Which leaf to remove from OME Dakar leaf pack
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoma725, May 19, 2012.
  1. May 19, 2012 at 9:47 PM
    tacoma725
    tacoma725 [OP] New Member
    Luke
    Pagosa Springs Colorado
    96 2.7L Tacoma
    2.5 lift ARB Bumper
    I about a 2 inch lift on the from and am hoping to get my OME leafs on clean the first shot. Anyone have any suggestions on which leaf(s) or overload springs to remove? Also apart from the two smaller retaining clips on the top three leafs, there is a larger clip over 5 of the 6 leaf/overloads springs, what do i do with this?
    Thanks
  2. May 19, 2012 at 10:12 PM
    chilidogrc
    chilidogrc Play stupid games, win stupid prizes
    Rodrigo
    San Diego
    2016 4Runner
    Just tackled this today with the help of 4wd(Doug). If the first gen dakars are anything like the second gen, then you can only remove the longer overload. As the larger retaining clip is attached to the shorter(bottom) overload.
    So, undo the retaining clips, unbolt the center pin, and remove the longer overload. put everything back together and you should be good to go. Hope this helps
    Jeffrow20111 likes this.
  3. May 19, 2012 at 10:43 PM
    tacoma725
    Luke
    96 2.7L Tacoma
    2.5 lift ARB Bumper
    Yeah that helps. Also do you know if my existing shocks will work still? Their fairly new and i don't want to replace them yet if i don't need to. They are just generic autostore shocks that fit factory, seemed to work ok with my last pack that had an AAL but was sagging.
  4. May 19, 2012 at 10:53 PM
    chilidogrc
    Rodrigo
    San Diego
    2016 4Runner
    Depends on what the extended and collapsed length are for your shocks. Im sure there are others out there running dakars on a first gen that will chime in.
  5. May 19, 2012 at 10:58 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    HA! , dejavue.... just did it
    Depends, whatcha runnin' now ??
  6. May 19, 2012 at 11:26 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Actually on the 2nd Gens , ARB recommends removing the third leaf down from the top , not the overload(s)
  7. May 20, 2012 at 8:34 AM
    chilidogrc
    Rodrigo
    San Diego
    2016 4Runner
    Well, I didn't want to effect the ride, just loose a little bit of rake that I had. Plus, no more squeaking :yay:
  8. May 20, 2012 at 8:39 AM
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    Maybe silly question but: why are you removing leafs from the pack? Is is just to drop the lift height a little?
  9. May 20, 2012 at 8:41 AM
    chilidogrc
    Rodrigo
    San Diego
    2016 4Runner
    Just one of the overloads. Dakars have two. And yes, just for ride heigth.
  10. May 20, 2012 at 9:17 AM
    OZ-T
    Peter North
    British Columbia
    Interesting
    My Dakar squeak has always originated where the leafs wrap the front hanger and there is no isolator
  11. May 20, 2012 at 11:03 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Probably dirt,small pebbles, midgets, etc;.. you'd be amazed at what works their way between leafs
  12. Apr 20, 2013 at 7:22 AM
    anamorphic
    anamorphic Well-Known Member
    08 TRD Sport 4x4
    How much height to you lose by removing an overload?
    I'm having Dakars installed today and trying to figure out if it's going to look ridiculous with the front setup I have. 5100's @1.75
  13. May 4, 2013 at 7:13 AM
    MY50cal
    MY50cal - IPFK -
    Mojo
    Chester County, PA
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    ^ currious myself. Ill have to take one out when I do the shackle flip. Anyone done this recently?
    Bump the old thread!
  14. May 4, 2013 at 8:51 AM
    chilidogrc
    Rodrigo
    San Diego
    2016 4Runner
    However thick the overload is. 5/8? 3/4? Not sure
  15. May 4, 2013 at 8:56 AM
    OZ-T
    Peter North
    British Columbia
    This
    You would lose the thickness of the overload , approx 5/8"
  16. May 4, 2013 at 9:01 AM
    chilidogrc
    Rodrigo
    San Diego
    2016 4Runner
    Your dakars still squeaking on ya a little?
  17. May 4, 2013 at 9:08 AM
    OZ-T
    Peter North
    British Columbia
    Since I did my EPDM strips , they only squeak when it's dry and they get covered in fine dirt or grit , hosing them out clears that up
  18. May 4, 2013 at 9:11 AM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    http://www.tacomaworld.com/forum/2nd-gen-builds/43696-begins-miss-blue-41.html#post5696079
