Which octane is everyone using
Discussion in '3rd Gen. Tacomas (2016-2023)' started by yoda16, May 29, 2016.
  1. Apr 22, 2021 at 1:28 PM
    #141
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Correct.
    But you originally posted, "Isn't 91 aki european? This would translate to 87 in the states."
    Had you said, "Isn't 91 RON european? This would translate to 87 AKI in the states", I would have agreed.
  2. Apr 22, 2021 at 1:31 PM
    #142
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    91 or 93. Modern engines can actually make use of the higher octane.
    CPS-65 and shotgunbilly420 like this.
  3. Apr 22, 2021 at 1:35 PM
    #143
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I've done the same on my 17 taco but first 10,000 miles I ran 87 octane after premium ball the way
    RCBS likes this.
  4. Apr 22, 2021 at 1:46 PM
    #144
    southernmost
    southernmost Well-Known Member
    Ivan
    Magic city
    Taco 3rd gen 21 TRD Sport
    Pro HL, Rigid Fog,raptor lights.
    I met a while back a fellow hunter in North Carolina who was very eager to talk about gasoline, he talked about the additives that go into gasoline.
    The different companies that make the fuel more refined such as Shell, Chevron, Mobil, Costco and so on, these all make top tier gasolines and they add detergent, additives and other chemicals that raise the octane, it will make a cleaner pass from throttle body to catalytic converters producing better combustion giving extra miles per gallon and a lot cleaner internal engine parts valves, pistons, heads.
    For instance 85 87 89 don’t have the additives that 93 92 and 91 have he just plainly said don’t waste your money on 89 it has more than 87 but it doesn’t have the additives and chemicals that 91 and above have. Now the final subject was he drilled wasif you want to have a clean motor when remove the valve covers you have to use high octane Top tier gasoline 93 if you can afford it it will give few extra miles and a cleaner combustion chamber and exhaust parts. But 87 top tier is also good
    At this point I asked how do you so much about gasoline and replied I was an ex Exxon chemical engineer and now I own a fuel hauling company I pick up at the refinery and deliver gas stations, marinas and any one who has 1000 gallon tank minimum.
    He likes Costco’s fuel because it almost the same as Shell, Chevron Exxon Mobil and its usually 10 to 15 cents cheaper.
    Top Tier is cheaper in the long run. Your Taco will love it.
  5. Apr 22, 2021 at 1:48 PM
    #145
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    87 because that's what it was developed to use unless Towing etc
    OrangeRa1n likes this.
  6. Apr 22, 2021 at 2:39 PM
    #146
    dagobert
    dagobert Well-Known Member
    It is the same, no one has an exclusive contract with Costco for fuel. What ever Top Tier refiner is in the area, the same fuel from that spigot is at Costco.
    Reason its less because they only carry regular and premium (no mid grade) credit card only, no fun n run store to pay for. No extra frills just gas and go.
    southernmost[QUOTED] likes this.
  7. Apr 22, 2021 at 2:40 PM
    #147
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If l am not mistaken the mid grades basically happen right at the gas station. The pump pulls directly from both the Regular and Premium tanks and mixes them.
    Charlie Too and shotgunbilly420 like this.
  8. Apr 22, 2021 at 3:05 PM
    #148
    bornxbackwards
    bornxbackwards Well-Known Member
    Bruno
    Sherbrooke, QC
    2021 MGM Tacoma SR5 4x4 DCLB
    Debadged, black sumos, brake controller.
    Y'all talking about the SiriusXM station right?
    boogie96, SilverSky195 and OrangeRa1n like this.
  9. Apr 22, 2021 at 3:11 PM
    #149
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
    True mileage alone would not make it up, but performance and mileage may for some. I think that's more of a personal decision for us.
    I think what may be happening here is that the octane listed is not true and/or the higher octane level you are using is likely where it needs to be for your conditions. I mentioned earlier that I have known people that measure octane levels. One measured octane at multiple gas stations for the lowest level and it was consistently 1-3 points below stated number on average. Even one point can be bad. E85 is even worse and notorious for causing blown engines(tuned engines) A buddy of mine is having is $44k engine rebuilt because of this exact issue. Over tuned on ideal fuel octane(E85) and actual fuel octane considerably lower. He actually drives around with an octane reader of some kind lol. I should find out the brand and get one myself.
    I do believe this to be true becasue of the ability of not just the ecu to change conditions but because of the VCT becoming so popular.
    I never heard of this but it would be efficient I guess to do this.
    shakerhood[QUOTED] likes this.
  10. Apr 22, 2021 at 3:36 PM
    #150
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    I use either Shell or Chevron 91 almost exclusively. Don’t make any claims about horsepower or MPG advantages but I have read that the less ethanol in your gas, the better off your engine will be long-term. Premium has the lowest percentage of ethanol and is primarily why I use it since I’m so heavily invested in my mods and want to keep the truck as long as possible
    southernmost likes this.
  11. Apr 22, 2021 at 5:12 PM
    #151
    shotgunbilly420
    Very well said keeping the engine cleaner
  12. Apr 22, 2021 at 5:12 PM
    #152
    shotgunbilly420
    I've heard same also
  13. Apr 22, 2021 at 5:15 PM
    #153
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Don't forget the 100+ octane
    RatDaddy[QUOTED] likes this.
  14. Apr 22, 2021 at 5:28 PM
    #154
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    I can’t even get 87 around here. 86 is about standard and it works fine. I’ve never noticed a difference when I could get higher octane. The truck runs exactly the same.
    Now my Indian Chief Springfield gets the highest octane I can find because it’s a high Comp engine and requires it. The truck gets whatever is available and usually the cheapest I can find and it’s fine with that...
  15. Apr 22, 2021 at 5:32 PM
    #155
    Charlie Too
    Charlie Too Well-Known Member
    Western PA
    2021 Army Green Tacoma TRD Off Road
    87, top tier only, typically Shell, but occasionally BP when I cross the state line where it's anywhere from 20 to 45 cents cheaper.
  16. Apr 22, 2021 at 5:40 PM
    #156
    TK11
    TK11 Well-Known Member
    Tom
    N. CA
    2019 TRD OR MT
    Bilstein 6112 / 5160, 275/70/17 BFG KO2, Caliraised Sliders, SSO bumper, Warn winch
    That is true. The statement that 89 doesn't have the chemicals / additives that 91 has isn't accurate. It will only have half of the additives per volume, however.
  17. Apr 22, 2021 at 5:41 PM
    #157
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    93 octane here in Texas with my custom tune.
  18. Apr 22, 2021 at 5:43 PM
    #158
    Charlie Too
    Western PA
    LOL. $2.11 for premium. Here, 87 octane is about $3 per gallon. I have no idea what 93 octane is because I won't pay for it.
    SilverSky195 and shakerhood like this.
  19. Apr 22, 2021 at 5:43 PM
    #159
    TK11
    Tom
    N. CA
    2019 TRD OR MT
    Ah, you had to post that, didn't you? Some of us are paying over $4 for 87 right now.
    zoo truck, shakerhood and Charlie Too like this.
  20. Apr 22, 2021 at 5:45 PM
    #160
    Invid
    2016 Tacoma Limited
    Well, this is from one year ago. I just filled up at $3.05 a gallon for 93 the other day. The KDMax and OVTune flashes really make it shine.
