Which OME springs for Bilstein 5100's
Discussion in 'Suspension' started by GrtSaint72, Feb 6, 2015.
  1. Feb 6, 2015 at 6:42 PM
    GrtSaint72
    GrtSaint72 [OP] Well-Known Member
    Darrell
    Ewa Beach, Hawaii
    14 DCSB TRD Sport
    I've searched all over and I can't get a solid answer. I have 5100's and I'm curious which OME spring 884 or 885 will give me 2.5" of lift. I have a 14 Prerunner.
  2. Feb 6, 2015 at 6:44 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    thought you were an access cab pre...
    My bad
  3. Feb 6, 2015 at 6:45 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    885 is meant for Double Cabs but any plan for a replacement bumper up front? Some people will tell you no on the OME with 5100's some will say yes. I don't really know. I am going with Eibach 620's up front with my 5100's
  4. Feb 6, 2015 at 6:47 PM
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    885 for double cab
    886 if you are getting weight on front, (bumper , winch)
    Leave 884s with the reg cabs
    Scrat likes this.
  5. Feb 6, 2015 at 6:51 PM
    GrtSaint72
    Darrell
    Ewa Beach, Hawaii
    14 DCSB TRD Sport
    No plans for bumper or armor of any kind. It looks like 885 it is then. I want to eibachs but they are out of stock on toytech. Thank you for the responses
  6. Feb 6, 2015 at 7:01 PM
    slcsez2000
    St Aug, FL
    12 TRD Sport 4x4
  7. Feb 6, 2015 at 7:11 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    So you can use 5100's with OME coils it appears. I have my 5100's on stock coils right now at 1.75. And I want the full 3 inches up front and will not be going with an aftermarket bumper. So should I go with the 885's and a spacer? Or 887's and just the trim packer? And if I went with 885's which spacers would I need to achieve the full 3 inches on both sides.
  8. Feb 6, 2015 at 7:16 PM
    slcsez2000
    St Aug, FL
    12 TRD Sport 4x4
    If you do 885s and a 1/4 spacer on both you should get 3-3.25 (that's what I got when I had my OME kit w trim packer on driver side)
  9. Feb 6, 2015 at 7:22 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    And I also have a new in the box Icon 3 leaf progressive leaf pack with 2.0 Resi's to put in. Will that make me nose high though?
  10. Feb 6, 2015 at 7:33 PM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    I have a 10 prerunner got 885 and Ome Dakars in rear. .. no top plate spacer and at 24 inches hub to fender in front 24.5 in rear... when I first put everything on I was at 25 hub to fender all around ( also has 10 mm top plate spacer in) Dakars settled to 24.5 so removed to get factory rack again.. 4x4 yield different because of the tranny, transfer case and gears that we don't have. .. just food for thought ..pic is before everything settled
  11. Feb 6, 2015 at 8:06 PM
    GrtSaint72
    Darrell
    Ewa Beach, Hawaii
    14 DCSB TRD Sport
    Cool thanks that is the stance I am looking for. 885 for sure now.
  12. Feb 6, 2015 at 8:26 PM
    Jeffvt0508
    Jeff
    Anderson, SC
    You will need new ucas for alignment for it.. I went budget with light racing
  13. Feb 9, 2015 at 10:10 AM
    Matlok
    Matlok New Member
    Calgary
    11 TRD Sport DCSB
    I pieced together my lift and finally installed it (myself) 2 weekends ago - and took it off road for the first time yesterday.
    OME 885's certainly do work with 5100's, but I recommend getting them assembled at a shop and leave the collar at the lowest setting...
    I have a DCSB 4wd and had to put a 1" block in the rear to get it level (canadian truck with 4 leafs/tsb already) - now I have a very slight rake and taco lean but just shy of a 3" lift with the Billies set at 0.
    Tech at Toyota got the alignment "in spec" on stock UCA's. Handles great!
    Took my swaybar off yesterday, aired down to 22 psi and hit some rutted, potholed, wet gravel roads and a bit of technical wheeling too.
    Long story short - I'm very impressed with how the 885 coils and 5100's perform. Great dampening at speed over rutted, potholed roads and great rebound control on the bigger stuff. Worlds better than my factory TRD sport setup!
    Hope this helps you decide, this members here certainly helped me...!:bowdown:
  14. Jun 18, 2024 at 8:06 PM
    NKTacoma808
    NKTacoma808 Member
    Naea
    2013 Pyrite Mica TRD Sport
    L
    Bumping this thread, but any photos of the truck with the lift installed, I currently have ToyTec spacers on 5100s but want to move away from spacers and upgrade the coils to 885.
    Mahalo in Advance!
  15. Jun 20, 2024 at 10:16 AM
    Ponder85
    Ponder85 Well-Known Member
    Brandon
    Cincinnati, OH
    19 DCLB TRDOR
    I'm also considering Bilstein 5100s and am trying to figure out springs for my 4x4 DCLB.
    Is there a good retailer that sells Bilstein/OME assembled?
  16. Jun 24, 2024 at 4:53 PM
    Akguy
    Akguy Well-Known Member
    way up north
    23' Silver OR DCSB
    It's been 9 years since they posted and only had one post. If they respond I'm gonna be truly shocked
  17. Jun 24, 2024 at 4:55 PM
    Akguy
    way up north
    23' Silver OR DCSB
    Yes, check out the vendors section on here
    Ponder85[QUOTED] likes this.
