Which Lugs to Buy - RRW Wheels/3rd Gen Tacoma
Discussion in 'Wheels & Tires' started by BugJuice, Mar 16, 2023.
  1. Mar 16, 2023 at 1:57 PM
    BugJuice
    BugJuice [OP] Well-Known Member
    Hello,
    Just realized my stock lug nuts won't work with my new RRW RR7-H wheels. What lug nuts are recommend for these? I've been searching online and it appears locking lug nuts are up for debate if they are worth it or not. Seeing brands such as Gorilla Automotive and McGard. Even on their site there is a lot of options. Any advice is helpful. Thanks!
  2. Mar 16, 2023 at 2:44 PM
    Clearwater Bill
    Billy
    Largo Florida
    Whatever a RRW RR7-H wheel is, wouldn't the manufacturer be who to ask? Or at least the vendor you bought through?
  3. Mar 16, 2023 at 3:16 PM
    BugJuice
    The lugs they sell are out of stock.
  4. Mar 16, 2023 at 3:53 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Huh, the Relations Race Wheels web links are not liked on TW
    https://www.***********************...dlock/products/pre-order-rr7-h-tacoma-4runner
    https://www.***********************/pages/faq
    "Will my stock lug nuts work with your wheels?
    - NO. All of our wheels require aftermarket lug nuts 12x1.5 that are conical seating with a 60 degree taper
    What's the difference between ET and non-ET lug nuts?
    • We offer ET lugs in a 12x1.5 thread length for the Tacoma, 4Runnera dn GX. It's a known issue that these three vehicles haveshort wheel studs.Upgrading to aftermarket wheels causes the lug seating to change to a conical seating, which then results in less thread engagement than what the factory wheels and lug nuts can obtain.
    • By using our ET lug nuts, the shank of the lug nut fits snugly into the wheel's lughole resulting in more thread engagement and a better peace of mind.
    • Another benefit is the wheels are now not only hub-centric, but also lug centric. Using ET lug nuts provides the same amount of wheel securement that a factory OEM wheel/lug nut setup would supply. "
    https://www.***********************/collections/lug-nuts/products/hex-closed-end-lug-nuts
    Nuts all day long:
    https://lugnutguys.com/pages/search...ion=lug-nuts-et&page=1&rb_snize_facet2=12x1.5
    https://www.alphawausa.com/products...orn-lug-nuts-12x1-5-for-aftermarket-wheels-60
    https://www.coyoteaccessories.com/lugs/lug-nuts?lug_style=2201&lug_thread=378
    https://shop.wheelacc.com/12x15-black-et-lug-nut-single-p6831.aspx
    https://jdcustomsusa.com/products/jdc-evo-8-9-titanium-lug-nut-set-m12x1-5mm
    https://www.chasingjs.com/product/chasing-js-closed-end-titanium-lug-nuts
    https://www.chasingjs.com/product/chasing-js-titanium-extended-closed-end-lug-nuts
    Clearwater Bill likes this.
  5. Mar 16, 2023 at 3:56 PM
    Clearwater Bill
    Billy
    Largo Florida
    So they won't tell you the specs you need to shop another brand?
    Thread, length and seat type?
    And splined lugs are kind of locking, because a tool is needed, but easy to defeat if the thrift has the tool or the time to use an alternate.
    Traditional locking lugs (one per wheel, clover style key) only deter 12 yo kids who aren't running with 15 yo 3rd offenders. IE really easy to defeat.
  6. Mar 16, 2023 at 3:57 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Not these remove spaces https://www. relations race wheels. com /collections/lug-nuts/products/hex-closed-end-lug-nuts
  7. Mar 17, 2023 at 11:00 AM
    BugJuice
    Aftermarket wheels and lugs are new too me. Thanks for sharing the links @eurowner . What's confusing to me is the concept of extended threads in this case.
    Wouldn't the lug nut use all of the threads on the stud since the required lug nuts require a conical seating with 60 taper? Sounds like the lug nut would seat all the way up to the hub?
    Maybe I'm misunderstanding something. I understood (M12x1.5) to be a 12mm diameters with 1.5 being the pinch. Not sure how I can make sure I'm getting extended thread.
    @Clearwater Bill is there any other locking system you recommend?
    • NO. All of our wheels require aftermarket lug nuts that are conical seating with a 60 degree taper. This is a standard size for many aftermarket wheels.
    Aftermarket lug nuts are more compact and use a smaller hex socket, which greatly reduces the possibility of scratching your wheels paint when installing and removing the lug nuts.
    Be sure to check the size of your vehicle's studs before purchasing lug nuts. The 3 most common sizes that we sell are:
    1.) 12x1.5 (Tacoma, 4Runner, Lexus)
    2.) 14x1.5 (Tundra, Chevy, F150, F250, Ram 1500/2500, Silverado 2500/3500)
    3.) 12x1.25 (Subaru)
    • We offer ET lugs in a 12x1.5 thread length for the Tacoma, 4Runnera dn GX. It's a known issue that these three vehicles have short wheel studs.Upgrading to aftermarket wheels causes the lug seating to change to a conical seating, which then results in less thread engagement than what the factory wheels and lug nuts can obtain.
  8. Mar 17, 2023 at 11:46 AM
    eurowner
    eurowner Duke Sky
    Scoty
    I sentences I posted and you quoted are off RRW Website. Tacoma is 12mm x 1.5mm wheel stud size.
    Extended
    NOT extended
    Stock Tacoma wheel nuts are extended Not 60* tapered.
  9. Mar 17, 2023 at 3:41 PM
    Clearwater Bill
    Billy
    Largo Florida
    Not any I know about.
    To me they are like alarm systems. Not very useful.
  10. Mar 18, 2023 at 2:25 AM
    SuperAir
    SuperAir Well-Known Member
    Maine
    19 TRD ORAC Cement
    Eibach Stage 1, 17x8.5 Ray 10s, 265/70-17
    Discount Tire likes this.
  11. Mar 19, 2023 at 9:42 AM
    BugJuice
    Ordered these! Thanks
