Which oil is thinner at start up?
Discussion in 'Technical Chat' started by DevL, Aug 15, 2010.
  1. Aug 15, 2010 at 2:01 PM
    DevL
    DevL [OP] Well-Known Member
    5-20 or 0-30? I know that the 5-20 is thinner at operating temperature but I dont know if 5-20 is thinner at start up. I know 5-20 is thinner than 5-30 at start up. I know that 0-30 is thinner than 5-30 at start up... what i dont know is if 5-20 or 0-30 is thinner at start up and by how much... and if 5-20 is thicker at start up at what temperature do they have the same viscosity.
  2. Aug 15, 2010 at 2:17 PM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    The way to read the oil viscosity grading for multi-vis oils: the first grade number is the "viscosity a single-weight oil of that grade would be" at low temp (0 degrees F IIRC) and the second grade number is the "viscosity a single weight oil of that grade would be" at high temp (212 F IIRC). It stands to reason the 0w30 is thinner IF the starting temp is 0 F.
    But then it's equally logical to conclude that at some temperature between 0 and 212, the 5w20 is thinner. But to say a 5w20 is thinner than a 5w30 is only 'guaranteed' true if start-up temp is "something" above 0 deg F.
    In other words: it depends on temperature at start up.
    Since viscosity grades at temp's other than 0 and 212 aren't specified (and my guess is the curve isn't linear since there are multiple things going) it could be anyone's guess where the 'start up' viscosities are the same. It's also probably safe to assume the crossing point could vary from one manufacturer - or formulation - to another; there could even be multiple crossing points or be essentially congruent for a huge range of temperatures.
  3. Aug 15, 2010 at 2:47 PM
    REVHARD25
    REVHARD25 Well-Known Member
    so cal
    RUGGED TRAIL PACKAGE
    Tint on front windows. Dnx7120 kenwood. Rear tsb springs. Wet okoles seat covers UWS truck box Weathertech floor mats TSB floor mat hook grommets Satoshi grill AFE drop in filter Fumoto drain valve Bed mat
    o-30 better at start up..5-20 better for mpg
  4. Aug 16, 2010 at 8:30 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    x2
    Although both have crappy shear number :D
  5. Aug 16, 2010 at 7:34 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    shear.....
  6. Aug 16, 2010 at 7:36 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
  7. Aug 17, 2010 at 11:47 AM
    BlueT
    NorthEast
    thanks fixed
    I seen that but he is confusing....
    I was told that best oils have high HTHS numbers. I had been sticking to oils with high HTHS numbers and never had problems, Tacoma is first one that I am not sure what to do in part due to VVT-i in it. Otherwise I would be running Shell 5-40 which supposed to be near 4.7 More then even Mobil Delvac.
  8. Aug 17, 2010 at 4:24 PM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    There's ever so much more to a good oil than one single dimension like high shear numbers.
    Isn't Delvac a diesel engine oil? If it is it could have a boundary layer additive in high proportion that mfr's of gas engine oils have been reducing or eliminating because it poisons catalytic converters - ZDDP. I'm not sure that's the case, but it's something one could lose track of if pursuing a single dimension of perceived quality to the exclusion of all others.
  9. Aug 18, 2010 at 6:40 AM
    BlueT
    NorthEast
    Well Delvac and Rotella are both rated for gasoline engines too. The only difference supposed to be that, as you point out they still should have higher levels of additives to combat wear. Gasoline only oils, had been told to reduce additives to lower the strain on catalytic converters. Problem with that is oils like Mobil 1 5w-30 are no longer as good as they were before the change. Which happened I believe sometime around 2006 -2008. Personally I was wondering what happened with Mobil 1 since I could feel the difference, until I found out that, yet again California had forced the rest of us to use crappy oil. :mad:
    First I thought I bought a bad batch of oil, after getting oil from different sources and still having engine becoming noiser as oil was wearing out, it was clear that something had changed drastically in formula.
