Which Lift Should I install?
Discussion in '1st Gen. Tacomas (1995-2004)' started by veg hed, Mar 20, 2010.
  1. Mar 20, 2010 at 3:16 PM
    veg hed
    veg hed [OP] Well-Known Member
    Grand Teton, WY
    04 Toyota TRD SR5 V6 Access Cab
    Bilstein 5100s, Toytec 620 springs, OME Dakar Leafs, ARB Bumper, Warn 8000 Winch, Grey Wire Mod.
    I recently bought a nice 2004 Tacoma with 21,000 original miles on it. I have been reading a lot about lifts and just want to get an overall feel of what lifts people out there like.
    I talked to the dealer and I can get a Toytec 3 inch lift installed. I think it is the AAL. But I have been reading a lot on this forum and just want an idea of what else is out there.
    Also, how benificial are the Bilstein 5100's and can I use them with a Toytec lift or should I not even bother?
    And will a 3'' lift affect my gas mileage, even if I keep the tires stock?
    Thanks for the help...
  2. Mar 20, 2010 at 4:43 PM
    chazjb
    chazjb Well-Known Member
    James
    Oregon
    Deck plate mod, Magnaflow exhaust, Toytec 3in lift, Bestop canopy, Spray on bedliner across the bottom foot of the truck and fenders. HID 6000k 85W converted Hella 500's & 4000's, HID headlights 5000k 35W. Custom build roof basket, Pioneer Avic-x920bt deck with rockford amp and kicker sub.
    i have the toytec 3in and i really like it. my only down fall is i should have done a 6in lift. but yes your mpg is going to go down but not much... only a mile or two PG if that. mine only went down 3ish mpg and i added 33/12.5. so i wouldnt let mpg bother you too much. also i have read and heard good things about the toytec so IMO get it
  3. Mar 20, 2010 at 4:58 PM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    sweet taco. 21k mi. saawwweeeeeeeeeeeeet!!!! wanna sell it? J/K. welcome to TW
  4. Mar 20, 2010 at 5:13 PM
    veg hed
    Grand Teton, WY
    Thanks...No I can't sell it. I looked forever for a nice Tacoma with lowish miles. I hope to put 200k on this rig and don't plan on selling or upgrading to a 2nd gen for at least 10 years. Now that I got the rig I want it's time to accessorize...:D
  5. Mar 20, 2010 at 7:48 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    your mileage wont go down If you keep your tire size. Although it will look funy, and you wll quickly want bigger tires. :)
    Nice find by the way!
  6. Mar 21, 2010 at 2:09 PM
    veg hed
    Grand Teton, WY
    All right...So is there a 2" lift I could do instead that wouldn't look as funny? As many 1st gens my taco sits higher in the back. I'd like to at least level it out but would also consider an AAL or 5100's.
    Will 5100's all around lift it 2" and level it out?
    Thanks...
  7. Mar 21, 2010 at 4:02 PM
    ETaco23
    Evan
    PNW
    You can still do the 5100's all around, And do an 1" AAL or block like mine in the rear and set the front to 1.75" lift in the front. And that will level you out pretty good, and still look good with the 265's. But If you want the front to be exactly 2" then you could throw in a 1/4" top plate spacer that ToytecLifts.com sells.
  8. Mar 22, 2010 at 6:55 PM
    veg hed
    Grand Teton, WY
    What's a block?
    If I set my shocks to 1.75 how will that affect my ride?
    And where is the best place to pick up some 5100's?
  9. Mar 22, 2010 at 7:15 PM
    ETaco23
    Evan
    PNW
    Well a block is baically a spacer block that you put under your leaf springs to lift the truck. I would NOT recommend anything over 1" lift for blocks. Just bc they can cause more axle wrap and wear out your springs quicker. But a 1" should be just fine.
    the 5100's should ride pretty good at the 1.75" lift, it might a little stiffer but not bad.
    And alot of places are all on backorder. but the best place to get them would be DownSouthMotors, they're a vendor here on TW.
  10. Mar 22, 2010 at 7:24 PM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    5100's are good. If you want a full 3 inch lift and dont mind a rougher ride then the spacer lift would be fine. Gas mileage has nothing to do with lift, how much tire is needing to be pushed around is what determines mpg. the larger and wider the tires the more gas it takes to get those tires rolling and up to speed.
