Which lift is best
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The Tricky Jew, Sep 3, 2014.
  1. Sep 3, 2014 at 5:34 PM
    The Tricky Jew
    The Tricky Jew [OP] Member
    I've got myself a 2006 5 lug 2wd. I need to lift a few inches like 2-3 to fit bigger tires on it... Ive heard of fat bobs, rough country, and pro comp, which is best for the job. I do minimal off road driving mostly on road. How do these compare by difficulty to install as well?
    Thanks
  2. Sep 3, 2014 at 5:37 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Those are on the cheap end and really are "you get what you pay for lifts". Look at Bilstein 5100's or OME.
  3. Sep 3, 2014 at 5:39 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    5100s are also get what you pay for. Preloading springs isn't correct, even if popular.
    OP, try looking in the 5 lug tthread, lot of nice stances in that area.
  4. Sep 3, 2014 at 7:14 PM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Just put 5100's on front adjusted to 2" can clear 265/70/17 with mudflaps and 285/70r17 without mud flaps
  5. Sep 3, 2014 at 7:21 PM
    The Tricky Jew
    What's the difference between 5100 and 4600? The website says 4600 fot
