 at 1:23 PM
    CLODHOPPER
    CLODHOPPER Well-Known Member
    EDMONTON, AB
    05 tacoma
    Chrome black mesh grill, Devil horns taco emblem, Halo Headlights/HID's 8000k, Snow Camo back window decal, Hard top Tonneau cover, Zone 6" suspension lift, Fuel Tri Ace 35x12.5R18's on pro comp rims.
    Jack?? I just use my thighs, back, and buns of steel to lift my truck up... :rofl:
  19. Apr 10, 2013 at 1:28 PM
    Bubbarr
    Bubbarr Monkey Sweat
    Duane
    SD
    TRD Off-Road 4X4
    DynoLock Auto tailgate lock, 16" Konig Counter steer Off roads, 265/75/16 Goodyear Wrangler Duratracs, 2.5 King front and rear with remote reservoir, Built Right UCA, Deaver 3 pack, SD Truck Shop Custom Sliders.
  20. Apr 10, 2013 at 2:14 PM
    Jetman1979
    Jetman1979 Well-Known Member
    Michael
    North Texas
    2009 tacoma 4X4
    Is the rapid jack from China? Most stuff from HF is.
