which one??
Discussion in 'Lighting' started by Blackyy, Apr 11, 2013.
  1. Apr 11, 2013 at 1:14 PM
    Blackyy
    Blackyy [OP] Active Member
    Which one is the most whitest the 4300k, 4500, or 5000k?
  2. Apr 11, 2013 at 1:14 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
  3. Apr 11, 2013 at 1:18 PM
    beaver_scott
    beaver_scott Well-Known Member
    scott
    renton, wa
    2015 inferno trd pro
    vent shades, tinted windows, clear bra, pop n lock tail gate lock, anytime fog light mod.
    5000k. below 5000 will be a yellowish and above 5000 will be blueish
  4. Apr 11, 2013 at 1:23 PM
    nfs257
    nfs257 Well-Known Member
    Menifee, Ca
    09 DCLB PreRunner MGM SR5 Debadged
    Trac Performance built Prerunner
  5. Apr 11, 2013 at 2:51 PM
    Blackyy
    Thank you!
  6. Apr 12, 2013 at 9:27 AM
    DevL
    DevL Well-Known Member
    Depends on the company. Many low end Chinese bulbs labeled as 5000K are blueish because they use cheaper salts. For those companies 4500K is both whiter and higher output. Then you have bulbs like Osram CBI which are the highest lumen bulbs made, even over 4300-4500K bulbs and they are pure white 5000K color temp.
  7. Apr 12, 2013 at 9:35 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Philips 4300K
    QC and the quality of salts is very important
  8. Jun 29, 2014 at 2:59 PM
    mightytacoman
    mightytacoman Well-Known Member
    kelby
    Moving every 3 months
    Heavily upgraded
    Magnuson supercharger, Walbro 255 fuel pump. URD supergrip pulley 2.825", Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluid swap, Afe Stage II with pro-dry filter, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 2- 20" light bars, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 12" sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. Optima yellow top, Helo 791 rims, 315/75/r16 Mt/r
    Always heard 4500 is the whitest and most visible/ usable light.
