Which Lift?
Discussion in 'Suspension' started by CJH9980, Nov 29, 2009.
Which lift?
Poll closed Dec 29, 2009.
  1. #1 Bilsteins all around w/ fronts set at .85 with eibach springs, and toytec all in back
    6 vote(s)
    16.2%
  2. #2 OME 3" suspension lift from toytec
    31 vote(s)
    83.8%
  1. Nov 29, 2009 at 2:39 PM
    CJH9980
    CJH9980 [OP] Well-Known Member
    Clint
    Shreveport, LA/Tucson AZ
    2018 TRD PRO
    Wescott lift Wescott rock sliders Prinsu Cabrack SpartanXcustoms skewp light Demon Hook front recovery point Diamondback SD (just shipped) N2 Designs Remote Start A few meso goodies
    Trying to choose a lift for my 2010 4x4 DC. Here are the two I have it narrowed down to:
    Build #1
    Bilstien 5100 all the way around, with the fronts set at .85
    Eibach coils in the front
    TSB(hopefully) and toytec aal in back
    Build #2
    Any input is appreciated!
  2. Nov 29, 2009 at 2:52 PM
    Dashe
    Dashe Well-Known Member
    David
    Charleston
    Black Double Cab SR5 4x4
    debadged, Grillcraft grille with FJ emblem, KC SlimLite Driving Lights behind grille, Bilstein 5100's, Eibach 1.6" lift springs, add-a-leaf, Pro Comp 7089 wheels, BFGoodrich A/T 285/75/16, Dynomax Super Turbo muffler, CB with Wilson Flex antenna
    i voted for number 2, because i cant read, and didnt notice that you listed the eibach springs. i actually have exactly the same setup you listed for build #1. i have been very happy with it so far. for either one of these, though, make sure you get some aftermarket uca's.
  3. Nov 29, 2009 at 3:03 PM
    Dashe
    David
    Charleston
    just speaking from my own experience. i suppose you could wait and see if you have alignment issues after the lift, but i will be surprised if you dont.
  4. Nov 29, 2009 at 3:13 PM
    cheehab
    cheehab I bleed Black and Gold
    Adam
    Winter Park, CO
    2015 Tundra TRD Pro CrewMax
    I voted for #1 because I like my Bilstein setup, but I'm on stock coils. To tell you the truth, I'm not sure I even understand how the eibach springs add lift.
  5. Nov 29, 2009 at 3:29 PM
    CJH9980
    Clint
    2018 TRD PRO
    I'll check into ucas if I have issues. Hopefully it won't be a problem!
  6. Nov 29, 2009 at 3:32 PM
    CJH9980
    Clint
    2018 TRD PRO
    I HOPE this is the case!
  7. Nov 29, 2009 at 4:03 PM
    Dashe
    David
    Charleston
    my caster was off enough to really screw up my ride quality. youre lucky to have not had serious problems with yours. i suppose there is no hard and fast rule about alignment issues with this kind of lift. didnt mean to give false information, just providing my experience. sorry if there was any confusion.
  8. Nov 29, 2009 at 4:33 PM
    taco157
    taco157 Active Member
    Brian
    Nova Scotia, Canada
    06 D-cab White
    2.5" Lift
    I dont want to jack this thread but i was wondering, i've heard of driveline vibrations from the 3" lifts... i also want one probably the #2 kit listed here. Are the rumors true?
  9. Nov 29, 2009 at 10:13 PM
    CJH9980
    Clint
    2018 TRD PRO
    Have any of you guys used a 1/4" top plate spacer to correct the "taco lean"? I know you're not supposed to use spacers with the 5100s, but one that small couldn't cause too much of a problem it seems
  10. Nov 29, 2009 at 10:14 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Ome ftw!
  11. Nov 30, 2009 at 8:20 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    I voted OME because when my truck in paid off in a few years thats the route I am going. I currently have the Eibach springs in the front and I like the ride but was hoping for a little more lift out of them. I also just ordered the 1/4 spacer to correct the taco lean.
  12. Nov 30, 2009 at 1:22 PM
    CJH9980
    Clint
    2018 TRD PRO
    Are you running the eibachs w/ your 5100s at .85 setting?
  13. Nov 30, 2009 at 1:37 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I'd go with OME, just my opinion.
  14. Nov 30, 2009 at 1:48 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    Some have and some don't. I have DC LB and I don't have vibration issues.
  15. Nov 30, 2009 at 2:45 PM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    I voted for #2 but if budget is a concern #1.
    With things the way you have them set up, you may need new UCA's to get alignment into spec...that will cost an extra $339-$669.
  16. Nov 30, 2009 at 3:32 PM
    CJH9980
    Clint
    2018 TRD PRO
    I'm going to get the lift on first, then see if i have to have the UCAs. I'm assuming that I'll need them though.
  17. Nov 30, 2009 at 3:34 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    I really like the OME kit and wish now I had bought it instead of what I have now, but I still really like my set up
  18. Nov 30, 2009 at 5:03 PM
    Burns
    17 DCSB Off-Road
    I am running the stock TRD billys and I only got maybe and inch of lift with the Eibachs.
  19. Nov 30, 2009 at 5:51 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    The full OME kit from Toytec comes with a trim packer for that.
  20. Nov 30, 2009 at 5:57 PM
    CJH9980
    Clint
    2018 TRD PRO
    Thansk for all the replys guys. I'm pretty much leaning toward the OME now. Just waiting to see what the dealership is going to decide as far as my rear leaf TSB so I make sure and get the correct AAL.
    I almost want to just say F*** it and get the dakar for the back, but i'm going to wait and see what they decide.
