Which octane is everyone using
Discussion in '3rd Gen. Tacomas (2016-2023)' started by yoda16, May 29, 2016.
  1. May 29, 2016 at 8:15 AM
    yoda16
    yoda16 [OP] Member
    2016 SR5 tss 4x4
    None
    just curious which octane y'all are running.we don't have 91 octane around here,so it's either regular 87 or premium 93.i noticed the manual stated they tested the truck using 91.
  2. May 29, 2016 at 8:19 AM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
  3. May 29, 2016 at 8:24 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    I've used 87-93. They all ran the same and got same mileage. So I stick to shell or BP 87 now
  4. May 29, 2016 at 8:25 AM
    BrettsMac08
    BrettsMac08 Well-Known Member
    Kansas
    2016 DCSB TRD Sport | 2002 Camaro SS
    KDMax Tuned | MagnaFlow Exhaust | OEM Audio Plus Reference 450Q | TRD Pro Wheels | AT Tires | LED Interior Lighting
    So far the entire time I've owned a vehicle (Gen 1 Tundra, Gen 2 Tundra, Gen 3 Tacoma) I've never pressed anything but the regular 87 button and I've yet to have an issue with that.
  5. May 29, 2016 at 8:33 AM
    choupick
    choupick Double Secret Probation
    The south
    2016 DCSB TRD SPORT 4X4 MGM
    Dents in roof from poorly loaded canoe. Broken side mirror from blown transfer truck tire. Scuffed up front bumper from thinking I was still in a corolla. Graham cracker embedded upholstery from a crazy kid.
    I'm going to try and test everything we have local, both with and without ethanol. I'm using 93 ethanol free right now and I can't tell a bit of difference over 87 ethanol free. Both of the ethanol free fill ups (I'm on #3 ethanol free now) did a little better than the 87 with ethanol for MPG. I'm going to try a few runs of 93 with ethanol next. I haven't really done the math for cost effectiveness yet. I need more data.
    I'm going to try to have a few runs in both a hot and cold weather with both grades of ethanol free I can get and all three grades of ethanoled gas. Plus I plan on doing an experiment with name brand premium fuel vs cheapie premium fuel.
    FeraNatura, yoda16[OP] and DrFunker like this.
  6. May 29, 2016 at 8:43 AM
    JQ3
    JQ3 Well-Known Member
    I used both 87 and 93. It seemed that I got better mileage with the 93. I never saw a difference when I had my Tundra...go figure.
  7. May 29, 2016 at 9:20 AM
    flesheatingvirus
    flesheatingvirus Well-Known Member
    ABQ, NM
    2016 TRD-OR 4x4AT Access Cab - Magnetic Gray
    Tech Package
    I use the cheapest gas I can find because it makes my truck go. That's why I put gas in there.
  8. May 29, 2016 at 10:13 AM
    OnceARunner
    OnceARunner War Eagle!
    Georgia
    2016 DCSB TRD Sport Tacoma
    87...scientifically anything else is a waste of money. But if running something higher makes you happier, go for it.
    ndavid2, ghostleaf, David K and 13 others like this.
  9. May 29, 2016 at 10:20 AM
    DrFunker
    DrFunker Well-Known Member
    Always ran the cheapest, until I tried some 91 EF (last week).
    Gotta say....the truck runs better and is more efficient on it. Not sure if it is the 91 or the EF. I am sure the combination of both help.
    Going to run some 91 ethanol just to see what results I get.
  10. May 29, 2016 at 10:39 AM
    R2D2
    R2D2 Well-Known Member
    2016 MGM DCSB 4x4 Limited
    Towing package
    If you get the same mileage with 87 and 93, it's a no-brainer. 93 is average $0.40 more expensive/gallon, so in a full tank of 21 gallons that's around $8, which will buy around 3.5 gallons at the current price here in Georgia. To make it simple, if you average 20 miles/gal in your driving average, a 20 gal tank will give you a 400 mile range, whereas 23.5 gals will give you a 470 mile range. So, basically, using 87 versus 93 is like getting 3.5 miles/gal more.
