Which Oil to Run Toyota OEM Synthetic or Mobile 1 Synthetic?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by moe2o4, Dec 8, 2015.
  1. Dec 8, 2015 at 5:12 PM
    moe2o4
    moe2o4 [OP] Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Even tho I got free oil changes I still like to do it myself. I'd rather be the only person touching my truck!
    Plain Jane Taco and Doggman like this.
  2. Dec 8, 2015 at 5:13 PM
    moe2o4
    Corey
    Pittsburgh PA
    Go to the dealership for a filter and buy the oil separate!
  3. Dec 8, 2015 at 5:14 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    That's how I am. I will still be surprised if my local Toyota dealership actually gives me free oil and allows me to use their lift when the time comes... I would have thought they wouldn't do that for liability reasons. The lift isn't that big of deal really though... it would be for my car but a Tacoma has enough ground clearance that lifting wouldn't necessary.
  4. Dec 8, 2015 at 5:15 PM
    moe2o4
    Corey
    Pittsburgh PA
    How do they let u do that. There is defiantly a liability there!!
  5. Dec 8, 2015 at 5:17 PM
    Sam B
    Sam B Well-Known Member
    Samuel
    Poway, Ca.
    16 Red DCLB TRD Sport 4x2
    none
    Yea I understand that. I am the same way but.... it's free and under warranty for the 1st 2 yrs or 25,000 miles so take advantage of it. It always stings but I take the Harley to the dealer for the 1st 1k service then do the rest myself. The Jeep has the same plan so it goes to the dealer until the plan expires. No reason to waste your money and the oil is 0w20 which is only synthetic.
    The only thing I do is right after pickup I check the oil plug, the filter housing and the oil dipstick for fluid level. It's easy to see that its fresh oil.
    truchador likes this.
  6. Dec 8, 2015 at 5:24 PM
    cllowe24
    cllowe24 Well-Known Member
    Mid Tennessee
    2015 access cab
    Billstines with 885 coils 2”aal Lce header, pro dry drop in filter, charcoal filter removal, light bar in grill, ditch lights, yaesu dual band radio, and a bunch of other junk
    My dealer was to rotate my tires as part of my Toyota care. After about 15000 miles and noticeable cupping I marked one. They never rotated them once. I asked them about it and they said they did, so I then showed them where I marked the tire plus had the wheel lock key put away. I do not trust dealers.
    KY_Rob, taczilla and Doggman like this.
  7. Dec 8, 2015 at 5:27 PM
    Doggman
    Alabama
    2017 TRD OR MT
    +1
    Never have, never will.
    taczilla and moe2o4[OP] like this.
  8. Dec 8, 2015 at 5:28 PM
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
    Do I have to use the dealer for repairs and maintenance to keep my warranty in effect?
    No. An independent mechanic, a retail chain shop, or even you yourself can do routine maintenance and repairs on your vehicle. In fact, the Magnuson-Moss Warranty Act, which is enforced by the FTC, makes it illegal for manufacturers or dealers to claim that your warranty is void or to deny coverage under your warranty simply because someone other than the dealer did the work. The manufacturer or dealer can, however, require consumers to use select repair facilities if the repair services are provided to consumers free of charge under the warranty.
    That said, there may be certain situations where a repair may not be covered. For example, if you or your mechanic replaced a belt improperly and your engine is damaged as a result, your manufacturer or dealer may deny responsibility for fixing the engine under the warranty. However, according to the FTC, the manufacturer or dealer must be able to demonstrate that it was the improper belt replacement — rather than some other defect — that caused the damage to your engine. The warranty would still be in effect for other parts of your car.
  9. Dec 8, 2015 at 5:32 PM
    Uncle Jimmi
    Uncle Jimmi Well-Known Member
    James
    Coleman MI
    White access cab 4x4 TRD Off Road
    Mud flap delete
    You can go to any Toyota dealer in the US and get the oil changed and tires rotated and vehicle inspected and have them sign and stamp the maintenance record book for 2 years or 25k at no charge
  10. Dec 8, 2015 at 5:47 PM
    moe2o4
    Corey
    Pittsburgh PA
    I think I'd rather just spend the few bucks and buy oil and a filter and do it myself that way I know it's done right!!!
