Which OME Springs (885s or 886s)?
Discussion in 'Suspension' started by NumNutz, Nov 22, 2012.
  1. Nov 22, 2012 at 9:36 AM
    NumNutz
    NumNutz [OP] One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Which OME Springs are best for the setup below?
    07 Access Cab
    BruteForce Hybrid Front Bumper
    9500lb Superwinch
    I'm looking for about 2" of lift. I don't want driveline vibs and I don't want to have to buy UCAs. I also want to be able to use the 5100s I have on my truck now.
    Thanks everyone!
  2. Nov 22, 2012 at 9:38 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    How much does the bumper / winch combo weigh ?
  3. Nov 22, 2012 at 9:39 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    Winch is 90lbs. Not sure about the bumper.
  4. Nov 22, 2012 at 9:40 AM
    OZ-T
    Peter North
    British Columbia
    Well , that would certainly be a deciding factor , perhaps a pm to the vendor is in order
  5. Nov 22, 2012 at 9:51 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    Let's say it weighs 150-170lbs.
    I know they suggest the 886s for over 200lbs of weight in the front, but I only want about 2" of lift.
  6. Nov 22, 2012 at 2:23 PM
    OZ-T
    Peter North
    British Columbia
    Well , you could go 885's and if they don't provide enough lift you could add some 1/4" or 1/2" top plate spacers
  7. Nov 22, 2012 at 4:12 PM
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    886's will give you 3+ inches, so for that alone you're choice is clear.....
  8. Nov 22, 2012 at 4:17 PM
    mh.meier
    mh.meier PB MIKE Vendor
    MAD MIKE
    Flagstaff AZ
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front 3-hoop bumper(soon to be single hoop CM) -Rigid 20" SR series light bar -Rigid Dually D2 Flood pods -KM FABRICATION custom 1/4" steel bumper mounts -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB 6' Awning -KMFAB bed reinforcement -AVID Offroad weld on slider -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -Icons Ext Travel front CO's -King 700# coils -Camburg Uni-ball UCA's -Sway-A-Way 2.0 rear shocks -All-pro Expo LEaf packs w/ custom bumps -35" Goodyear Wrangler MTR's w/ Kevlar -16" SCS SR8's in Black -Custom Retrofits -Smoked Tails -Flare-less mod -AFE ProForce Magnum CAI (went back to stock) -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    Goo 885's and get spacers if it isnt enough. 886's will not give you 3+ of lift though. I have them on a DCL:B without even the factory bumper on there and barely get 3". With a bumper and winch you wont get 3" with the 886's
  9. Nov 22, 2012 at 4:21 PM
    MadToy
    Nick
    Huntersville, NC
    I'm slightly over 3 with about 140 lbs on the front between winch and skids.
  10. Nov 22, 2012 at 4:22 PM
    OZ-T
    Peter North
    British Columbia
    886 or 886x ?
  11. Nov 22, 2012 at 4:22 PM
    OZ-T
    Peter North
    British Columbia
    886 or 886x ?
  12. Nov 22, 2012 at 4:26 PM
    MadToy
    Nick
    Huntersville, NC
    886
  13. Nov 22, 2012 at 4:26 PM
    mh.meier
    MAD MIKE
    Flagstaff AZ
    Just the 886 with no weight in the front at all. No alum factory bumper, no skid plate, no plastic bumper cover.
  14. Nov 22, 2012 at 4:31 PM
    MadToy
    Nick
    Huntersville, NC
    What is your hub to fender height?
  15. Nov 22, 2012 at 4:32 PM
    mh.meier
    MAD MIKE
    Flagstaff AZ
    cant remember off hand but ill measure in a bit.
  16. Nov 22, 2012 at 4:33 PM
    ross123
    ross123 Well-Known Member
    fort bragg
  17. Nov 22, 2012 at 4:35 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
  18. Nov 22, 2012 at 4:41 PM
    MadToy
    Nick
    Huntersville, NC
    For what it's worth, I have zero driveline vibes - although I do have LR UCA's which really make a big difference. My vote would be to do it right and go 886 with that much weight.
  19. Nov 22, 2012 at 4:45 PM
    OZ-T
    Peter North
    British Columbia
    I agree LR UCA's are a good way to go , I have them , but they don't factor into driveline vibrations
  20. Nov 22, 2012 at 4:53 PM
    MadToy
    Nick
    Huntersville, NC
    Not vibes, but not being able to get more than zero degrees caster made freeway driving interesting. LR's make it track like stock again with 2.8 degrees. Definitely a must have IMO.
