Which Portable air compressor behind seat
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Minimedic, Oct 8, 2022.
  1. Oct 8, 2022 at 12:56 PM
    Minimedic
    Minimedic [OP] Well-Known Member
    Tacoma DCLB OR MGM
    Tried searching but unable to find a thread about which portable air compressors that will fit behind or under seat of 3rd gen DC rear seat. Hoping a ViAir 300 or 400 will fit back there
  2. Oct 8, 2022 at 2:11 PM
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
    Viair has a compressor model/tire size chart. Make sure the air machine you buy is sized for the tires U expect to run.
  3. Oct 15, 2022 at 12:02 PM
    MavericksTaco
    MavericksTaco Well-Known Member
    Bob
    17 TRD OR DCSB
    Mobtown skids, ARB diff breather, pop-n-lock, sabellco tailgate lock, ARB 2” med lift kit, BP fab recovery hook, bakflip mx4 tonneau cover
    I bought the ARB dual portable compressor a while back. Expensive but it has been the best piece of off road equipment purchase i have made. I could even use it to even run some airtools in a pinch.
  4. Oct 15, 2022 at 12:11 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
  5. Oct 15, 2022 at 12:43 PM
    eurowner
    eurowner Duke Sky
    Scoty
    100%
  6. Oct 15, 2022 at 1:07 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
  7. Oct 15, 2022 at 1:48 PM
    Minimedic
    Tacoma DCLB OR MGM
    Looks like a good option and can use different brand compressors which is nice. Anyone have any pics or tips for install of this? Their website doesn’t say anything
    Edit: Nevermind I found video on expedition essentials website
  8. Oct 15, 2022 at 1:54 PM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
  9. Oct 15, 2022 at 1:59 PM
    Minimedic
    Tacoma DCLB OR MGM
  10. Oct 15, 2022 at 2:04 PM
    Devious6
    Mark
    I actually haven't used it, yet - more for an emergency than every day use. It certainly doesn't have the power of the 300 or 400 but it's rated up to 33" tires. Probably not what you want if you are going to use it regularly, though.
  11. Oct 15, 2022 at 2:14 PM
    Kyle_
    Kyle_ A guy and his expensive hobby
    Kyle
    SoCal (805)
    2021 TRD OFF-ROAD 4X4 DCSB
    @tacoma.kyle on IG
    I have it and have used it a few times already. I have stock tires 265/70/r16 and they fill up at a fast enough pace. I run my tires at 32-35 psi and airing up to that from 18psi ish took about a minute-ish - minute and a half ish per tire if I recall correctly.
    Its compact and has worked fine. It does get very hot so if you get it, be careful. it does cool down quickly enough. The bag is ridiculously small and you won't be able to zipper it shut completely. The only thing that I have heard is to get an extra fuse or two in case the fuse pops. Its worked each time so far and for me, works great. I don't need to haul a larger compressor just to fill up a bit faster. Why be in a rush? it fits great behind the seats and is light.
