Which King Springs?
Discussion in 'Suspension' started by Car1, Mar 24, 2021.
  1. Mar 24, 2021 at 2:09 AM
    Car1
    Car1 [OP] Well-Known Member
    I'm wondering how to swap springs on a Tacoma. For example, when looking at King springs it has 2.0, 2.5, 3.0, and 3.75 springs. I figured that this number corresponded to the inches of loft that you wanted, but then it has a lot of other information. For example, 3.0x14x250 and is for 2.5 shock bodies. The last number is the weight per inch, but then the first number is the inches lifted? And what's the middle number? Also, what's a shock body?
  2. Mar 24, 2021 at 3:31 AM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    3.0x14x250 (using as an example)
    3.0
    Inner diameter of coil spring
    14 Length of coil spring
    250 Spring rate
    whatstcp likes this.
  3. Mar 24, 2021 at 3:44 AM
    Car1
    So can I choose any diameter and length, or which diameter and length does the Tacoma use? If I use a longer spring it lifts the vehicle?
  4. Mar 24, 2021 at 3:55 PM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    3.0 x 14" x 700lb is pretty standard. Long spring wont fit and is not the main way to get lift.
    https://accutuneoffroad.com/tacoma-4runner-faq/
  5. Mar 24, 2021 at 5:33 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    May I ask why you are looking at springs and what your overall goal is? Typically the spring is bought as a pair with the shock (aka a coilover). In that case you typically only need decide on whether you want a 600, 650, or 700 lb/in spring. Length and diameter are already figured out for you by selecting the make, model, and year of your truck.
  6. Mar 24, 2021 at 5:40 PM
    cmbondo
    cmbondo Well-Known Member
    San Diego CA
    2021 Cement DCSB TRD Offroad
    FOX 2.5 DSC and some other stuff too.
    It sounds to me as you are trying to put King springs on stock (or similar) suspension to achieve lift. This will not work. These type of springs are made to work with aftermarket coilovers. You should be looking at OME springs or similar.
    gudujarlson likes this.
  7. Mar 24, 2021 at 8:36 PM
    Car1
    Yes, that was my goal, to swap the stock springs with King springs with extended travel to achieve a lift.
  8. Mar 24, 2021 at 8:39 PM
    Car1
    It's not the main way to get a lift? I've been reading that a coilover with an extended spring is the optimum way to get a lift as a spacer limits downtravel and a coil spacer limits uptravel.
  9. Mar 24, 2021 at 8:41 PM
    Car1
    On something like the Rough Country 6" adjustable vortex coilovers is the lift obtained through the extended springs? Or does it even have extended springs? Or does it use stock length springs and just stretches them to get the 6" lift?
  10. Mar 24, 2021 at 8:44 PM
    MSN88longbed
    MSN88longbed Sporty Shorty
    Goleta, CA
    2014 Single Cab 4x4, Auto, Blinding White
    Kings all around, Method 306, Cooper STT Pro 265 75/R16, JBL amp, Morel Speakers, Undercover tonneau, Alcan leafs, SOS sliders, RCI skids, SSO Slimline, Engo winch.
    This will not work. You will have to replace the entire coil-over with something that lets you achieve your desired result.
    MrTreehorn and Island Cruiser like this.
  11. Mar 24, 2021 at 8:56 PM
    cmbondo
    San Diego CA
    I think you are misunderstanding. Yes an extended spring (along with spring rate) like OME springs do provide the lift when using a strut assembly such as a Bilstein 5100. If you are using a coilover such as King or Fox, lift is achieved with preload on the spring. Generally, the spring length on a coilover is a set length based on the manufacturer specs. Lift is then achieved with a combination of preload and spring rate based on the weight of your truck. These 2 setups are completely different in concept. Please do some reading on the link provided by @AccuTune Offroad. They know what they are talking about and have several educational articles on their site.
