Which lift is best? Help.
Discussion in 'Suspension' started by gospurs21, Feb 18, 2014.
  1. Feb 18, 2014 at 10:44 AM
    gospurs21
    gospurs21 [OP] Well-Known Member
    Brownsville, Texas
    05 x2 Cab Texas Edition V6 prerunner, TRD
    Ive been looking for a 3" lift kit for a while now. I came across a rough country 3" lift. which i heard from a friend who had a 7 1/2" lft on his Silverado that it was good and he didnt have a crappy ride at all, i also came across an OME 3" comes with front spacers,coilovers, and two 2" AAL but with the OME will i have to get new shocks since it comes with coilovers or can i use my stock shocks? Both are reasonable prices here are the links to both of them, thanks! (If yall have other suggestions on other lifts (in the same price range $200-350) can you please share as well?) i heard front Bilstein 5100s and rear 2" AAL is best. Anyone know how much that would cost for just the parts?
    Here are the links to the ones im looking at
    http://bilsteinlifts.com/shop/05-and-up-tacoma/3-lift-with-front-coils-rear-options/#tab-faqs
    http://www.roughcountry.com/toyota-suspension-lift-kit-745n2.html
  2. Feb 18, 2014 at 12:04 PM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    Tons of reseach can be done to get you closer where you want to go. I would tell you that out of the two links you have, the first one is best.
    You will not want spacers and blocks. Crappy ride and axle warp issues.
    If it were me, I would go with springs that provide the lift, not the shocks or spacers. In the back, new leaf pack or AAL, not blocks.
  3. Feb 18, 2014 at 12:05 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    The blistein lift is a coil lift. it will ride much better then the rough country spacer lift.
  4. Feb 18, 2014 at 12:20 PM
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    Definitely avoid using blocks and spacers. You will be happier with the end with a good set of springs front and rear.
  5. Feb 18, 2014 at 12:36 PM
    gospurs21
    Brownsville, Texas
    Will i need to get new shocks?
  6. Feb 18, 2014 at 12:40 PM
    Mademan925
    Nick
    Discovery Bay, CA
  7. Feb 18, 2014 at 12:41 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    No you can use stock shocks but upgraded ones are preferred.
  8. Feb 18, 2014 at 12:44 PM
    joshipps
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    Since you'll be in there with everything torn down anyway, it wouldn't hurt to go ahead and put new ones in. I wouldn't want to risk over extending the stock ones or something of the sort. I'm sure someone with more knowledge on this will chime in.
  9. Feb 20, 2014 at 12:37 AM
    gospurs21
    Brownsville, Texas
