Which problem do I tackle first? 07 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UncleArty1776, Jul 24, 2017.
  1. Jul 24, 2017 at 9:10 AM
    UncleArty1776
    UncleArty1776 [OP] Active Member
    NoVa
    2017 White Tacoma TRD Off-Road
    Apologies if this is not the right area for posting this questions. So I have a 2007 Black PreRunner Sport with an automatic V6 engine with about 100,000 miles. I have three main problems that I know I need to fix and I need to see if one is connected to the other two/how to fix them. I am no mechanic, however, I do not shy away from learning new things about my truck.
    (1) While driving, in any sort of condition (highway/surface roads), with my foot on the pedal, sometimes the engine seems to "lag". It's a hard thing to describe, but the best I can describe it is that it is if the truck is rolling along and then all of a sudden it feels like it is being pulled back and not able to go faster. It eventually kicks in, however it is very disconcerting, and I would like to get this problem fixed first.
    (Wondering if the either of the next two problems is related to the 1st)
    (2) I know that the pullies and belt need to be replaced, as I can hear squeaking when I accelerate now and then. Sometimes it is worse than others. I believe the best guide I have found on the interwebs is http://www.fjcruiserforums.com/foru...154-idler-pulley-bearing-failure-what-do.html
    (3) Also, something that started happening recently is after I park and turn the engine off, the brake lights stay on. If I pull the brake pedal towards me, the lights immediately turn off. Should I just purchase a whole new brake assembly.
    I have a feeling that the (1) and (3) are related as (1) seems to go away when I put my foot underneath the brake pedal and pull. However, I would like to know what the community thinks.
  2. Jul 24, 2017 at 9:42 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Clean you maf and throttle body. Replace belt. Replace you brake light switch/ adjust brake pedal push rod. When were your spark plugs replaced last?
    UncleArty1776[OP] likes this.
  3. Jul 24, 2017 at 11:18 AM
    UncleArty1776
    NoVa
    Probably not recently enough, is the spark plug what you think the problem is with problem (1)?
  4. Jul 24, 2017 at 11:31 AM
    Muddinfun
    Muddinfun Well-Known Member
    The brake switch is the cause of both 1 and 3. The computer slows you down if it thinks you're on the brakes.
    JoefromPTC likes this.
  5. Jul 24, 2017 at 12:20 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
