Which Lift Kit is Better and Why?
Discussion in 'Suspension' started by Moss1979, Feb 16, 2014.
  1. Feb 16, 2014 at 7:16 AM
    Moss1979
    Moss1979 [OP] Member
    Utah
    06 Tacoma 4 Dr.
    TRD Cold Air Intake
    I am looking to just lift my 2006 Double Cab Tacoma. I have looked at the Rough Country SST lift kit for $249.00 or the Ready Lift for $249.00. I already have aftermarket Belstine front shocks on but not sure how old or what model. They were on when I bought the truck. The Rough Country comes with N2.0 series shock absorbers.
    Does anyone have experience with either one of these lifts? Which one would you recommend and why? Or is there another lift kit you would recommed around the same price range? Looking to stay round $350ish.
    Ready Lift
    http://www.readylift.com/products/toyota/toyota-tacoma-prerunner/sst-lift-kits.html
    Rough Country
    http://www.roughcountry.com/toyota-suspension-lift-kit-745n2.html
  2. Feb 16, 2014 at 7:17 AM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    Neither..
    spend a little more and buy Bilstein 5100s and an AAL
  3. Feb 16, 2014 at 7:20 AM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    Not a expert but, from what i have learned here if you don't want to screw stuff up, and don't want a terrible ride, your gonna need to depend maybe 600$
  4. Feb 16, 2014 at 7:22 AM
    Moss1979
    Utah
    06 Tacoma 4 Dr.
    TRD Cold Air Intake
    Sorry not to knowledgeable in this area what is AAL?
  5. Feb 16, 2014 at 7:28 AM
    Monster Coma
    Corey
    Add a leaf
  6. Feb 16, 2014 at 7:29 AM
    Moss1979
    Utah
    06 Tacoma 4 Dr.
    TRD Cold Air Intake
    Thanks Monster Coma. I have heard that AAL makes for a rougher ride is that not true?
  7. Feb 16, 2014 at 7:32 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Welcome to TW
    Most people on here will advise to stay away from spacer lifts and lift blocks. Spacers in the front limit the travel and often cause the shock to break.
    See pic here
    I would save up and get this lift: http://toyteclifts.3dcartstores.com/Bilstein-Adjustable-lift-kit-with-5100-shocks_p_132.html
    MUCH better than spacers and blocks and will not cause issues mentions above.
    Also, here is a guide to the various types of lift kits and their pros and cons:
    http://www.tacomaworld.com/forum/suspension/142677-suspension-lift-info-includes-pics.html
    Hope this helps.
  8. Feb 16, 2014 at 7:35 AM
    Monster Coma
    Corey
    Not the one I posted. If you bought a single leaf AAL that was 2" thick then yeah I can imagine it would. I have the AAL I posted and it rides just fine
  9. Feb 17, 2014 at 10:45 AM
    Moss1979
    Utah
    06 Tacoma 4 Dr.
    TRD Cold Air Intake
    Is that a pretty easy install geekhouse23? How many hours would you say it would take for someone that has never done something like this before?
  10. Feb 17, 2014 at 10:54 AM
    Monster Coma
    Corey
    Buy some beer, some pizza, get friendly with people in your area on TW. Really simple then :)
  11. Feb 17, 2014 at 5:13 PM
    Donald Brandon
    Donald Brandon New Member
    Donald
    Florida
    2011 prerunner access cab 2.7
    Was considering lifting my 2011prerunner 2.5 inches in front to accommodate for a larger 265/75-16 from the stock 245/75r16 tire with aftermarket wheels. Will the truck sit pretty level without doing any thing to the rear
  12. Feb 17, 2014 at 5:18 PM
    Monster Coma
    Corey
    265/75/16s will fit without lift. But if you are lifting 2.5" in the front I'd recommend a .5-1" lift in the rear as well
    Bilstein 5100s set at .85 will keep your truck level without an aal or set them at 1.75 with an aal
