Which octane is everyone using
Discussion in '3rd Gen. Tacomas (2016-2023)' started by yoda16, May 29, 2016.
  1. Oct 5, 2021 at 5:15 PM
    #201
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    87
    Also try to avoid the corn gas
  2. Oct 5, 2021 at 5:59 PM
    #202
    Jay745
    Jay745 My racecar is a vw
    Jay
    21 Tacoma Off-road
    KdMax tuned, stock aside from cosmetics
    Mine is tuned for 91, but I put 93 in it
    Junkhead likes this.
  3. Oct 5, 2021 at 6:28 PM
    #203
    TheSortaHawaiian
    TheSortaHawaiian Well-Known Member
    21 Lunar Rock TRD Pro
    I dont understand why the Tacoma manual just doesn't say "use 87.". The truck isn't tuned for anything higher....it's not like it's a forced air engine...the manual should just say 87.
    Junkhead and ZColorado like this.
  4. Oct 5, 2021 at 9:32 PM
    #204
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    That’s a good question. An internal combustion engine actually requires less octane at a higher altitude because there is less air filling the cylinders and less cylinder pressure is produced. Of course, this assumes a naturally aspirated engine and a static timing curve.
    If you went from sea level to a high pass like Tioga which is just under 10,000 ft, the octane requirement is substantially less. At one time, lower octane fuel was sold in high altitude areas. However, once you descend to a lower altitude, the octane requirement goes up.
    ZColorado likes this.
  5. Oct 5, 2021 at 9:36 PM
    #205
    CPS-65
    Alta Loma, CA
    Mostly old man mods
    It’s also an aluminum head motor and pulls heat out of the combustion chamber faster which is why it can run a higher compression ratio and not detonate.
  6. Oct 5, 2021 at 11:07 PM
    #206
    TazTheTaco
    TazTheTaco Member
    2019 Tacoma TRD Pro
    Eh I use 87 because I feel like the Tacoma engines aren’t optimized to even benefit from higher octane fuels. Less money out of my pocket for the same result.
  7. Oct 5, 2021 at 11:21 PM
    #207
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    91, but only because I'm tuned for it. Stock tune i ran 87 and it ran just fine.
  8. Oct 5, 2021 at 11:22 PM
    #208
    TazTheTaco
    TazTheTaco Member
    2019 Tacoma TRD Pro
    What tune did you get??
  9. Oct 5, 2021 at 11:43 PM
    #209
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
  10. Oct 6, 2021 at 12:01 AM
    #210
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    I'm running OVtune 2.0, premium, 33 inch tires.
  11. Oct 6, 2021 at 12:03 AM
    #211
    TazTheTaco
    TazTheTaco Member
    2019 Tacoma TRD Pro
    I’m on 265/70/18. So pretty close to 33s. Do you see a benefit from the tune? Worth it?
  12. Oct 6, 2021 at 1:02 AM
    #212
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    Oh absolutely. Makes the truck so much more fun. I spin the tires on dry pavement now lol, and it doesn't hunt. @tonered is the man to go to if you have more specific questions, or the VF tuner forums.
    tonered and TazTheTaco[QUOTED] like this.
  13. Oct 6, 2021 at 2:48 AM
    #213
    I.eat.tacos
    I.eat.tacos Well-Known Member
    Steve Rogers
    '18 TRD 4x4 Sport
    JP5 or JP8. In a pinch, I'll run JP4.
  14. Oct 6, 2021 at 4:07 AM
    #214
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    Good parts cleaner, or to burn in kerosene lamps.
  15. Oct 6, 2021 at 4:53 AM
    #215
    DanoTay
    DanoTay Well-Known Member
    Victoria, B.C.
    2019 Tacoma OR AC MT
    I currently have an OV Tune that requires premium gas but will be switching to Coyoza tune because it is M/T specific and while Coyoza does not require premium I plan to stay with it because in British Columbia Chevron sells ethanol free 94 octane.:D
    BTW the OV Tune completely overcomes the wimpy low rpm performance of the 3.5 V6. I highly recommend getting any aftermarket ecu tune as the increase in performance is easily well worth the $.
  16. Oct 6, 2021 at 8:46 AM
    #216
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    91 or 93. pulls timing and runs like hot garbage on 87. but i have the 2tr-fe I4. hunts for gears and shifts like crap too due to shifting too often with 87. it holds gears much longer with 91/93.
  17. Oct 6, 2021 at 8:48 AM
    #217
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    You'll be fine, I ran mine on 85 without any problems before I installed the supercharger. If you know you'll be doing heavy towing or driving down to a lower altitude it won't hurt to put in a higher octane but for your normal daily driving there is no need.
  18. Oct 6, 2021 at 8:57 AM
    #218
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    87 OR higher. It does not say designed to run on 87 only.
    cryptolyme and DanoTay like this.
  19. Oct 6, 2021 at 9:02 AM
    #219
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Manual in my ranger said: “designed to run on 87 only”. Before reading my manual I decided to fill her up
    With 91 and she ran like shit.
    All my Japanese vehicles ran better and got better MPGs with 91 or higher E0. I’ve been using 91 E0 in my taco, even on the stock tune. No hesitations/jerkiness and whatever else people here complain about.
    cryptolyme likes this.
  20. Oct 6, 2021 at 9:05 AM
    #220
    R4D4G4ST
    R4D4G4ST Well-Known Member
    21 LR TRD PRO MT
    Maxxis Militia
    I came here just to post this video. EE always does a great job explaining some of the nuance. It's always a bit more complex than people realize.
    That said, I only run E0 87 octane at 5,000-10,000 feet of elevation where I spend most of my time.
    splitbolt[QUOTED] likes this.
