Which leaf springs??
Discussion in 'Suspension' started by canucklehead, Mar 7, 2010.
  1. Mar 7, 2010 at 4:50 PM
    canucklehead
    canucklehead [OP] Well-Known Member
    sunnyvale, ca
    05 Tacoma reg cab 4x4
    alright so i installed 5100's in the front and rear. fronts are set at 1.75". i have the reg cab with the crappy 3-leaf so i want to upgrade my rear leaf springs. i've looked on wheelers and came across the deaver 10-pack and alcan 8-pack.
    deavers: 1-1.5" lift
    alcan: 1.75-2"
    which springs should i go with to get the stock rake look?
    thanks
    heres a pic of my truck with 5100's 1.75" front and stock 3-leaf rear:
  2. Mar 7, 2010 at 4:55 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Id say the deavers
    1.5 should put you about level
  3. Mar 7, 2010 at 5:17 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    If you want the stock rake , and you went up 1.75 in the front , wouldn't you want to go up the same in the back ( 1.75 ) ? With your canopy weight you could probably go up 2" in the rear and get the stock rake ,
    OZ