    NAAC3TACO and 16tacomaOR like this.
  11. Dec 8, 2015 at 5:52 PM
    16tacomaOR
    16tacomaOR Well-Known Member
    Sam
    16 Tacoma OR 4x4
    The only reason they reccomend a 0w-20 5w-20 is specifically to meet epa regulations (mpg quota) the older Tacomas were running 30 weight they sent out a tsb to change to a 20 weight for better fuel economy And so they could switch everything over to a 20 weight and be a seamless transition. A 30 weight will do nothing more than provide more protection during extreme heat. I do appreciate you trying to help me out though!
    billybob50 likes this.
  12. Dec 8, 2015 at 6:04 PM
    16tacomaOR
    Sam
    16 Tacoma OR 4x4
    Also I don't think Toyota will give me any grief, your not required to run Toyota oil, just an oil that is up to toyotas standards. And for those that get their oil changed at dealership, mark your oil plugs and filter caps, I got some special treatment years back when they didn't change my oil filter and I called them out on it. I would rather change my own, and know that I'm not going to strip my oil pan hole or cause any damage, just for the piece of mind.
    moe2o4[OP] likes this.
  13. Dec 8, 2015 at 6:14 PM
    BAMA-256
    BAMA-256 Well-Known Member
    Rex
    Huntsville Alabama
    2017 SR 4x4 5 speed manual Past-2016 TRD Offroad 4x4
    Mobil 1 is decent, but not the best as it may have been in the past. If you're not going to go with the OEM Toyota oil, Penzoil Ultra is about the best "off the shelf oil" you can buy imo. But really, any of today's modern synthetic oils will provide more than enough protection, provided you follow the maintenance recommendations.
  14. Dec 8, 2015 at 6:16 PM
    moe2o4
    Corey
    Pittsburgh PA
  15. Dec 8, 2015 at 6:33 PM
    #35
    16tacomaOR
    Sam
    16 Tacoma OR 4x4
    I've hear penzoil had come out with an awesome synthetic, I'm not sure of the name, the stuff I'm using castrol syntec 0w30 German formula, is phenomenal stuff, it's what most European guys and a lot of domestic guys are running and there is nothing but great things said, i agree that mobile 1 isn't what it use to, I really considered going back to Toyota oil since I can buy it much cheaper than castrol but it's what I run in my wifes grand Cherokee also and figured it would be easier to keep up with 1 type of oil. As stated by Bama really any synthetic by today's standard will be fine, I mean how many Toyota Tacomas are out there that have 300k on the clock and have ran conventional oil, and you know not all owners are as meticulous as us. I think we will all be fine no matter what we use, but just keep up with general maintenance
  16. Dec 8, 2015 at 6:37 PM
    #36
    billybob50
    Bob
    For the last 30 years the first thing I get for my cars/trucks is a fumoto valve! No more fishing for the oil plug and no more oily hands! a http://www.fumotousa.com/
  17. Dec 8, 2015 at 6:40 PM
    #37
    moe2o4
    Corey
    Pittsburgh PA
    Never seen those.....
  18. Dec 8, 2015 at 6:42 PM
    #38
    16tacomaOR
    Sam
    16 Tacoma OR 4x4
    My dad raves about fumoto valves, I'm just nervous of putting one on since the plug is straight down and the valve would be almost flush with skid plate, I wouldnt want to hit a log or something that would damage oil pan since that valve would be so close to skid plate. But you are right they are wonderful I have had the one with the nipple on the end that you slide a piece of hose on and it's great!
  19. Dec 8, 2015 at 6:46 PM
    #39
    moe2o4
    Corey
    Pittsburgh PA
    Wonder where my plug is on my 2.7 if it's straight down or at a angle..... And how do you drain from those valves you had to you the button on the whole time?
  20. Dec 8, 2015 at 6:51 PM
    #40
    16tacomaOR
    Sam
    16 Tacoma OR 4x4
    I don't quite understand what your asking,but let me give it a shot, to drain valves you lift up on the lever and turn it, it's as easy as that, when your done you turn it back and it locks down, if your extra paranoid they have a lock that you can install to make sure the lever doesn't move at all.