    Kronk21, Dryfly24, Scott4032 and 4 others like this.
  11. May 29, 2016 at 10:45 AM
    Joe D
    Joe D .
    What area are you located?
    I note you say "tested". Is that what the manual calls for or???
  12. May 29, 2016 at 10:47 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I use what ever is cheapest.
    Dryfly24 and Boghog1 like this.
  13. May 29, 2016 at 10:47 AM
    2016BBP
    2016BBP Well-Known Member
    Southeast
    SR5 V6 Auto
    Method Wheels, WxTechGuards, TowPkg, KNDropn, 3M-Tint
    Ive been using 87 since day one and I have gotten Toyota's advertised Mpg for over 3,000 miles now.
    Dryfly24 and kgilly like this.
  14. May 29, 2016 at 10:47 AM
    nickj604
    nickj604 Well-Known Member
    Nick
    Vancouver BC
    2019 RAM 1500
    To be announced
    If your manual say run 87 I'd say run 87. Any body who runs anything high is stupid and has to much money. They obviously have no idea how fuel works and they assume they know more then the engineers that designed the engine.
    This tread has been beaten to death a million times and op has obviously not used the search function
    MODS PLEASE LOCK
    betrayus likes this.
  15. May 29, 2016 at 10:49 AM
    R2D2
    Towing package
    BTW, here in my part of Georgia non-ethanol gas is significantly more expensive than ethanol 93. I use it for lawn equipment and power washers, where they be idle for months and you run the risk that the ethanol will come out of solution and generate water. But if you are not going to let your truck sit for long periods of time, there is not significant advantage in using non-ethanol gas. Also, you minimize the risk of getting water in your tank if you keep it topped off. Less water vapor pressure in the tank will minimize ethanol conversion to water.
    Maybe the non-ethanol will feel like more horsepower (I know my Porsche sounded different with non-ethanol) but I don't have plans to win any light-to-light drag races in my Tacoma.
    Nunya Bizness and choupick like this.
  16. May 29, 2016 at 10:52 AM
    choupick
    The south
    I'm in south georgia and the ethanol free is a good bit more expensive. After this tank I'm going to run a couple of tanks of ethanol 93 and compare the cost per mile.
  17. May 29, 2016 at 10:52 AM
    jsi
    jsi Well-Known Member
    native earthling
    Around here 85 is regular, 87 is mid grade, and I don't know what premium is because I never buy it. My truck drinks a regular diet of 85, but I've been out of town and forced to buy 87 because that was the lowest grade available. If there was a difference the seat of my pants couldn't tell, but my wallet sure could.
    Dryfly24, Nunya Bizness and choupick like this.
  18. May 29, 2016 at 10:59 AM
    jsi
    native earthling
    to the "I run 93" crowd turning this bit of math the other way around: if a tank of 93 doesn't take you further than 470 miles you are wasting money. If there was anything to running higher grade gas than what the manufacturer recommends everyone would be running 93. Me, I chose to spend my money on fun stuff.
    Dryfly24 and FeraNatura like this.
  19. May 29, 2016 at 11:05 AM
    2016BBP
    Southeast
    SR5 V6 Auto
    With so much negativity does it make ya wonder if he and many others even own a 3rd Gen or do they work for another Auto Manufacturer ?
  20. May 29, 2016 at 11:20 AM
    surfyota
    surfyota Well-Known Member
    mike
    Tampa, Florida
    17 mgm dcsb Trd sport 4x4
    Lifted, kmc 17x9, Cooper 33s, katzskin leather, topper, front bumper light bar.
    octane rating has nothing to do with mpg. it has everything to do with how much energy is required to burn it. so unless you put a turbo on your tacoma you are wasting money putting 93 in it. and theoretically leaving excess unburnt fuel behind.
    betrayus, robfrye, ret42 and 4 others like this.