    Now here is what I gathered from interweb...
    Toyota, GM and some other company did test to figure out what is the lowest HTHS number they can go before engine will have possibility of catastrophic failure, their number was HTHS 2.9
    Mobil 5w-20 is ... 2.62
    Mobil 0W-30 is 2.99
    oils like 5w-20 or 0w-30 are on the border line of what even Toyota deems to be a safe number so I am not sure if I want to run them.
  10. Aug 18, 2010 at 10:27 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    Give us a link or it's...well...as they say... "(The internet) is like a herd of performing elephants with diarrhea -- massive, difficult to redirect, awe-inspiring, entertaining, and a source of mind- boggling amounts of excrement when you least expect it."
    I simply can't believe that Toyota says the oil they require us to use (doesn't a 30 wt have minimum HTHS of 2.9 per SAE spec?) is almost going to lead to 'possibility of catastrophic failure'. Just makes no sense.
    Also, from what I've read HTHS doesn't seem to be as important with synthetic oils since they exhibit much greater "Newtonian" properties than do petroleum oils that rely on VII's. In other words: they don't change viscosity in high-shear conditions.
  11. Aug 18, 2010 at 10:30 AM
    08pretaco
    Oliver
    az
    so then whats the best oil weights for our trucks BlueT?
  12. Aug 18, 2010 at 11:00 AM
    BlueT
    NorthEast
    Honest answer is ...Dont know.
    I am waiting for Toyota to tell me why Tacoma does not have xW-40 in its book. Most likely as some others point out its VVT-i. I am running Mobil 1 5W-30 as others but I do change oil as soon as the sound of the engine changes which is around 3500-4000 miles. It could be my engine but I doubt. It runs super quiet on fresh oil.
  13. Aug 18, 2010 at 12:56 PM
    DevL
    Well HTHS comes into play at the highest revs and hottest engine oil working range. If you do lots of WOT driving then you need 2.9 or higher. Your oil wont break down and casue issues if it is at least 2.9 and that figure wont even come into play unless you have high oil temperatures to begin with. My WOT use is limited so I am totally NOT concerned with HTHS numbers. I also have the aux engine oil cooler.
  14. Aug 18, 2010 at 2:36 PM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    That makes sense about WOT use. I think it makes a very good case for trailer towers using synthetic since they stay in grade so well even with extended drain intervals. If anyone should doubt it just check the UOA's at BITOG. With a synthetic oil it's rarely the loss of viscosity that drives the decision to change oil, it's the loss of TBN, accumulation of contaminants an/or other factors.
    But none of this has anything to do with the original question: which oil is 'thinner' at start up, an entirely different conundrum.
  15. Aug 19, 2010 at 12:44 PM
    DevL
    I have discovered for Mobil 1 the 5-20 is the thinner oil at pretty much all temps above freezing.
  16. Aug 19, 2010 at 1:38 PM
    cinch
    cinch Member Extraordinaire
    Al
    Boulder Creek Ca
    2010 Prerunner double cab
    The best oil is whatever the owners manual recommends. There are reasons they recommend it.
  17. Aug 19, 2010 at 6:09 PM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    Probably reasons that have more to do with 'entrenched conservatism' than anything else...
  18. Aug 19, 2010 at 6:11 PM
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    the funny part is you could've used the cheapest walmart brand oil and you still would've never 'had problems'
  19. Aug 19, 2010 at 6:12 PM
    woodygg
    So Cal
    04 DC Tacoma 4x4
    and you've discovered this how??
  20. Aug 20, 2010 at 8:48 AM
    DevL
    By using Mobil 1's viscosity and density data and bibistheoilguy's viscosity calculator I can interpolate down to 15 deg C and makes educated guesses down to freezing. This is just for ONE of the 5-20 formulations and the 0-30 Advanced Fuel economy formulation. I didnt test out ALL the Mobil 1 5-20s but it appears the results would be similar.
