Which of these two would YOU choose, and why?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SigBur, May 7, 2012.
  1. May 7, 2012 at 1:18 PM
    SigBur
    SigBur [OP] Active Member
    '98 Tac, 4x4, V6, 200K--$4500
    '99 Tac, 4x2, 2.4L, 138K--$5000
    Use: Just getting around, no heavy wheeling, light and infrequent motorcycle towing, living out of, exploring. Mainly in central coast of California, and maybe a little Colorado here and there.
    Would the 60K+ mileage difference sway you in one way or another? I bought an '84 FJ60 seven years ago with 200K on her and sold in October with no major probs. Does this gen have similar reliability?
    For arguments sake, suppose that both trucks were well maintained with little or no modification made, 5spd, extended cab.
    Opinions?
  2. May 7, 2012 at 1:23 PM
    drubacca117
    drubacca117 Well-Known Member
    Brad
    Eglin AFB, Florida
    '12 PreRunner V6 SR5 Double Cab
    I'd go for the '99 if I were you. Less total mileage, better fuel economy. You don't sound like you need the 4X4, or even the V6, and with Cali gas prices... Yeah...
  3. May 7, 2012 at 3:53 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Does the '99 really have the 2.4L? Does it have 5 lug nuts on each wheel or is it a 6 lug? If its a 6-lug, its not a 2.4L.
    Reliability is a non-issue. The 60K is a non-issue. I would go with the 4x4 and v6 every time. Also much more ground clearance over the 5-lug truck.
    $4200 is a good price.
    edit: BTW, Welcome to TW.
  4. May 7, 2012 at 4:41 PM
    SigBur
    Yes, it's the 5 lug, 2.4 L. Owner doesn't want to budge on price. It's got a 6" Fabtech and Detroit Truetrac.
    I think I could get the V6 for 4K or so.
    Thanks for responses thusfar...
  5. May 7, 2012 at 6:27 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    I'd go for the '98 for sure. The mileage isn't a concern at all. its cheaper, and....Its got 4wd! May not use it everyday but when you need it you'l be sooo glad its there.
    If it was a highway commuter only I'd say the '99... my .02 :)
  6. May 7, 2012 at 6:30 PM
    NRXTM
    NRXTM Well-Known Member
    Houston
    2011 toyota tacoma
    98' for the V6
  7. May 7, 2012 at 7:04 PM
    hatda02
    hatda02 Member
    David
    Western PA
    01 Taco, 99 4R, 01 'Lude, 01 Snake
    Both engines are very reliable in this gen. I would take the v6 4wd if I were you.
  8. May 7, 2012 at 8:10 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Putting another vote on the V6 4x4.
    I had a 4cyl Taco before (granted, it was the 2.7L 4x4) and it is a DOG up steeper hills and on the interstates. If you plan to go around/through the Rockies exploring then the 4cyl may be a bit tough.
    I also saw zero mileage change from the 4cyl to the 6. If anything, I get better MPGs with the V6.
  9. May 7, 2012 at 8:15 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    98. 4x4 and v6
  10. May 7, 2012 at 8:18 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Hmm, is that the 3.0 V6? And is the other one a 22R-E 2.4L? I would go with the 22R-E all day long over an early 3.0. The 3.4, 4WD and cheaper price might sway me.
  11. May 7, 2012 at 8:21 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Tacoma v6 is the 3.4L
  12. May 7, 2012 at 8:33 PM
    Tacomang
    Tacomang Well-Known Member
    Norcal
    Trd Taco
    Get the V6 if it isnt beat to hell. Hows the body? Check for rust.
    For reference Ive owned 2 of the 3.4l trucks. A 96 T100 with 380k miles, had 3 timing belt jobs. Everything else aside from brakes was stock.
    My current 02 Tacoma has 214k, still on oem clutch.
  13. May 7, 2012 at 9:47 PM
    KeeKee
    KeeKee Active Member
    Keelyn
    Arizona
    05 Speedway Blue 4.0L V-6 2WD Prerunner
    Fj TRD black rims Headlight, fog lights & tail lights LED light bar Magnaflow exhaust K&N Air filter Sony headunit More to come...
    The 98 would be a good choice. Mileage isn't too bad...my 99 has 230k+ and it's a V6. I prefer the V6 but some people like the better gas mileage and just cruising driving in the 4 bangers....depends on your style :)
  14. May 7, 2012 at 10:39 PM
    Jnizzle
    Jnizzle Well-Known Member
    Jack
    Reno, NV
    04' 4x4 5spd X-cab
    Shell
    V6 4x4 for sure, plus you don't want a 6" lift on a 2.7L.
  15. May 7, 2012 at 10:43 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    which ever one is closer to stock
  16. May 8, 2012 at 12:26 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    i would look for something under 200k with 4x4. if it snows you want it, and 200 is pretty high. but out of the 2 if i had to choose it would be the 4x4. just prepare for more maintenance and maintenance costs.
  17. May 8, 2012 at 4:13 AM
    SigBur
    Soooo....went and drove the '98 V6 yesterday. Sweet little old lady handed me the keys and let me loose; it had been her husbands who passed away last month. They were a retired couple from California, in the business of, wait for it....auto parts.
    Wow, so much more fun to drive than the four banger! Gave it a thorough once over, and walked away with it for 4K. Clean, clean clean and driven gently. Oh, and 199,524 on the clock, so I get to take her over the magic mark.
    Will post pics shortly
    Thanks for the responses!
  18. May 8, 2012 at 4:21 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Wow. awesome! It was meant to be . . .
  19. May 8, 2012 at 5:17 AM
    TIPICOTACO
    Tyler
    nw nj
    Congrats on the Taco man!!! you made the "right" choice, and sounds like you got a great deal... fwiw I bought a '97 xtracab 2.7l auto w/ 235k in 2010 and paid 4k also...so you did good IMO. Do a search on recommended maitenance (ie changing fluids, plugs, wires, etc.) there are a ton of those kinda threads, and Get some pics up we need our Taco porn ;)
  20. May 8, 2012 at 5:34 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    Apples and oranges really when comparing a four wheel drive to a two wheel drive truck. Where I live I would say four wheel drive, if only for the resale value, but be prepared there are a few more maintenance issues to keep it in good shape.
